Results 1 to 7 of 7
    Jun 15 2015
    Long Island, NY
    19s on RS5 Sportback
    I'm looking for feedback from those that have moved from 20s to 19s on their RS5 (specifically the Sportback).
    Does the ride quality get better? My wife complains a lot about the harshness of the car (even in comfort mode) and I'm wondering if moving to 19s would make a difference? If so... how?
    NYC roads suck....
    2019 Navarro Blue RS5 Sportback
    Gone but not forgotten:
    2015 Sepang Blue S4
    2001 Nogaro Blue S4
    Established Member Two Rings sthulin's Avatar
    Nov 11 2019
    Metrowest, MA, USA
    I run 19s as winter tires and i do find them to be a bit more comfy, but not that much of a difference. I think the type of tire you run will make a big difference in addition to having a larger sidewall.
    2019 RS5 Sportback - Daytona Grey - Blackline Taillights, Milltek Exhaust, 034 Strut Brace, Passenger Sport Gauges
    Veteran Member Four Rings 303 Spartan's Avatar
    Aug 16 2016
    F87 M2 Comp
    Colorado
    When I bought my RS5 in March, I took the 265/35/19 snow tires from the M3 I traded in and threw them on some cheap 19" wheels to get me through the last few weeks of winter.
    Overall, I wouldn't say the ride quality changed much, even with the slightly taller tire. However, if you're going to go with 19's I recommend using a 275/35/19 tire. It will be closer to the OEM wheel/tire diameter and will give you a taller sidewall for some extra ride cushion.
    This year I'm transitioning my OEM 20's over to winter duty with some 275/30/20 snow tires. Personally, I think 20" wheels suit this car much better and considering that I have to keep my winter setup on for upwards of 6 months, I prefer a setup that's visually appealing. Even if it means sacrificing some snow performance, when compared to a 19" wheel with a taller/skinner snow tire.
    Anyway, here's what the car looked like on 19's with 265/35/19, in case it helps:
    Another option is to get a bigger tire on a 20" wheel. My new Summer setup is a 20" wheel with a 285/30/20 tire. the 285's provide a 6mm increase in overall diameter, providing some extra cushion. But ride comfort feels about the same as OEM, if I'm being honest.
    Current:
    21' GMC 1500 Denali
    Gone:
    B9 RS5 Sportback / APR+
    F80 ///M3 | 6MT
    B8.5 S4 / EPL Dual Pulley Stage 2
    Jun 15 2015
    Long Island, NY
    Quote Originally Posted by 303 Spartan View Post
    Thank you! This is helpful context and I do agree the 20s suit this car better. I was considering downgrade because I was planning to us the RS5 more when my lease is up on my daily. I was going to try and save a few bucks on a car payment while things get back to normal. But I guess I should just look for a replacement car for my daily.
    2015 Sepang Blue S4
    2001 Nogaro Blue S4
    Jun 15 2015
    Long Island, NY
    Quote Originally Posted by sthulin View Post
    Thanks, I didn't think it would make a huge difference but figured it was worth the ask.
    2015 Sepang Blue S4
    2001 Nogaro Blue S4
    Mar 26 2010
    US
    Quote Originally Posted by SepangS4me View Post
    I focused on ride quality & pothole survivability. I hit a pothole with only 500 miles on the new car with original 275/30R20 tires on 20x9 ET22 wheels. The tire went flat 8-10 seconds, and the cost to get replaced was $336.
    I switched to 19x9 ET20 wheels and 245/40R19 tires, since 40 series tires (98mm sidewall) have more cushion than 30 series tire (88mm sidewall) . which has a calculated +0.8% speedometer error. Wife is OK with the ride in Comfort mode.
    https://www.wheel-size.com/calc/?whe...cl=50mm&sr=0mm
    I could have pursued a 18" wheel/tire combination, since BBS does a make a wheel that fits the RS5 front brakes (according to BBS rep.): BBS SR Satin Grey Wheel 18x9 5x112 21mm SR033SG and 265/40R18 tires (-0.5% speedometer error).
    Tire pressure also affects the ride. I use the light load values.
    BMW M3 Competition X-drive
    Veteran Member Three Rings Andy_FL's Avatar
    Mar 01 2004
    South Florida
    Quote Originally Posted by wwhan View Post
    ^^THIS^^
    I was riding around at around 32-33psi all around on my black optics wheels (20") ever since I picked up the car a few months ago. I had 18's on my prior car and thought to myself "Wow these wheels don't ride as 'bad' as I thought they would." Then I finally got around to setting the TPMS and went to 40psi all around - man what a difference! THIS is how I expected 20" wheels to ride (that every expansion joint is a little jolt to the flank!). So yeah, I would adjust your pressure a bit and you may get more of a difference than if you go to a smaller wheel. GL.
