Page 3 of 4 FirstFirst 1234 LastLast
Results 81 to 120 of 144
  1. #81
    Feb 13 2004
    Silicon Valley, CA
    When I ordered in March, one of the calipers was out of stock in the US and had to come from Germany, so it may be that.
    Kevin - Moderator, Audizine
  2. #82
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Quote Originally Posted by Stubek View Post
    IF anyone is looking for Q5 calipers, some just came up in the classifieds today.
    https://www.audizine.com/forum/showt...-G2-Lime-Green
    Just wanted to point this out. These are 320mm, not 345mm. These are not direct bolt on's for a B8 S.4, almost made an impulse purchase and noticed at the last second!
    BMW M850i
  3. #83
    Aug 21 2017
    Quote Originally Posted by Depthcharge View Post
    You can still check ECS, FCPEuro, Europa and others. Last time I checked a few weeks ago they had them.
    Thanks but none of those carry the Porsche Macan calipers, just the Q5's
    BMW M850i
  4. #84
    Veteran Member Three Rings Depthcharge's Avatar
    Nov 15 2007
    '21 PS2, '20 SQ5, '14 A4
    DFW, TX
  5. #85
    Aug 21 2017
    Much appreciated but they are backordered til 6/14 and are also $70 per caliper higher than other sources
    BMW M850i
  6. #86
    Veteran Member Three Rings Peter.dupuis's Avatar
    Jun 28 2015
    2018 Atlas
    Bend, OR
    I bought from here. You can find a free shipping promo code if you hunt around.
    https://www.suburbanautoparts.com/oe...per-95b615123f
    https://www.suburbanautoparts.com/oe...per-95b615124f
  7. #87
    Aug 21 2017
    Quote Originally Posted by Peter.dupuis View Post
    Thx...finding them cheaper even with free shipping
    BMW M850i
  8. #88
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Over 2 years with them and quite happy 💪
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
  9. #89
    Veteran Member Three Rings NathanGreatScott's Avatar
    Apr 05 2017
    '16 Ford Flex Limited
    Western PA
    Anyone know if the yellow ones (https://www.harperautoparts.com/v-20...--front-brakes part 95B-615-123-L about halfway down the page) are the same as the other colors? This one specifies "with ceramic brakes" but I wasnt sure if they're really just the same caliper but porsche only put the yellow color on the ceramic brake package.
  10. #90
    May 10 2015
    Pittsburgh PA
    Quote Originally Posted by NathanGreatScott View Post
    Those calipers along with the red Macan S calipers require Macan knuckles as well for install. The only direct bolt-on ones are the black calipers from the base 4cylinder Macan.
  11. #91
    Apr 05 2017
    Western PA
    Quote Originally Posted by 19birel View Post
    Thanks for the heads up. Really wanted a color, red or yellow, and still keep the porsche branding on there, but I guess I'll have to do it myself
  12. #92
    May 10 2015
    Pittsburgh PA
    Por15 brush on caliper paint is the move, I painted my A7 bbk with their yellow paint and they still look great 2yrs later. I'm sure Porsche caliper stickers are pretty easy to find on eBay to complete the look.
  13. #93
    Active Member One Ring Mr.I.'s Avatar
    Oct 19 2021
    Boston/MA
    Thank you so much for the great write-up! I'm finishing my cart for B8 S4 rn to start ordering parts. May I suggest adding a few things to complement the initial post for new people like me? I'm trying to replace all the HW as I go through the car to make sure it's fresh and reliable, especially on a 100K-mile car. So I would also add the following:
    Caliper Mount Bolt (x4): PAF-911-476
    Disc Brake Pad Wear Sensor (x1): 8R0-615-121 (Q5), 95B-907-253-A (Macan, but not 100% sure, as well as whether it can work with A4)
    Brake hose (x2): 95B-611-701-E (Macan, not sure if it's interchangeable with Q5 (8R0611707A) and S4 (8K0611775J) ones)
    I would appreciate if someone could clarify the above regarding Wear Sensor and Brake Hose, as for example on FCP Euro a brake hose for S4 or Q5 can be obtained for $15, while Genuine Macan is $40-$50.
