I have a feeling there is a intermittent failure in the IP module in the passenger footwell and that's my culprit. I wonder if turning off lane departure in coding would stop this code, but allow me to retain ACC. Last time I had my maps updated at the dealer, my codings were reset, but they somehow didn't get lane departure enabled, yet I seem to recall the car didn't care and ACC worked regardless. I could also be misremembering as it was years ago.
Anyone know what I should be chasing or am I just going to replace the controller under the carpet? Is it there a TSB talking about this and maybe a firmware update the dealer can do? I saw a similar TSB for the Euro version that has firmware updates for the module.
Code:
Address 8E: Image Processing Labels: 4H0-907-107-V2.clb Control Module Part Number: 4G0 907 107 E HW: 4H0 907 107 Component and/or Version: BV-SG H31 0041 Software Coding: 04C198180111 Work Shop Code: WSC 45876 528 143098 ASAM Dataset: EV_BC7 001001 (AU57) ROD: EV_BC7.rod 1 Fault Found: 0003 - Data Set Implausible B2012 00 [008] - - [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 72 Mileage: 134932 km Date: 2020.08.27 Time: 22:01:56 Outside air temperature: 28.0 °C Voltage terminal 15: 13.1 V Control Module temperature: 0.0 °C
