Results 1 to 40 of 85
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Anyone running the new design CTS K04?
    Just keep in mind that you might have clearance issues with the CTS manifold. It was literally 1/16th taller than stock.
    Make sure you test wastegate cracking pressure BEFORE you install it. It’s easier to set it higher out of the car than in.
    Make sure your N75 hoses aren’t bent and replace the N75 they supply with a new Pierburg or genuine Audi valve
    All of these things are easier to do before you install it or try to.
    2016 S4 premium plus, Glacier White Metallic, black optics, carbon trim, magma interior. APR dual pulley Ultracharger and TCU, APR intake, Merc HX, CWA100, APR A01 wheels, ECS rotors, Michelin PS4S, 034 trans mount, AEM 400cc’s meth
    APR tune [email protected]
    Jackal tune 10.68@129
    stock blower, stock cats, stock suspension.
    Veteran Member Four Rings Kevin C's Avatar
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    It seemed to fit my 1.8T just fine.
    2003 02X Six speed swapped, RS4 RSB, H&R FSB, B7 brakes, 2.0T stroker, DSMIC's, B7 CTS K04 turbo.
