Page 31 of 32 FirstFirst ... 2129303132 LastLast
Results 1,201 to 1,240 of 1244
  1. #1201
    Jul 16 2018
    Atlanta
    I suspect the answer to both of those is "no".
  2. #1202
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by Smac770 View Post
    Yeah I suspected that. Just a waste of technology and cool factor not to utilize. And now way am i paying $800 a year for what my phone can do.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
  3. #1203
    Jan 28 2022
    Seattle area
    Upon warm startup, I get a very strong chemical smell in the cabin (like a mixture of gasoline and used motor oil) through the HVAC vents. It happens immediately upon startup - not nearly enough time for exhaust to make its way in (doesn't smell like exhaust anyway). At first I thought it was a burp coming out the turbo, then the open air intake box in the engine compartment and then finally getting sucked into the HVAC system intake, but I've started the vehicle with the recirc on (default is off) and still get the smell. I've been tuned for so long can't remember if it was there before stage 1 and/or stage 3. No CELs, no DTCs, no under hood oil or fuel leaks I can see. I just replaced the PCV breather tubing and vent valve assembly (oil cap was leaking) and still there. Any ideas? Nothing major but kind of annoying.
    2021 Audi SQ5 Prestige SSP w/Sport Exhaust and APR Stage 3 (91 octane) - 0-60 in 3.5 s and 1/4 mile in 11.6 s @ 117 mph
  4. #1204
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Quote Originally Posted by GoCougs1234 View Post
    Iirc, even if the HVAC is off, the blower will still be on "recirc" to move the cabin air. That said, on my '21 SQ5 Sportback, when I initially turned-on the HVAC, I noticed a petroleum smell before it dissipated. Turns out the evaporator core had a small leak, and it was likely the compressor oil that is comingled with the refrigerant that I was smelling. My dealer found the leak and replaced the evaporator under warranty. No more weird smells.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
  5. #1205
    Jan 28 2022
    Seattle area
    Quote Originally Posted by B6_Dolphin View Post
    Thanks, that makes total sense. Mos def a petroleum smell, but to me not really gas/exhaust/motor oil - the closest would be gas. Of course, I'm WAY out of warranty, and it probably involves removing the dashboard (i.e., expensive) so I'll just suffer it for now.
  6. #1206
    May 03 2010
    2012 TT Sold
    Maine
    Gotta get a vag tool and inspect. also look underneath as well on a cold day and see if anything shows.
    2002 A4 1.8T - sold
  7. #1207
    For the 17KW PHEV 55, - Would I be better off with the genuine Audi wall plug in charger or would investing into a "better" wall charger be any better? I have a friend who works for a company that sells the wall chargers I forget the name but they are name brand and offer special features. I'll have to report back
    I would be using it on a 120V standard outlet (apartment reasons)
  8. #1208
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Quote Originally Posted by MayorMcCheese View Post
    If you’re in an apartment will they even allow you to install a permanent wall charger? One potential downside to the Audi included charger is that there is no lock on the wall side. So someone could mess with you and unplug you from the wall and you would stop charging unexpectedly. That would be less of an issue with a hardwired wall plug since the charger locks to the vehicle. As for other special features of a wall charger, not sure what you’re referring to?
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
  9. #1209
    May 03 2010
    2012 TT Sold
    Maine
    I was looking to increase the rotor size from 350 to 380 with the stock calipers. Will this work and do they make a bracket for this? I've seen full kits but want to keep the stock calipers.
    2002 A4 1.8T - sold
  10. #1210
    Jul 16 2018
    Atlanta
    Can you hack it to work, maybe. Is it a bad decision, likely. Even for the factory 375x36 vs 350x34, both using the same Akebono 6-piston fixed caliper system, it's different calipers for the larger rotor size. Look at the space between the rotor and caliper on your current system. Then imagine how far the caliper will have to back off the rotor to fit over a larger diameter rotor.
    B9 SQ5 350x34: https://audi.7zap.com/en/usa/audi+q5...id-615-615055/
    B9 SQ5 375x36: https://audi.7zap.com/en/usa/audi+q5...id-615-615056/
    Appears 034 has said as much: https://www.audizine.com/forum/showt...1#post14941856
  11. #1211
    May 03 2010
    2012 TT Sold
    Maine
    That's the explanation I was looking for! Thank you!
    2002 A4 1.8T - sold
  12. #1212
    Junior Member Two Rings FUZE's Avatar
    Aug 26 2016
    Tustin, CA
    Garage door opener
    I tried searching, but wasn’t successful managing the search function on my phone…
    For some reason the garage door opener feature is grayed out in the MMI. I’m not sure when this “broke” but this used to work, now it’s not. Can anyone point me in the right direction to get this working again?
    Many thanks!
