Results 1 to 7 of 7
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    Possible rear speaker upgrades for B8 B&O systems
    I was recently made aware that the rear speakers for the B&O system in the B8/8.5 A4/S4/Avant, A5/S5/RS5, and Q5/QS5 are the same speakers used in the front dashboard outer locations. I have verified this using the parts lists on this website (select your vehicle and the model year and click on the "Group 0 accessories, infotainment" link in the displayed list; scroll down towards the bottom and you'll see the breakdown for the speakers). The front dash speakers have been successfully upgraded using the Dayton Audio RS75-4 speakers from Parts Express so I see no reason why the rear speakers cannot be upgraded in the same way. I do not own an Audi with a B&O system so I have no way to verify that they will fit, but I should be able to check my 2014 B8.5 A4 for fitment even though it's a non-B&O system. I would assume that the speaker mounting locations should be there regardless of which audio system is installed. I've just got too much on my plate right now to start pulling my car apart to test the speakers for fitment.
    One thing to keep in mind that the Dayton Audio speakers are full range speakers that are configured with a 10 uf capacitor that acts as a 4kHz high pass filter. This allows them to reproduce all frequencies above 4kHz. The center dash speaker is a tweeter and the outer dash speakers are midrange speakers that also have the 10 uf capacitor installed. I assume that the midrange drivers naturally roll off at a higher frequency and the tweeter has a natural rise at the same crossover point so they blend together without the need for an external crossover. The Daytons essentially take the place of both speakers in all three dash locations so they act as both midrange drivers and tweeters. Since the rear shelf speakers are the same as the midrange drivers and there is no tweeter in the rear location other than the doors, I would expect the sound level from the rear to increase since now you will be experiencing much higher frequencies coming from the rear than before.
    Junior Member Two Rings
    Oct 14 2019
    Burlington, KS
    Since I was the one that raised the question, I would be willing to be a test subject. I'll shoot you a pm.
    Ryan
    Oct 14 2019
    Burlington, KS
    Got them installed. Fit without issue. The rear deck speakers don't do as much work as the rear side speakers, but it is nice having matching front and rear speakers. I am glad I made the upgrade. I would do it again. I would recommend doing all 5 speakers if I was doing the upgrade. If I couldn't afford that, I would do the 3 in the dash first.
    Sep 03 2014
    Ellicott City, MD
    If anyone is interested in the upgrade kits you will find the details and pricing info in this thread:
    https://www.audiworld.com/forums/aud.../#post25486534
    Sep 03 2014
    Ellicott City, MD
    Kits are still available. Check the link in the first post for the latest info and price list.
    Junior Member One Ring
    Oct 07 2015
    McDonough, GA
    Quote Originally Posted by captain_video View Post
    On the rear 3" speakers, do you just pop off the grilles like you do on the front dash?
    Sep 03 2014
    Ellicott City, MD
    The rear grills can be a bit trickier to remove as they are pretty tight and easily damaged if you apply too much force. They are mounted similar to the front outer grills in that they have small tabs at the rear that engage with slots in the rear deck cover. You'll need to carefully pry up along the front edge a little at a time to disengage the front clips. I believe the speakers are mounted exactly the same as the front dash speakers. I don't have a B&O setup to test the installation on, but someone volunteered to test it for me some time ago and it clearly works. I have never received any feedback about the rear speakers being difficult to install so I can only assume they are relatively easy to get to once the grills have been removed. There is definitely more room to work with on the rear deck compared to the cramped space for the outer dash speakers.
