Results 1 to 3 of 3
    Aug 27 2020
    Ruchmond
    Cvt to 5 speed coding help
    I have a 2002 a4 apr k04 stage 3 . It’s a cvt car and it’s the worst thing ever. I have all my parts for the swap and I own a mechanic shop. I need a step by step for the 3 modules that need recoding . I have a vag com cable from Ross tech with the full version. Any help would be great . Starting this process Friday!! Thanks in advance guys
    Veteran Member Three Rings Dr.B6Banter's Avatar
    Sep 26 2017
    B6 A4 1.8T, B8.5 SQ5
    NB, Canada
    https://www.audizine.com/forum/showt...nsmission-Swap
    That goes over all the coding you'd need to do on the ECU ABS module and cluster.
    B6 A4 1.8T Nottro 02X 6spd Conversion | GTRS | IE Forged Rods | Suspension/ Subframe Poly Bushings | 18z BBK Front & Back
    B8.5 SQ5 3.0t | JHM 207mm Crank Pulley | IE Dual Pulley Tune & ZF8 TCU Tune | CTS Test Pipes, Downpipes & HX | AWE Touring Exhaust
    Active Member Four Rings EuroxS4's Avatar
    Jan 24 2010
    Paramus,NJ USA
    Should only need to recode ecu,cluster and abs iirc.
    VW/Audi Immobilizer removal and immobilizer adapting solutions for any and all VAG Vehicles, Odometer matching, SKC/Pin retrieval services/ Component Protection/Module Coding/Diagnosis Services and repairs.RB4/RB8 Specialist cloning and repairs. Located in Northern NJ. For inquries pm for details or contact me via Whatsapp
    Ziddy Autowerks