    2011 Audi S4, APR Stage2+, ultracharger, dual pulley
  14. #94
    Veteran Member Four Rings JLAllroad's Avatar
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by Mr.I. View Post
    I just reused my bolts, brake lines, and bought a new A4/Allroad wear sensor, 57k miles ago.
  15. #95
    Nov 09 2019
    Earth
    Just so you guys know I will be selling my 4 piston Macan front brakes soon so I can move up to a 380mm kit. Also the SQ5 setup is killer if you don't mind the weight.
  16. #96
    Jul 25 2016
    California
    Me being in beautiful Southern California, I reused everything lol. My brake lines were okay, although I kind of wish I went the SS route. Also I spliced the brake wear sensor together so it never comes on. I can easily check for myself if I need new pads. Lol.
  17. #97
    Nov 09 2019
    Earth
    Dude just so everyone knows. I had the Porsche Brembo Macan 4 pot brakes, Audi Sq5 ATE 15" brakes , RS5/ R8 8 pot brakes and also Alcon 15" brakes. None of them require BMC swap. Our BMC works very well with all those kits mentioned. But, Install and enjoy.
  18. #98
    Oct 29 2018
    Seattle WA
    Quote Originally Posted by Audpor911 View Post
    I looking to buy a set let me know when you want to sell them and how much
  19. #99
    Senior Member Three Rings vincent_nguyen2's Avatar
    Oct 05 2016
    2014 Audi A4
    Dallas, TX
    Reviving the thread to ask about S4 rears. What is the issue with B8 and B8.5 calipers? I understand B8 on B8 works and B8.5 on B8 doesn't work, but how about the last scenario, B8 on B8.5? i.e. 2012 S4 on 2014 A4
  20. #100
    Nov 11 2017
    Denver, Colorado
    Quote Originally Posted by vincent_nguyen2 View Post
    I have B8 S4 on my B8.5 Allroad. I was going to switch out my lower mileage parking brake motors but the drive was not compatible, so I just plugged in the OGs on the calipers.
    That said, it wasn’t a noticeable difference, I had already installed the 4 piston Macans 40k prior, well worth it.
  21. #101
    Senior Member Two Rings bthethy's Avatar
    Oct 28 2018
    London
    What discs and pads you guys running with ur macan calipers?
  22. #102
    Veteran Member Three Rings bluefox280's Avatar
    Jul 03 2005
    Broomfield, CO
    Been very happy with the following for 4.5 years on my 2013 Allroad:
    Brakes:
    Front
    - OEM Q5 3.0T / TDI front 4-piston Brembo calipers - New Tucker Orange powder coat [thanks AZ member avantagg]
    - GEOMET front slotted rotors (vented 345mm x 30mm) [ECS Tuning ES#2189933]
    - EBC Brakes Red Stuff Pads [Perfect Brakes / EBC #DP32168C]
    - Front Exact-Fit stainless steel brake lines [ECS Tuning ES#248970]
    Rear
    - OEM S4 / S5 rear 1-piston calipers & carriers - New Tucker Orange powder coat [thanks AZ member avantagg]
    - GEOMET rear slotted rotors (vented 330mm x 22mm) [ECS Tuning ES#2189938]
    - EBC Brakes Red Stuff Pads [Perfect Brakes / EBC #DP31988C]
    - Rear Exact-Fit stainless steel brake lines [ECS Tuning ES#1899277]
    - Erik
    PatternDraftImaging.com - "...Where Engineering Discipline and Photography Merge as One..."
  23. #103
    Junior Member Two Rings Rewagon's Avatar
    Sep 04 2021
    California
    Quote Originally Posted by SNice View Post
    I actually think they might fit. I came across them after I did my conversion but they look exactly like the SQ5/s4/s5 rears with the name plate.
    The Macan rears would be great because they have the plate. There are several sets on ebay - prices aren’t too bad. The actual SQ5/s4 ones with the plate are unobtanium. I found a pair and repainted them (they originally had the SQ5 logo on the plate). The only difference on the macan rears seems to be that they have a wear sensor.
    It only makes sense that these platforms would share parts. All the specs match up. Macans have 330mm rears too. Here’s a link to a current eBay listing:
    https://www.ebay.com/itm/Porsche-Mac....m46890.l49292
    Macan rears:
    Attachment 210569
    Attachment 210570
    Attachment 210571
    SQ5 rears (repainted)
    Attachment 210573Attachment 210574
    Attachment 210575
    Confirming 2017 Macan 2.0t rear calipers fit on my 2010 A4 Avant. Strangely the only thing that did not fit on my car in this conversion was the Macan front dust shields.