  13. #1213
    Jul 16 2018
    Atlanta
    Start with a scan for codes; see if the car is aware of something being wrong and address that. If the car isn't pointing out any issue, you probably should point out if this is a B9.0 MIB2 vehicle or a B9.5 MIB3 vehicle, since the human interface to the HomeLink is different between them. And MIB3 could have any number of wtf problems.
  14. #1214
    May 03 2010
    2012 TT Sold
    Maine
    Quote Originally Posted by FUZE View Post
    Many thanks!
    These MMI systems are so much of a PITA!! I assume the car is started? Hate it when i park and want to go in through the garage and have to start to use function.
    2002 A4 1.8T - sold
  15. #1215
    Jun 11 2013
    Hermiston OR
    My 25 SQ5 came with the trailer hitch option. Anyone take theirs off? Is there a different lower bumper cover if you don't have a hitch?
  16. #1216
    Jul 16 2018
    Atlanta
    Quote Originally Posted by erslll View Post
    Yes, the lower spoiler is different for without trailer hitch (1D0) vs with trailer hitch (1D4) or with trailer hitch prep (1D8). Since the trailer hitch for NAR is a port accessory rather than a factory part, NAR Q5 come as 1D8.
    For the facelift since mid Aug '23, the rear sport bumper lower spoiler can come in either satin black or brilliant black. Prior to that, the facelift rear sport bumper lower spoiler was only satin black.
    1D0: 80A 807 434 F 9B9 for satin black or 80A 807 434 H Y9B for brilliant black
    1D8: 80A 807 434 G 9B9 for satin black or 80A 807 434 J Y9B for brilliant black
    I assume the only difference is the hole for the hitch to stick through.
  17. #1217
    Established Member Two Rings cmil527's Avatar
    Oct 16 2023
    Old Bridge NJ
    Anyone add rear footwell lighting to a Premium Plus? I'm assuming its standard on the Prestige and was curious if its prewired under the seat? TIA
    2024-SQ5-Glacier White/Magna Red-Prem+-Options:S Sport,Nav,Sport Exhaust,BO Pkg & 21'' BO Wheels,Nappa Leather,Audi "S" Beam,Cargo Cover,Black Rings,Audi Guard-Mods:HRE FF10-21X9.5''-Tarmac-255/40 Pirelli P-Zero,20% Side & 35% Windshield Tint,JB4 Map 6 w/Bluetooth,Roar Pedal,034 Turbo Inlet & Trans Mount,AWE IC,Roc Euro Intake,ECS X-Pipe/Res Delete,Badgeskins DRL Kit,TGK Lowering Links,DSG Red CF Paddles+PSB,Maxton Kit w/V2 Lip & Roof Spoiler
  18. #1218
    Jun 11 2013
    Hermiston OR
    Thank you. Just what I was looking for.
  19. #1219
    Jul 16 2018
    Atlanta
    Quote Originally Posted by cmil527 View Post
    Wow, the cost cutting by Audi these years. So the rear footwell light was deleted from QQ1 starting MY22. The rear footwell light p/n for the facelift is 4E0947415A (which represents even more cost cutting, it was RGB for B9.0). And we see the seat harness p/n changes starting MY22 for QQ1 configs. So very likely they removed the connector.
  20. #1220
    Oct 16 2023
    Old Bridge NJ
    Thank you sir.. ridiculous!
  21. #1221
    Mar 17 2025
    Ohio
    Will the factory warranty on MY25 be kept if I upgrade intake to integrated engineering intake ? And nothing else
  22. #1222
    Veteran Member Three Rings chrisdazzo's Avatar
    Aug 11 2015
    RAV4 Limited
    Mountains, CO
    Quote Originally Posted by Whitigir View Post
    Yes, intakes are safe mods.
    '21 Ultra Blue x Black Nappa ▉SQ5
    Prem+ : S Sport : Black Optics : Carbon Atlas
    21" Black Optic Wheels : B&O Audio : S Beam
    034 Res-X Res Delete + X-Pipe : IE Polymer Intake
    12.5/15mm Spacers : 034 Trans Mount Insert
    35% Ceramic Tint : 3M Front PPF
    [_SQZME] : Previously: MKV Jetta 2.5, B8.5 A5, 8V S3, B9 A5 SB
  23. #1223
    Sep 05 2014
    Has anyone tried the Matrix LED activation through ACM Technik? Quite a bit cheaper than some other options.
    Ken
    2021 Q5e Prestige
    District Green
  24. #1224
    Mar 17 2025
    Ohio
    Quote Originally Posted by Sweep View Post
    I was looking into options as well, and I hear that wrong codings can burn out the modules which cost $3000 for the lights ...? Not sure how true that is, but it halted me on looking further. I know on BMW with an App and OBD, I can activate it just fine
  25. #1225
    Sep 05 2014
    This is news to me, where did you read this?
