Results 1 to 16 of 16
    Registered Member One Ring StevoCvi28's Avatar
    Aug 18 2020
    Gearbox Malfunction you can continue driving
    I have a b8 s4 and I have had this Gearbox malfunction error for a while now. I had the code read about a year ago, it was P179E00 Drive Position sensor. The car drives fine and the error comes and goes after 15 mins of driving but i think i want to get around fixing sometime soon. Just wonder if any of yall have had this problem and how much did it cost to fix the issue? From what ive heard its requires the transmission to be pulled out?
    Veteran Member Four Rings fastboatster's Avatar
    Apr 23 2019
    2010 Audi A4 3.0T, lol
    CA
    Quite a few had this problem including myself. Yes, transmission needs to be dropped and split apart due to brilliant design of Audi geniuses.
    Established Member Two Rings gj314's Avatar
    Jun 11 2020
    MA
    Transmission builder in CT by the name of Eriksson Industries replaced that sensor for $2400 on a car I bought.
    Established Member Two Rings Keymainey's Avatar
    Aug 04 2019
    '14 5.0 Mustang
    TX
    Yea tranny has to be opened up. It can cost anywhere between $2,400-$6000. Highest price being at the dealership of course.
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    At least with Audis we have that option. When i had 911 and my PDK went due to $20 sensor. The whole transmisison needed to be replaced, its the dumbest design ever.
    Quote Originally Posted by fastboatster View Post
    2014 Audi S4 DSG
    Apr 23 2019
    CA
    Quote Originally Posted by bronz View Post
    Shitty option, quite honestly. Might be possible that that pdk sensor could be replaced, it’s just no shop wants to do it. Most people/shops just get another gearbox when this sensor quits, I had to look around to find somebody who would do the replacement. Might be possible that Porsche does take the cake in this case, though, they are not exactly famous for repairability either. Still, the idea of burying some electronic sensor inside a hot gear oil compartment is very “smart”. Anyway, good luck to the OP
    Aug 18 2020
    Quote Originally Posted by Keymainey View Post
    Appreciate the insight. I been thinking about just buying a low mileage transmission from a 2015-2016 S4 and just replace the whole thing. I hate to cough up 2k-6k just to replace a sensor then something else goes wrong and i gotta pull the transmission out again. Ive seen issues with the "Gearbox Malfunction you can continue driving" error where guys lose reverse and the car is in limp mode. I dont wanna deal with that after spending money to replace a sensor
    Apr 23 2019
    CA
    Quote Originally Posted by StevoCvi28 View Post
    that issue is most often just caused by bad pcbs, easy fix. However, if you can do a gen 2 dsg swap then by all means do and document it. You might need new rear diff and bunch of programming. do note that that sensor does quit on gen 2 transmissions too, although less frequently.
    Aug 18 2020
    bad pcbs you say, that is interesting. Im gonna talk to my audi guy about that.
    Oct 14 2022
    asuncion, paraguay
    hi guys.
    I have been with this error message forabout a year, trying to find the right answer and not dropping the transmission and something else needs to be done. This message show up, mainly, during the afternoon while I m driving errorless during the morning. So my family know that afternoon is when the errors shows up, but after 15 or more minutes, I can drive again.
    my audi is A6 C7 2012, 3.0 TFSI
    if you know what was the solutions please let me know.
    Alex
    Junior Member Two Rings rovision's Avatar
    Aug 06 2008
    2013 S4 SD, B&O +++ 2015 A3 SP Q
    Ca
    @agasociados you could try an "adaptation" as described on Ross-Tech site, or a more simple "reset" (press and keep throttle past kick point, key on but engine not running, keep pressed for 30sec, turn key off, release throttle).
    I had recently similar issues with my S4, and that fixed it. At least temporarily (my mech did the adaptation, to be clear).
    It seems in time this Drive Position Sensor gives up, and as described above, it's a rather expensive job. It also seems to happen when the ATF fluid is hot.
    Aug 16 2020
    Q
    Same thing came and went for me, moreso when the transmission was up to operating temperature. It was a transmission-out job to replace the selector lever sensor, and I was fortunate enough to find a transmission shop to take on the repair for $4,200. Miles don't mean shit, my car had 38K or so when it happened, so be wary of used transmissions regardless of mileage or age, they're all at least 7 years old by now.
    Aug 06 2008
    Ca
    Re transmissions and sourcing, any good references?
    I've inquired with my local dealer, no new ones available, ETA 1-2mo. Couldn't find even reman or used ones.
    A used one might be a worthless expense due to the nature of this issue though.
    Oct 14 2022
    asuncion, paraguay
    https://www.amazon.com/-/es/dp/B0B74...roduct_details
    I have bougth this kit and I hope it will repair.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    The above is NOT the correct parts to fix the Drive Position Sensor (Gear selector lever position, senses the position of the gear shift lever R,N,D....).
    This is what you need:
    https://www.ecstuning.com/b-genuine-...AaAlcCEALw_wcB
    Dec 25 2019
    Howell, MI
    S4’ed is correct. That kit will not cure your P179E. That code is related to the sensor that tells the car what gear it’s in.
    Quote Originally Posted by agasociados View Post
