Results 1 to 11 of 11
Thread: Oil Level
    Sep 06 2020
    Fort Lee NJ
    Oil Level
    So there is NO dipstick correct?? Checking oil level on the dash is saying 'Oil level is not available" or something like that. How do I check the level. Just did my RMS and drained oil and added 4 quarts or so when I completed the job. It probably takes more but would like to know where I'm at. Any thoughts?
    Well just got some info....does the engine have to be warmed up and the hood closed in order to see the oil level?? Thanks V
    Established Member Two Rings colorado.a4's Avatar
    Dec 04 2018
    Correct most audi engines don’t have dipsticks. you can purchase “universal dipsticks” on amazon and set to the marks indicated for the most exact measurement. depending on your engine, you’ll have different levels to read. I know CAEB takes 4.9 qt + oil filter top off and CPMB takes 4.8 qt + oil filter top off.
    IG @Colorado.a4
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Come on dude search unless u wanna get flamed.... It takes about 4.9qt
    06J 115 611 E
    The car must have been on for a certain level of time i think minimum of 2 minutes and be fully up to temp and off I think its been awhile since used it.
    Sent from my SM-G960U using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Veteran Member Three Rings IHave2Turbos's Avatar
    Aug 17 2015
    driver door open, oil level screen on mmi, ignition on. wait a minute and gauge will resolve
    C7.5 S6
    Mods : OEM+ Stage3 / DS1 ECU / SRM TCU / CTS HX
    B8 A4
    Mods : HPA\\\ K04 / Manifold / HFC / Tune | CTS FMIC / DP | CR-15 | ECS Inserts
    Retrofits: MMI3G+ / RVC / AHH / Color DIS / Cruise Stalks
    Sep 06 2020
    Fort Lee NJ
    cool thanks...v
    Feb 15 2016
    Cambridge,Ontario
    Did you read your owners manual on how to check the oil..?
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Established Member Two Rings Romuloux's Avatar
    Jul 23 2014
    B8 A4 Avant, B5 S4, 1993 Subaru Impreza
    Spokane, WA
    So I just did my RMS and I discovered something new.
    With the hood open, driver side door open, and the key pushed on (no start, just turn the ignition on) I got an oil reading from the small screen in the gauge cluster. This was instant and was not using the oil level check in the MMI.
    I was actually testing something entirely different, but noticed that I got the oil reading on my gauge cluster. This was on a 2009 A4 Avant Quattro.
    Also, the shop I took it in for timing service managed to get a dipstick for my car. I will update with the PN when I pick it up today.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Romuloux View Post
    would be good to know if your dipstick matches your read out too.
    BTW Mine doesnt do that .. i just get the dinging and a message" remove key before leaving vehicle Battery is discharging" if the door is closed I get the picture of the hood in red indicating it is open. (2014 8.5 )
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    https://www.audiworld.com/forums/a6-...creen-2892869/
    I have never seen the event in my '09.
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by Smac770 View Post
    me neither .. but i would love to have a way to check my oil cold.. i have always done it this way and i am more comfortable with it.
    1976 Yamaha XS 360
    Jul 16 2018
    Atlanta
    SSP 438, page 15 - The electronic oil level indicator
    So opening the hood triggers the dash insert (aka DIS) "good" display. I assume the other displays are always on when the associated problem icon is on. It takes about 6-10 seconds for it to pop up, and then it doesn't stay on particularly long. I assume it's running the same calibration when you turn on car->oil level with the car off and oil warm.
    My engine is warm from just getting dinner. So that it generates a reading after closing the hood (which is what normally makes the MMI display reset to needing to redo its measurement) is not too surprising. But will this accomplish anything for you when the engine is cold?
    I find it sad that Audi needed 46 pages to explain to wrench monkeys how to tell the car that they had changed the oil.
