Results 1 to 4 of 4
    Established Member Two Rings bradthebold's Avatar
    Jan 10 2012
    Spokane, WA
    Oil screen, check valve, PCV parts list
    Is there a list of everything you should do when going this far in? The main R&R thread only lists 5 parts and 2 clips. Ideally for an RS7 or noted part differences. I'm planning on:
    Removing the oil screen
    Replacing the check valve
    PCV
    Piston Cooling Nozzle Control Valve N522
    Turbo Oil return lines (?)
    Turbo oil/coolant line o-rings
    All necessary gaskets (?)
    Oil separator/PCV - 079103542E
    Check Valve - 079103175C
    Piston Cooling Nozzle Valve - 079-115-243-C
    Valley cover gasket - 079103161Q
    Throttle body seal - 079145818
    Passnger intercooler gasket - 079129717K
    Drivers intercooler gasket - 079129717J
    2 x Bypass valve seal - 079145417B
    2 x Clamp - N90489801
    Clamp - N90409501
    1 x WHT001011 from JHM kit, water line seal, not sure where
    2 x Turbo Coolant Line O-Ring Kit - JHM
    2 x Turbo oil supply line o-ring at turbo - N91056801
    2 x Turbo oil supply line o-ring at engine - N90303801
    Right side turbo oil return hose - 079145743A
    Left side turbo oil return hose - 079145742C
    Clamp - N90409501
    G13 coolant
    Do I need any more gaskets or o-rings? I'm not sure what I need for coolant related o-rings; the JHM kit is just for the turbo side it looks like.
    '01 Stage 3 S4 - sold
    '13 Stage 2 Q5 3.0
    '14 RS7 Stage 2
    Mar 30 2018
    long island
    that seems to be a thorough list.
    he only thing id suggest is replace the clamps with worm gear clamps. just make sure to use quality ones that wont loosen up over time.
    2017 RS7 | Daytona gray pearl | DS1 | Mike's downpipes (catted) | Milltek non-res exhaust | SRM intake | AK racing lowering module | VS forged VS16 wheels | JHM turbo filter relocation | Blackout badges | Color matched side reflectors | Cquartz ceramic coating | 20% tint |
    Jan 10 2012
    Spokane, WA
    I called the dealer and he told me the piston cooling nozzle valve part number is 079-115-243-C, which ECS calls the Pressure Restriction Valve
    '13 Stage 2 Q5 3.0
    '14 RS7 Stage 2
    Veteran Member Four Rings 09S5's Avatar
    Dec 04 2015
    A8L, 4X4, c6 VETTE, New CTS-V
    TN
    Thanks for those part numbers, Sir.
