Results 1 to 17 of 17
    Jan 23 2020
    UK, Sunderland
    Water Methanol Injection?
    So I've got a few weeks untill the car is in for mapping, thought I'd use the time wisely, fresh service, new plugs etc, I'm also wanting to fit WMI, because why not!
    Going to go with the AEM v2 kit, still debating whether to go for a boot install or front end, scuttle, behind bumper etc!
    What way are people mounting the nozzle? Bung in a charge pipe, or throttle body spacer if there is a such a thing for the B9?
    Any recommendations on charge pipes with a pre welded bung in for the nozzle? Rather I'd have everything to hand first before doing the install!
    Veteran Member Three Rings nicotino15's Avatar
    Jul 24 2011
    2016 Q5 3.0T
    DFW, TX
    Due to the layout of the charge pipes, I personally would not use WMI for extra fueling. There have been a few failures using WMI on cars running hybrid turbos and high boost, and you can't expect a good enough mix hitting each individual cylinder with a charge pipe setup.
    If you are just looking for lower temps, then CTS turbo makes an aluminum charge pipe with 2 WMI bungs drilled into the middle of the pipe which I think is a really nice spot to lower IAT's with water injection, and I'm considering picking it up. Other options are BMS makes a throttle plate adapter which I have and use, but I don't think is very ideal due to it's proximity to the map sensors, and Integrated Engineering makes an intercooler with a bung on the outlet pipe. Alternatively you could someone to weld in a bung on either side of the intercooler, or possibly in the turbo housing itself.
    2019 Glacier White w/ Magnum Red interior - EPL E40, JB4, APR Intercooler, Red Star HJS 200 cell, ECS intake
    Jan 23 2020
    UK, Sunderland
    Perfect, just what I needed to know! 👌
    I'm using it purely for the cooling, I'd have a hard time trusting it if using it for supplementing fuel! 😂
    So in your opinion changing the charge pipe out with some bungs in is a better option than the TB spacer?
    Senior Member Four Rings
    Apr 26 2019
    United Kingdom
    Yes, 100%.
    Jan 23 2020
    UK, Sunderland
    Quote Originally Posted by Kondax View Post
    Yes, 100%.
    Champion, I was wanting to change out the stock charge pipes anyways, just couldn't really justify the cost against gains!
    Pretty much decided on installing the tank and pump in the boot, easier to install and easier to maintain! Would love to see other people's installs!
    Apr 26 2019
    United Kingdom
    For what it's worth, Injen charge pipes include a bung post FMIC - https://www.mlperformance.co.uk/prod...er-pipes-s4-s5.
    There's probably others too, I just know of this as I use the Injen pipes.
    Feb 27 2019
    Los Angeles, CA
    There is also the new CTS charge pipes.
    Established Member Two Rings steel234's Avatar
    Jun 07 2020
    GER/FRA
    If you will buy Wagner FMIC there is aluminium charge pipe from IC to trottle included.
    8W00 CWGD 8HP LZ7S || @EPL @Wagner IC @AWE AirGate Intake @H&R Monotube Coil-overs @Eibach Anti-Roll Kit @Motec MCT11 @PureTurbos ||
    Established Member Two Rings 18AudiS4's Avatar
    Jun 26 2019
    2017 Jeep Grand Cherokee, 2016 Ford F-250, 2008 Jeep Grand Cherokee
    Hagerstown, MD
    I would NOT recommend WMI pre intercooler I have dual nozzle TB direct and running 600whp effective. The problem you’re going to run into is you’ll have water built up in your intercooler.
    2018 Audi S4 (b9) Pearl Grey
    Current Mods:
    AWE CarbonFiber Cold Air Intake
    AWE Intercooler
    BMS JB4 W/ Bluetooth Kit and BCM
    SRM GTX GEN2 Hybrid Turbo
    BMS Meth kit 2 Gallon Tank BM7 & BM10
    034 Stiffening Springs
    034 end links
    034 Sway Bars
    034 Engine mount
    Forge motor sports Catch Can
    Eurocode turbo inlet
    Miltek high flow downpipe
    Current Mods:
    AWE CarbonFiber Cold Air Intake and Intercooler
    EPL Stage 2 93 octane ECU tune
    BMS JB4 Map 6 29 PSI W/ Bluetooth Kit and BCM
    Eurocode/SRM GTX GEN2 Hybrid Turbo with turbo inlet
    034 Stiffening Springs, end links, Sway Bars, Engine mount
    Fastest 1/4 mile Time. 11.0 @ 125.3 with stacked EPL 93 octane and JB4 Map 6
    Jan 23 2020
    UK, Sunderland
    Quote Originally Posted by 18AudiS4 View Post
    Current Mods:
    AWE Intercooler
    034 end links
    034 Sway Bars
    034 Engine mount
    Oh yeah I wouldn't dream of running the nozzle pre intercooler, the charge pipes with the bungs in is between the cooler and TB, just a shame there so damn expensive! 😂
    Mar 20 2020
    New Jersey
    I have Wagner FMIC + Charge Pipes.
    There is a sensor in the bung, where would I move that sensor to if I installed WMI kit to inject in my charge pipe?
    Sent from my SM-N975U using Audizine Forum mobile app
    Apr 26 2019
    United Kingdom
    Quote Originally Posted by East_Coast_S4 View Post
    You would not move the sensor.
    For the Injen pipes there is a separate bung for a meth nozzle.
    Mar 20 2020
    New Jersey
    I have followed and seen many of your posts - The record EPL times are all mine and I am debating going WMI. - Insurance and cooler runnings system all around is what I want more than anything, If it provides a higher ceiling should I go with a Hybrid Turbo so be it - Where do you think I should tap in at? I would prefer a purchasable solution, and one that doesn't require JB4 to monitor
    Apr 26 2019
    United Kingdom
    My personal recommendation is to not build your system around your WMI integration (like most people on this platform), but rather use it purely as a cooling solution. I have seen too many of these cars run into engine problems due to WMI on big turbos. I would not tune one of these cars to depend on WMI.
    I would recommend going with a solution as appears in this video: https://www.youtube.com/watch?v=f6hMnBy6XKc. You won't get as much power out as compared to tuning specifically from the WMI, but you will prevent the risk of your engine blowing / pistons melting if your meth runs dry or some other issue occurs.
    Mar 20 2020
    New Jersey
    Basically my thoughts exactly, btw have you seen his latest video?
    The RS5 snapped the front differential gears in half on launch.
    He had to get a whole 2nd ZF trans to fix
    Apr 26 2019
    United Kingdom
    I did yeah.
    I highly, highly believe it was a fault with his TCU tune. There is no reason those gears should have broken - plenty of S4/S5s on much more power having no issues on prepped tracks.
    Looks like his tuner slapped together an ECU and TCU tune in an hour or so. Fairly certain his TCU tune enabled constant AMAX.
    I'd be wary of using them.
    Junior Member One Ring
    Mar 24 2024
    Florida
    Hello everyone, I've been reading about WMI and I want to install it on my b9s4 . Are there any videos or other forums or threads that explain how this process works and what the best way to install and go about this process? Do the kits come complete or do you have to buy everything separate ? How does the system know when to spray and how do you adjust how much it sprays?
