Results 1 to 40 of 62
    Feb 23 2013
    B5/S4,MkI Scirocco, Rabbit Truck, allroad, mkV Jetta, T1 Touareg V8
    KC, MO
    2.0T FSI Tiptronic to Manual Pilot Bearing Adapter
    -Sourced a replacement engine from an automatic for your manual car only to find the crank is different?
    -Swaping your Tiptronic out for a 6 speed and need to figure out what to do about the pilot bearing?
    ---This adapter solves both these issues. Installing this converts your tiptronic crankshaft to the manual crank geometry.
    No machining, grinding, or material removal required. Pull the torque converter pilot bushing and press this in place. No more difficult than replacing a regular pilot bearing.New OEM pilot bearing is already installed.
    Installation instructions available upon request. If you are unsure how to remove the old torque convertor bushing from the crankshaft, please let me know. I can provide you with a simple tool to extract it for only $8 when you purchase the adapter.
    FAQ
    • What transmissions will this work with? 01E, 02A, 02X, 01X... if it came in a B5/B6/B7 then this fits.
    • Do I have to machine my crank for this to fit? No, the crank does not need have any material removed
    • What bearing does this use? This uses the OE bearing part# 056-105-313c.
    • Do you sell a bushing to convert a manual style crank to an automatic? No.
    • Does this work on my VW engine? The only VW application is Passats 1.8t’s that we’re mated to Tiptronic
    Click image for larger version.
    $87.50 shipped in the US
    Contact Chris ----> [email protected]
    Feb 23 2013
    KC, MO
    Bump
    Senior Member Two Rings Krmass25's Avatar
    Aug 18 2013
    AMERICA
    Did you make this or buy it?
    Feb 23 2013
    KC, MO
    The design is mine. I personally did all the prototype machine work to prove out the product and lock in the tolerances. The production versions are machined on a CNC lathe.
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TTT
    Senior Member Three Rings lumberwood's Avatar
    Apr 06 2016
    Hamilton, ON
    What. This is sick.
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    Ttt
    Feb 23 2013
    KC, MO
    Bump
    Sep 21 2010
    91 GTI
    Asheville, NC
    Bump for a great part. I bought one from you a couple of years ago or so for a swap. It worked great. I often recommend it on the forums.
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    Bump
    Junior Member One Ring
    Jun 29 2020
    2007 RS4
    Elkton, VA
    Hey man, would love to buy one of these, let me know how to get the ball rolling.
    Thanks
    Feb 23 2013
    KC, MO
    Quote Originally Posted by Tsdfab View Post
    Thanks
    PM sent
    Veteran Member Four Rings jamerican1's Avatar
    Nov 15 2009
    2008 A4 S-Line Titanium TQM, 2000 A4 1.8tqm, 1993 Audi 90S(sold)
    VA
    I need one.
    Unf*ckwithable
    Feb 23 2013
    KC, MO
    Quote Originally Posted by jamerican1 View Post
    I need one.
    My contact e-mail is in the first post.
    Nov 15 2009
    VA
    Email sent
    Unf*ckwithable
    Feb 23 2013
    KC, MO
    Bump
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    up
    Veteran Member Three Rings deusilan's Avatar
    Aug 17 2012
    '89 E30 325i; 2011 Police Interceptor
    Stinky Island, NY
    So just to be clear, if I have a 6-speed manual will this bolt an AWD automatic engine to my tranny?
    Currently: 2005.5 A4 2.0 (Red)TQ 6-spd, WORK IN PROGRESS 2011 Police Interceptor
    Previously: E30 325i, donated for track purposes
    Feb 23 2013
    KC, MO
    Quote Originally Posted by deusilan View Post
    If the engine was originally mated to a ZF 5HP19 (tiptronic) then this will allow you to convert that engines crankshaft to a manual (pilot bearing) configuration. Yes, it works with the 5 and 6 speed Audi AWD and transaxles
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    TTT
    Veteran Member Three Rings quattro guy's Avatar
    Nov 30 2014
    06 audi a4 quattro 2.0 6sp
    rockford il
    Just to be absolutely clear. This will make any quattro auto engine be able to work in a manual one correct. I no longer need to worry about engine codes? It will be for a 2.0
    02 audi a4 Quattro 1.8 6sp, milltek exhaust, Motoza e85tune,f21 @26psi,stage 2 ra4 clutch, hyperboost diverter valve, 18z brakes, rear s4 brakes, TR11 FMIC, je pistons,ie rods 2.0 coil convertion kit (best 1/4mile time on stock engine at 21psi 13.4 @101mph)
    06 audi a4 quattro 2.0 6sp, gfb diverter valve, 2.5" test pipe, apr stage 2, r8 coil packs, s4 front brake
    05.5 a4 2.0tq 6sp, r8 coils, motoza e85 tune. S4 front brakes.
    Feb 23 2013
    KC, MO
    Quote Originally Posted by quattro guy View Post
    This will convert the auto crank from the longitudinal 4cyl 1.8T and 2.0T that were mated to the ZF HP19F series transaxles (1996-2009) to a manual configuration. This is the Audi B5,B6 and B7 chassis. On the VW chassis it is the B5 and B5.5 Passat 1.8t engines.
    On the 2.0T B7 (EA113) it fits the North American BPG/BPY engine. It is really about what the engine came out of and not the engine code.
    Nov 30 2014
    rockford il
    So I have a manual 6spd and the engine code for that is a BPG I found a quattry automatic that runs the same engine too. I found that odd. But I have purchased this a few years back when I broke a rod on my b6. Now on the wife's b7 the engine seized. I have this part already jusy need to find it. If I can find it ima order one next week as that's that's the engine will be ready.
    I appreciate the clarification
    Veteran Member Four Rings Jayz691's Avatar
    Jan 21 2018
    2005 Subaru Legacy GT
    frackville, pa US
    Quote Originally Posted by Gearbox View Post
    Don't forget BWT. I thought the only codes in NA b7''s was BPG(early) and BWT(late models).?
    Sent from my LM-G710VM using Audizine Forum mobile app
    Feb 23 2013
    KC, MO
    TTT
    Junior Member Two Rings MrxSiilent's Avatar
    Dec 05 2011
    A4 B7 2.0t Quattro
    In The Woods. P.A
    I ordered one. Fits great. Thank you and thanks for the gift
    Feb 23 2013
    KC, MO
    Quote Originally Posted by MrxSiilent View Post
    You're welcome!
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    TTT
    Feb 23 2013
    KC, MO
    bump
    Feb 23 2013
    KC, MO
    TTT
    May 08 2017
    Lowell, MA
    I'm interested and just sent you an email.
    Sent from my SM-N986U using Audizine Forum mobile app
    Veteran Member Three Rings wafi ahmed's Avatar
    Feb 03 2019
    Ny Long Island
    Isn’t this the same one as 1.8t?
