Results 1 to 7 of 7
    Junior Member Two Rings Woob's Avatar
    Feb 20 2020
    Cardiff, Wales
    Comprehensive RS5 service intervals
    Hi all
    I'm trying to get a digital list of all the service items needed for an RS5 and wondered if anyone can confirm or deny what information I’ve gathered. I can’t seem to locate any service intervals in my paperwork. I definitely don’t want to miss anything as I know these cars are costly to repair and require strict maintenance. Units are miles
    I couldn’t find any official information on coil packs, carbon clean, brake lines etc.
    Engine oil - 10,000 (though some recommend every 5,000)
    Air filter - 60,000
    Interior filter 2 years or 20,000
    Brake fluid - 2 years
    Spark plugs - 6 years or 60,000
    Final front drive - 20,000
    Dual clutch gearbox S-tronic ATF filter and fluid - 40,000
    Final rear drive ATF fluid and final drive oil - 40,000
    Panoramic roof mechanism check, clean and grease the slides - 2 years or 40,000
    Wiper blades - 2 years or 20,000
    Air conditioning evacuate, de-odour, renew refrigerant and oil and re-pressurise - 3 years
    Engine coolant drain and renew - 6 years
    DRC evacuate oil, renew and re-pressurise - 3 years
    Tyres and alignment - 6 years or 3mm
    Car battery - 6 years
    Fuel filter - 6 years
    Front brake discs - 32.4mm
    Front pads - 10mm (plus backing plate)
    Rear discs – 20mm
    Rear pads – 7mm (plus backing plate)
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    There are no official service/replacement intervals for coil packs and brake lines.
    Carbon clean is recommended at 80000-100000Km. But your driving style and the type of driving you do will impact this.
    Sent from my Pixel 4 XL using Tapatalk
    Feb 20 2020
    Cardiff, Wales
    Ah thanks
    Does the rest all seems reasonable?
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    Great info.
    Sent from my motorola razr (2020) using Tapatalk
    Active Member One Ring CaptD's Avatar
    Jul 17 2020
    Portland OR
    https://www.audiusa.com/content/dam/...RIL%202018.pdf
    HTH.
    Quote Originally Posted by Woob View Post
    Hi all
    Air filter - 60,000
    Rear discs – 20mm
    Veteran Member Four Rings BuyTheWarranty's Avatar
    Jun 11 2014
    2017 Mythos Black RS7 Performance Black Optics & Titanium Exhaust
    Great info, helpful.
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    I recently did all four corners for brakes, rotors and pads in the rear, pads up front. Note the CCB minimum thickness is around 9mm with backing plate. My pad wear indicator light came on at about 12.5mm and I have to say, if I'd waited any longer, I would have ruined the CCB rotors. So even measuring with calipers, it seemed fine but was very close to not being fine. I'd say absolutely change them at 12.5mm (includes backing plate) or immediately when your pad warning light comes on.
    For the rest, I'd do plugs every 35K, coils at 60K and consider new fuel injectors at that point, especially if you're having a carbon clean done. Definitely change the oil every 5,000 miles.
    I'd half the air filters too, every 35K for those as well.
    I advocate for changing both the MTF and ATF on the transmission every 20K miles but that can get steep. I'm sitting here draining the MTF side now and opted to forego the ATF side. I'm also running the RMR transmission cooler and a bit more fluid. A bit more peace of mind.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