    Ken
    2021 Q5e Prestige
    District Green
  26. #1226
    Established Member Two Rings PDR Jack's Avatar
    Dec 05 2019
    Plano Texas
    2024 SQ5. The Audi Pre-Sense thing is driving me up the wall. MMI only allows it to be turned off for that trip, and resets to be on again the next time the car is started. I really want it turned off and have it stay off. From what I've heard, even the dealer can't/won't disable it. Is there anything I can do myself, like VCDS perhaps? I tried searching the forum but came up empty.
  27. #1227
    Established Member Two Rings Txlifter's Avatar
    Oct 10 2024
    Wife's car 2018 SQ5 Prestige, completely stock which is how she wants it!
    San Antonio, TX
    Quote Originally Posted by PDR Jack View Post
    What is it doing? Pre sense really shouldn't be a daily interaction.
    2018 SQ5 florett silver prem+ with all the things.
  28. #1228
    Mar 17 2025
    Ohio
    Is this the imminent collisions warning ? It bothers me greatly when the vehicle is ways far behind another vehicle but I dont step on the brake...for example when I use engine brake and dkdnt have my foot on either pedals.
  29. #1229
    Dec 05 2019
    Plano Texas
    Quote Originally Posted by Txlifter View Post
    The Imminent Collision Warning pops-up on the screen with a loud "ding". And on one occasion the vehicle even applied the brakes sharply 2x on me. I heard that there was a class-action lawsuit over this, because it has actually caused some people to be hit from the rear because their Audi applied the brakes like that.
  30. #1230
    Oct 10 2024
    San Antonio, TX
    Definitely not operating correctly then. Have you had a calibration done? Someone here will know more than I do but that isn't normal operation for sure.
  31. #1231
    Dec 05 2019
    Plano Texas
    Thanks. I guess it's worth having them re-calibrate it. I bought it 5 months ago with only 9400 miles on it. It was the service manager's company car at an Audi dealership, no accidents, no re-painted panels. Wouldn't expect that anything was off-kilter on it to need a calibration but if the behavior seems abnormal I'll go give that a try.
    I do drive pretty aggressively, but in Dallas traffic you either lead, follow, or get the hell out of the way. I don't want the car trying to drive for me. That forced-braking ain't gonna fly. If I can't find a resolution it's going to have to be traded-in on something else.
  32. #1232
    Oct 10 2024
    San Antonio, TX
    Check your MMI settings. Vehicle-driver assistance - pre sense. I believe you should have options to turn it down or off in there. Just checked the neighbors car 2024 Q7 and it's in there.
  33. #1233
    Dec 05 2019
    Plano Texas
    It's in there. I've found it. But that is only good for that trip. Once you turn the engine off, that setting reverts back to "on" again upon the next start. No way to turn it off and keep it off via the MMI. I have heard that it isn't like that on earlier year-models and it will stay off, but on mine ('24) it reverts.
  34. #1234
    Sep 05 2014
    A place to ask random questions thread
    Has anyone been able to successfully remove the front bumper lower trim without pulling the entire bumper off?
    Or if anyone happens to have a copy of the service manual for the B9.5s? I only have up to the B9.
    Ken
    2021 Q5e Prestige
    District Green
  35. #1235
    Oct 16 2023
    Old Bridge NJ
    All 1 piece as far as I could tell, I've had my bumper off a few times!
  36. #1236
    Sep 05 2014
    I know it’s one piece since I have a black version that I’m trying to replace it with. I was just wondering if there was a way/trick to disengage the tabs without having to take the bumper off to access from the inside
    Ken
    2021 Q5e Prestige
    District Green
  37. #1237
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    So is there a US made tire that competes with Continental DWS06+ or did they just become 25% more expensive when I plan to replace tires this summer?
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
  38. #1238
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by jlaudio View Post
    At a high-level, Goodyear and BFGoodrich. But a lot of foreign companies do have manufacturing plants in the US, like Continential, Yokohama, Bridgestone, and Pirelli.
    If you have the ability, you can check the plant code on the tire sidewall to see where it's made: https://wfirm.com/complete-list-of-t...t-plant-codes/
    But of course, its a bit more complicated than that given the nature of a global supply chain. Even if it's manufactured in the US, where the raw materials are sourced, machinerery and production parts, ongoing maintenance of parts in the prooduction line, will all play a part. Everything is going to get more expensive and you can bet that if foreign entities have to increase their prices by X percent to offset import fees, onshore companies will raise their prices by Y percent to futher pad profits margins.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
  39. #1239
    May 03 2010
    2012 TT Sold
    Maine
    I used this for removal. Drop the belly pan. You can see the T25 screws. I think there's 10-12 of them. of course disconnect the sensors.
    https://www.youtube.com/watch?v=JS6xACSBGmc
    2002 A4 1.8T - sold
  40. #1240
    Sep 05 2014
    Quote Originally Posted by A4Maine-iac View Post
    If I’m gonna pull the whole bumper, I might as well wait until I source a BO grille and replace both at the same time
    Ken
    2021 Q5e Prestige
    District Green
