Page 7 of 9 FirstFirst ... 56789 LastLast
Results 241 to 280 of 323
  1. #241
    Veteran Member Three Rings a1dan_87's Avatar
    Mar 07 2018
    Utah
    Do you guys have any plans for underbody shielding? We don't really have any US based options for skid shields, and I for one would possibly be interested...
  2. #242
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Quote Originally Posted by a1dan_87 View Post
    As of right now we do not
  3. #243
    Junior Member Two Rings pele75's Avatar
    Nov 19 2020
    Vancouver, WA
    Quote Originally Posted by pploeser View Post
    Nice, I’ll wait and save my pennies.
    Same here
    2010 A6 Avant Sport Pkg. | JHM ECU/TCU Stage 2 | JHM Downpipes | JHM Cat-back exhaust | JHM 207mm Pulley | JHM Snub Mount | JHM HeatX | JHM Throttle Body Inlet Hose | JHM Driveshaft Support Upgrade
  4. #244
    Aug 31 2011
    Lathrop
    The exhaust sounds good
    After several different combinations we came up with a recipe that has a clean note that doesn't require baffled downpipes. HFC only sounds great. No obnoxious 3.0t sounds
  5. #245
    Jan 21 2020
    Michigan
    Quote Originally Posted by Jake@JHM View Post
    Nice!!
  6. #246
    Junior Member One Ring
    Jul 13 2022
    Colorado Springs
    Would this throttle body upgrade work with your tune or is it going to have to be a custom tune?
    https://garageautosports.com/product...30736796811360
  7. #247
    Aug 31 2011
    Lathrop
    Quote Originally Posted by ColoradoAvant View Post
    It's possible the 75mm would work. However we have never tested it.
  8. #248
    Jan 21 2020
    Michigan
    Has the C6 platform development been done with a stock throttle body?
  9. #249
    Aug 31 2011
    Lathrop
    Everything we have done has been with stock TB yea
  10. #250
    Oct 04 2018
    Europe
    @Jake@JHM Would you share share what else are you planning to introduce for A6 C6 with 3.0TFSI ? I believe that will be interesting for many people.
  11. #251
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Tuned yesterday and pushed it some today. Feels nice and strong! That TCU tune is good stuff 🤌
    Sent from my Pixel 6 using Audizine Forum mobile app
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
  12. #252
    Nov 19 2020
    Vancouver, WA
    Are we closer to it being available to purchase?
  13. #253
    Aug 31 2011
    Lathrop
    Quote Originally Posted by pele75 View Post
    We are currently building the fixtures so It should be on the website in a couple weeks or so
  14. #254
    Jan 21 2020
    Michigan
    Ordered today!
  15. #255
    Aug 31 2011
    Lathrop
    Ordered today!
    Thanks for the order!
  16. #256
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    I currently have the dual pulley tune from EPL as they were the only ones available a couple of years ago. Since EPL is now gone, can I get the JHM tune and flash it on top of the EPL tune? Or do you have the stock tune that can be flashed over before loading the JHM tune? As far as I know, the EPL tune does not lock the ecu. Also, I have some TCU tune for the ZF6 from some local tuner here in NJ (Mirza) since he was the only one that had one available as well. So same question, can it be flashed over w/ your TCU tune? I've been really impressed on what JHM has done w/ the C6.5 A6 platform. I just wished you guys already came out with all these stuff when I first started modding mine.
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
  17. #257
    Jan 21 2020
    Michigan
    I finished installing the catback system today to compliment the JHM catless downpipes. I also swapped in the JHM intake pipe with stock air box and filter.
    Overall the catback install was straightforward and not bad for a DIY. Lined up well with factory mounts and the 4” tips are a nice touch.
    I don’t have any sound clips yet but the volume is a good bit louder than stock, with a nice deep tone. Pretty lively on cold starts and high revs but very tame at idle when it warms up. Haven’t had it on the highway yet so can’t really comment on drone at cruising speed but around town it sounds nice with windows up or down.
    JHM Stage II next then coilovers and Rotiforms I think.
  18. #258
    May 09 2012
    Virginia
    Quote Originally Posted by alexdell View Post
    I’m in the same boat. Though I don’t have the TCU tune. Interested to know the details.
  19. #259
    Aug 31 2011
    Lathrop
    Yes we can flash over existing software
  20. #260
    Aug 31 2011
    Lathrop
    Right on!
  21. #261
    Jul 29 2011
    Central NJ
    That's great to hear. Sucks that I have to eat up the ECU/TCU costs from my previous tune but I would rather have a company that is still around to support the platform. Hoping to see some Black Friday package deals on the ECU/TCU, flashing cable and baffled downpipes so I can pull the trigger. I'm thinking of going w/ the baffled DP since I have an avant which seems to be louder inside based on some of the reviews when I eventually get the catback exhaust down the line.
