Results 1 to 9 of 9
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Engine Bay Squealing Noise Identification
    The other day when I started up my Q5, I heard a somewhat loud squealing noise from the front lower left (drivers side) engine area. It only makes the noise when idling, goes away when I rev the engine and also went away completely when I turned on my A/C and defroster (didn't come back after I turned them off either). It sounds like it's coming from the A/C Compressor area, but I am not 100% sure it is the compressor. My car is a 3.0T with about 60k miles, any ideas?
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
    Established Member Two Rings Aries_27's Avatar
    Sep 28 2016
    Michigan
    Quote Originally Posted by choppstixxx View Post
    I had the same noise this morning. Never had it before and when i went out for lunch it wasn’t there. Same exact thing you’re describing.
    I was told it’s possible that it’s the secondary air pump but can’t confirm yet
    IG: sq5_igor
    2016 SQ5 P+ Florrett Silver w/ Black Optics
    Current Mods
    - APR Carbon Open Intake-034 Silicone Intake Hose-Vast Performance Custom Stg 1 Tune-KW Street Comforts-Powerflex Front Bushing Upgrade Kit-Uniden R7/Blendmount/Mirror tapped-NemesisAutosport 15/20 Spacers
    Coming very soon -JHM 187mm Pulley-Vast Performance Custom Stg 2 Tune-034 X-Brace-034 Rear Sway Bar
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by Aries_27 View Post
    I told my buddy that was a Master Audi tech. He had me spray a little brake cleaner on the belt that runs on the A/C compressor to see if it quieted it down, but it didn't change the sound. Then when I pressed my defrost and A/C it went away completely. I will say that I haven't been driving my car as much as usual due to working from home, but it stays in the garage and the only thing I can think of is the recent drop in temps (20-30*).
    Sep 28 2016
    Michigan
    Mine stays in the garage every night. I do drive everyday to work. I only get a very light squeal in the morning and at 7-8ish when i leave work. Never during the day. And this morning the noise you had came up and that was it
    IG: sq5_igor
    Current Mods
    Jul 31 2016
    PA
    Secondary air pump is on the passenger side at least on the 3.0T, could just be the accessory belt that needs to be replaced. Otherwise maybe AC clutch or bearing if it went away when the SC went off. Id start with the belt.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Nov 07 2016
    Phoenix, AZ
    Sounds can be tricky to pinpoint. I know from experience and got a good tip here on Audizine when I had a squeal that sounded absolutely like a dry ringing bearing. Check your PCV by removing the oil filler cap with the engine running. If the squeal stops that's your clue. The vacuum may be high enough that removing the cap is difficult so just start the engine with the cap off. If all is quiet and the noise starts after replacing the cap it's a strong indicator that the PCV is bad.
    If the PCV is bad try to keep miles to a minimum the noise is from the seals squealing as air is drawn in from too much vacuum. There are several write-ups on here to make diy a cinch.
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by djn876 View Post
    I'm with you. I favor it being either the accessory belt or its tensioner or idler pulley.
    I would not want it to break or throw that belt, as it also drives the water pump.
    It could be the a/c compressor clutch or bearings, given the report that the squeal stops when its turned off. But, that might be simply due to the load resistance being removed from the accessory belt and tensioner.
    On another car I have (non-Audi) the same issue was resolved by replacing the accessory belt tensioner pulley. Its good practice to replace the idler pulley at the same time when you have the belt off. These are cheap parts.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Apr 24 2017
    Hilton, NY
    Quote Originally Posted by MSq5 View Post
    I just ordered a new accessory drive belt from FCP Euro, should be here in a few days. Have a new supercharger belt too that I was going to install anyways for my 60ish thousand mile service. Haven't heard the noise since I turned on/off the A/C, but rather try to sort things out in case it is a bigger issue. Thanks everyone!
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Recently mine started making the same noise as you describing. I'm under 30k miles (45,000 km's)
    Did changing the accessory belt fix the issue?
    Sent from my Pixel 3 XL using Tapatalk
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
