Quote Originally Posted by Kevin quattro View Post
Firstly, please do it. You'll fall in love with the platform. Im on my second mqb car. They drive so well and you can easily get awesome power out of them.
As for mods to do, first do a cold air intake, a stage 1 tune, and lowering springs.
I would do EMD lowering springs. They seem seem to be the most popular for our platform. Maintain great ride quality while getting that lowered look and improved handling/performance. They're a linear spring like stock whereas most are progressive rate and are very stiff as a result. I live in michigan so I'm biased. Worst roads in the US.
As far as tuners go I would say Cobb/EQT is your best bet. You can start small and change the tune as you like. IE is another good one.
For cai 034 would be my recommendation. Im replacing my apr intake with theirs.
You mentioned a cat-back. I would recommend the other things long before doing that, because you won't gain any real performance from it, but that's a matter of taste too. If you just want a more aggressive sound that'll do it. I have a scorpion resonated cat-back and I love it. Its not ricer but it sounds aggressive af. Nice deep rumble. If you do get a cat-back make sure it's resonated if you want it to be "tasteful".
Let us know if you pull the trigger. I promise you won't regret it!
You can get the same results as a cai for less than half the cost of new with a turbo inlet, silicone hose, drop in filter, air box snow screen delete, and the air duct mod that opens up the driver’s side.
Turbo inlets pop up in the classifieds pretty regularly for less than $100. I bought my silicone hose new on sale for $70. With the money you save there, I would recommend an aftermarket diverter valve, or an OBDeleven, if you don’t have one.
The diverter valve is tricky since there’s not a lot of room in there. My set up is a dv+ from GFB, inlet from CTS, and a silicone hose from DFG. It all goes together with no trimming or grinding. And doing them all at the same time will make it easier to get to the lower bolt on the dv+.
