Results 1 to 8 of 8
Hybrid View
    Aug 23 2020
    Pennsylvania USA
    Help!! Boost issue??
    Yesterday the car ran fine. Today I started it up to go to the gas station noticed nothing different. As I pulled out and started to go down the road I noticed that the car was not building boost. So I gave it some throttle and the Turbo spools and build boost when it wants but Cuts back out. I don't know what's going on the car has power when it wants to and other times it's no boost. And I went over the car with some carb cleaner to try and find a vacuum leak but found nothing I need help it's a 2002 C5 A6 2.7 t
    Aug 23 2020
    Pennsylvania USA
    I also have a boost gauge usually I run around 10 PSI boost and 20 vacuum. But I noticed today that the car would spike 215 back down to 10 and bounce around and also the vacuum is now at 10 and not 20
    - - - Updated - - -
    Veteran Member Four Rings ShelbyM3's Avatar
    Feb 05 2007
    Alpaca 2002 Allroad 2.7T Auto 3rd Row, Avus Silver Oxblood 2003 S8, Silver Metallic 2004 Allroad V8
    Portland, OR
    Sounds like you have a boost leak somewhere. Throttle body boot is a common source. It’ll tear on the bottom side where you can’t see.
    Do you have a way to check for CELs?
    Aug 23 2020
    Pennsylvania USA
    I do not
    Senior Member Three Rings C5S6's Avatar
    Oct 04 2008
    '02 S6 Avant, '03 A6 Sedan
    CO mountains
    I had a breather fitting/hose pop off the back of the intake manifold twice. After the 2nd time I secured it with a zip tie. Car behaved as you describe both times.
    -TJ
    2002 S6 MT6
    2003 A6 2.7t MT6
    Aug 23 2020
    Pennsylvania USA
    Had it read via vcds. Codes were for a secondary air injection and something about a boost valve?
    Apr 30 2020
    US
    Had a similar issue with my 14 S6, I had a bad catalytic converter,
    Sent from my SM-N986U using Audizine Forum mobile app
    Feb 05 2007
    Portland, OR
    Secondary air is common and will require attention, but not crucial to performance.
    Boost valve could maybe be N75. That controls your wastegates.
