Results 1 to 14 of 14
    Veteran Member Three Rings S3_Miles's Avatar
    Jun 13 2018
    Paso Robles CA
    Wheel Spacers < 8mm: What do you use and would you buy again?
    I have a set of H&R 5mm spacers I probably would not buy again. They do not tightly seat on the 57.1mm hub.
    Anyone "swear by" their narrow spacers and have had good luck? Anything from 8mm down to 5mm
    May 08 2020
    2015 Golf R DSG, 2015 Golf TDI 6-speed.
    Purcellville VA
    You might want to check with ECS Tuning, as they have good quality spacers. I am using one of their 30mm spacers for supporting spare tire use which I put together since our 2019 Audi RS 3 came with out a spare tire! I've also used other size spacers from them and they've always fit perfectly.
    Dec 25 2004
    Earth
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by Rod Paine View Post
    Thanks Rod, and good info about the spare (ive been looking at RS3s) - I have ECS on the rear, and they do work great because they have a flange (they are 10mm), but I used ECS on the front and had shimmy. Then I ordered H&R and have an issue as well. Its really an issue for the narrower spacers that are without a flange.
    - - - Updated - - -
    Quote Originally Posted by MikTip View Post
    Thanks for the tip! ill give them a look
    UPDATE: Looks like the narrow ones they do are not different from others in the market, and the overall cost with shipping is quite a bit more. If they were unique, I would purchase. They look quality
    Veteran Member Four Rings Gberg888's Avatar
    Jun 16 2011
    996tt
    MA
    None of the less than 8mm spacers are going to work well. They do not allow your wheel to seat properly on the hub. So you are going to either get real lucky centering your wheels or they wont be centered and youll get vibrations at speed. I had this happen to me and I have my friend make me the following which is in a whole thread:
    I had no issue because the wheel bore was bigger than the hub on the S3 cause the rims I mounted were from my old POS B8 S4. If you have the proper size wheel hub you are sol. But also, on a side note, you should buy the proper rims with the proper offset or make sure its so far off you can use 10+mm spacers.
    https://www.audizine.com/forum/showt...bcentric-rings
    Garage:
    04 996TT X50, 06 Boxster S, 88 911 Targa, 16 S3
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by Gberg888 View Post
    I see what you are saying and remember that thread. My issue is I have 57.1 wheels too, and want to run a min of 5mm, max of 8 (truly a 7mm)...so 57.1 wheel to 57.1 hub....but because of the spacer it pushes out beyond the effective edge of the hub. The wheels you use are 66.6 right? Unless I missed something. Ill re-read the whole thread
    Jun 16 2011
    996tt
    MA
    Quote Originally Posted by S3_Miles View Post
    Correct, my wheels are 66.1 bore, my hub is 57.1.
    Garage:
    Jun 13 2018
    Paso Robles CA
    Ok so, I ended up ordering these: https://www.ecstuning.com/b-black-fo...r/sp204gb~bfi/
    They have a conical set up and since my Neuspeed wheels ALSO have a conical chamfer, we will see how this works out.
    Thanks for the input
    Jul 12 2009
    Interested to see how they work for you, also which wheels? I'm running some generic 5mm spacers that seem to add just a bit of vibration at speed. I had previously tried some 034 hubcentric spacers but they wouldn't fit my Neuspeed RSe12 wheels. The portion that inserted into the wheel left a small gap and I couldn't tighten the wheel.
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by R1ce View Post
    Interested to see how they work for you, also which wheels? I'm running some generic 5mm spacers that seem to add just a bit of vibration at speed. I had previously tried some 034 hubcentric spacers but they wouldn't fit my Neuspeed RS12 wheels. The portion that inserted into the wheel left a small gap and I couldn't tighten the wheel.
    Ok will do. RSe102s
    Veteran Member Four Rings Grey3's Avatar
    Mar 14 2018
    B8 S4, mk6 Jetta, 2 mustangs
    Sherrills Ford NC
    Can u not just go up 2 mm to a 10 mm? Seems like the simple option, u less your fitment is extremely tight
    Senior Member Two Rings sj9ninety's Avatar
    Nov 03 2018
    2022 M240i
    Northern Virginia
    Any update on the BFI spacers? They look like a good option for someone who wants 8mm and cant fit a 10mm.
    Jun 13 2018
    Paso Robles CA
    Quote Originally Posted by sj9ninety View Post
    Well I got them... and the chamfer on my Neuspeeds is not deep enough. These bfi are truly for OEM.
    I didn't even have to mount. I held the spacer to the back of the wheel.
    I may just go to a 10. It may have a tiny bit of poke but worth it for no wobbles
    Nov 03 2018
    2022 M240i
    Northern Virginia
    Yeah I run the ECS 10mm spacers in the rear and it’s flush fitment. 19x8.5 et45, with the spacer its effectively et35. Absolutely perfect fitment.
