JH Motorsports is proud to release our JHM C6 A6 3.0T ECU and TCU Software!
Our Stage 1 and 2 performance ECU and TCU software is specifically designed to work in harmony together maximize the engine power output capabilities. With extensive research and testing with our in house C6 A6 3.0T, we have created the ultimate software for your car. Our tuning will give your A6 improved throttle response, higher shift points, and more power throughout the entire RPM range leading to faster acceleration and a much more rewarding and refined driving dynamic.
This is a one and done solution with 1 Flashing Cable Required (JHM Power-Connect) and can be flashed at the convenience of your own home with an internet connection.
By making an ECU and TCU combination that works together we were able to do the following for your C6 A6 3.0T:
• Engine Rev limit increased to 7100rpm to match the B8 S4 3.0T
• More aggressive throttle control in Sport Mode
• Increased shifting speeds
• More assertive shifting in Sport mode and after launching
• Launch Stall RPM raised from ~2000 to ~3000 (outside factors can alter this result)
• More aggressive and consistent Launch
• Refined Drive and normal driving shifting dynamics
• Decreased Transmission wear due to less slipping from faster shifting
• Raised TQ limiters
• Maximum Boost for each Pulley Ratio
• Safe EGT Management for stock catalyst protection keeping your car as safe as possible while maximizing performance
• Free Upgrade from Stage 1 to Stage 2 to Stage 2+
STAGE 1 PERFORMANCE:
MODS:
JHM Stage 1 ECU/TCU Software - JHM Auxillary Heat Exchanger Kit (JHM-PMPHXC6A630T) - JHM C6 A6 Silicone Throttle Body Hose (JHM-06E129629P)
STAGE 2 PERFORMANCE:
(Currently limited by stock exhaust. JHM Downpipes and Catback coming soon)
MODS:
JHM Stage 2 ECU/TCU Software - JHM Auxillary Heat Exchanger Kit (JHM-PMPHXC6A630T) - JHM C6 A6 Silicone Throttle Body Hose (JHM-06E129629P) - JHM C6 A6 Max Clearance Snub Mount System (JHM-C6A630TSnubKit) - JHM 179mm Overdrive Crank Pulley (JHM-06E105251F-179mm)
Keep an eye out for even faster results coming soon!
CLICK HERE TO ORDER
Power-Connect Flashing Cable: https://jhmotorsports.com/jhm-power-...-and-tcus.html
If you have any questions or would like help placing your order, please feel free to contact us!
[email protected]
209-968-0077
