I have a 07 A4 Quattro tiptronic with 115k miles and I recently changed the water pump +belt, cam follower, oil + filter, coolant flange + hoses + coolant temp sensor, thermostat, and oil filter housing. Today I gave it a drive to my bank about 3mins from my house and went I got back in to turn it on, it cranks and powers on but did not stay turned over. Waited a bit and it got on so I drove home and left it for a day come back to find it’s leaking coolant and now I have the codes P3081 and codes U0002, U0101. Following all this the wiring I believe for the connector that plugs into the CTS frayed out as it would throw me a high voltage circuit code, with the wires exposed to the heat it frayed out. Because of this the radiator fans will constantly spin and although the coolant temp does not overheat on the gauge, it does bounce around on the code side of it.I been meaning to change it but could not figure out the part number, any help is greatly appreciated. As I was lifting the car into ramps as well, it appears it has entered limp mode as I was stuck in 3rd gear getting up.
