The measuring values are the actual volts measured from the knock sensor during each of the cylinder combustion events. Engine off values were 16.768v for me. After driving around some, idle is around 0.6-0.7v, except my cyl 2 is about double that. While cruising, I'll see 2v-7v, moves around which cylinder(s) is peaking. Apparently I didn't log any WOT pulls. Peak was in the 8s. But I've heard of people seeing values in the 10s and 20s.
There's a number of knock sensor related P032x P-codes. P0327 means it's seeing less than 0.7v when the engine rpm is over 1000 for at least a 0.5 second window.
Just log engine rpm, engine load norm, knock voltage for cyl 1-4, and coolant temp, and one other whatever you like (to keep it to 8 or less for maximum sample rate; make sure group uds is on, always for the ECM). See what you see.
Yes, it's the green plug under the backside of the intake manifold (where the 14-pin and the fuel injectors plugs are also). Apparently, if you put a resistance measurement on pins 1 and 2 of the knock sensor plug (ie, the plug to the sensor, not the wiring harness plug), it should read an open circuit, infinite resistance. If you read any resistance value, you replace it.
I wonder, if you leave the resistance measurement active and tap on the block near it, if you see resistance values pop up.
The torque of the bolt holding it to the block is important for it to function correctly. I wonder if it's loosened over time. Which would suck; don't you have to pull the coolant pump to get to it?