    IG: @puzoyAlex
  22. #262
    Jul 27 2018
    2010 Audi A6 Avant 3.0T
    Coquitlam, BC
    Agh nice. If you'd be kind enough to post some sound clips with the baffled downpipes whenever you get them that'd be cool
    Sent from my Pixel 6 using Tapatalk
  23. #263
    Aug 31 2011
    Lathrop
    Keep an eye out! ;)
  24. #264
    Mar 21 2022
    Keep an eye out! ;)
    dear jake, how can i contact you directly? thanks :)
  25. #265
    Jul 29 2011
    Central NJ
    Keep an eye out! ;)
    I'm seeing the 15% BF sale for all JHM products for today only on the website. When I try to order the ecu/tcu tune as well as the baffled DP, it's only showing a 10% discount. Is there a code or something the needs to be entered?
    IG: @puzoyAlex
  26. #266
    Jul 29 2011
    Central NJ
    Looks like the site is fixed now for the 15% off BF sale. About to order the goodies....
    IG: @puzoyAlex
  27. #267
    Aug 31 2011
    Lathrop
    Were you able to get the order in correctly?
  28. #268
    Jul 29 2011
    Central NJ
    Yes. Ordered the ECU/TCU tune and the baffled DP on Friday. I need to get my ecu swapped first though since I'm having an issue w/ the barometric pressure sensor which seems to be inside the ECU. Found a local guy that will program the immobilizer to a donor ecu.
    IG: @puzoyAlex
  29. #269
    Aug 31 2011
    Lathrop
    Oh right on! Thanks for the order
  30. #270
    Jul 29 2011
    Central NJ
    Hi Jake, while I'm waiting for my catted baffled DP's to be made and shipped out, would I be able to flash the stage 2 ecu/tcu file (stock cats file)? Then once I get the DP, reflash it again w/ the file specific for that? Actually, is there a separate file for the catted baffled DP running DP or is it only for test pipe ones?
    Thanks,
    Alex
    IG: @puzoyAlex
  31. #271
    Aug 31 2011
    Lathrop
    Thanks,
    Alex
    Hey Alex,
    you can flash the stock downpipe file now and then when you get our downpipes installed you can flash the JHM Downpipe file. The options are Stock DP or JHM DP for the files
  32. #272
    Jul 29 2011
    Central NJ
    Awesome! Are there different files for test pipe/catted/catted baffled DP's? Curious if it actually makes a big difference. The setup on my Avant will be the baffled catted DP and later on will probably get the JHM exhaust down the line.
    IG: @puzoyAlex
  33. #273
    Aug 31 2011
    Lathrop
  34. #274
    Jul 29 2011
    Central NJ
    Thanks. Also, will I be charged the $55 server access fee if I switch tunes later on? I was not aware of this until I saw the customer tuning sign-up form. I was able to flash back & forth w/ different tunes w/ the EPL at no additional costs.
    IG: @puzoyAlex
  35. #275
    Aug 31 2011
    Lathrop
    Typically no, we don't really charge anyone unless they start abusing it or flashing excessively for no reason.
  36. #276
    Established Member Two Rings alex--monteiro's Avatar
    Mar 27 2021
    trusty Honda Accord
    Dorchester, MA
    Got sound clips? What's the review after a few more weeks of use??
  37. #277
    Jan 21 2020
    Michigan
    Quote Originally Posted by alex--monteiro View Post
    No sound clips yet. Overall I like the tone and would say the volume inside is a tad too loud for the average passenger (ie not a car enthusiast). I have the cat-less downpipes and a wagon which is probably the worst case. I had some spare 12x12 foam acoustic panels I stuffed around the spare tire which helped with boom inside the car. I have all the parts to do stage II+ as soon as I stumble upon a favorable combination of free time, good weather, and motivation. After that I may pursue additional exhaust tweaks to take the edge off interior drone. I’ll get some sound clips post-tune.
  38. #278
    Jul 27 2018
    Coquitlam, BC
    I would recommend sticking some of that dynamat sound proof material to the inside of your wheel well. I took my entire trunk apart for my b7 avant and stuck that on everywhere I could. Reduced the drone greatly.
    Does anybody on here have the high flow cats ? what's the sound like ?
  39. #279
    Jul 27 2018
    Coquitlam, BC
    Bringing this back how are folks doing with the stage 1 ECU and TCU tune?
    Still running strong with no issues? Anything to report about around town driving and what not?
  40. #280
    Mar 07 2018
    Utah
    Quote Originally Posted by ewmin3m View Post
    Only thing to be reported is, if upon tuning you have any transmission shift/slip issues, have the transmission immediately serviced and reflash the software on the car
    Sent from my LE2127 using Audizine Forum mobile app