    Many thanks to the OP and everyone’s comments here.
  24. #104
    Veteran Member Three Rings shreddykrueger's Avatar
    Feb 14 2016
    S4 Avant
    Quote Originally Posted by Rewagon View Post
    Interesting. I just ordered everything including the dust shields for my avant. Think the dusts would fit with minor modification?
    S4 Avant (6MT)
    RCP dual pulley | AWE touring | JHM catted/baffled DP's | AEM water/meth | Ringer Stage III | RSNAV | Vogtland Coilovers | many other tings
  25. #105
    Sep 04 2021
    California
    Quote Originally Posted by shreddykrueger View Post
    I bought the shields based on OP notes but also knowing they weren’t expensive if they did not fit. Honestly, I took the whole kit to a local performance shop I trust for the work so I didn’t wrench myself. I don’t plan to track the car so the venting was a low priority. If you try it out, let us know and I may try again. I was mostly interested in the Macan rear calipers since it seems everyone else was using the S4/S5 rears. I like the consistency and both front and rear are now 2017 Macan.
    Sent from my iPad using Audizine Forum
  26. #106
    Jul 25 2016
    California
    Your shop didn't even try, they were 100% bolt on for my car.
  27. #107
    Sep 04 2021
    California
    Quote Originally Posted by Nano909 View Post
    It’s a good shop with stellar reputation but I think you’re right. I still have the shields and may just do it myself.
    The brakes have been awesome. Ceramic pads have cut down the dust 10x. And glad I went with the Macan rear calipers.
    Thanks again for your write up and inspiration.
  28. #108
    Dec 01 2021
    BROOKLYN
    Porsche Macan Calipers on B8 B8.5 A4
    Can the 2018-2020 q5 calipers fit the 2014 allroad(b8.5)?
  29. #109
    Dec 01 2021
    BROOKLYN
    Quote Originally Posted by BQE2.0T View Post
    Anyone Home????
  30. #110
    Jul 25 2016
    California
    Anyone Home????
    Did you even bother reading the thread? I'm not going to hold your hand.
  31. #111
    Jul 16 2018
    Atlanta
    "B9" does not appear in this thread anywhere that I can see. That said, the question presented is a more generic "do B9 brakes fit on B8 vehicles", which is a lot more of a stretch than simply using Macan 2.0T 345x30 brakes on a B8 vehicle. Which is what this thread is about.
    The B9.0 Q5 2.0T uses the same 338x30 4-piston fixed caliper ATE brakes as the B9 A4 and B9 A5, not 345x30 4-piston fixed caliper Brembo like B8.5 Q5 3.0T / 3.0 TDI used (or 320x30 version for B8.5 Q5 2.0T). It appears from some simple google searching that you'd need some custom brackets at least, based on threads of putting B9 S 350x34 and RS 375x36 on B8 vehicles. I don't know why you'd bother unless you had them already sitting around.
  32. #112
    May 23 2016
    1996 Toyota 4Runner
    Bay Area, Ca
    Worth it. Thanks thread
  33. #113
    Jul 25 2016
    California
    Quote Originally Posted by classicrl45 View Post
    Damn that looks good 👌
  34. #114
    Veteran Member Three Rings Wimbledon's Avatar
    Dec 01 2005
    Tucson, AZ
    For the Macan rears, any other parts I should buy at the same time?
  35. #115
    May 23 2016
    1996 Toyota 4Runner
    Bay Area, Ca
    Just make sure you buy the correct rotors and brake pads.
    I selected macan brembo rotors and macan ebc red stuff pad.
  36. #116
    Dec 01 2005
    Tucson, AZ
    Macan pads, not S4 pads, right? Anyone have the part numbers for the correct Macan pads?
  37. #117
    Nov 28 2017
    Carbondale, IL
    I ordered the OP's parts list for the front brakes for my '11 S4. Ended up being $667 shipped from the Porsche dealer he recommended. Should arrive in a few days.
    --'11 Audi S4 Prestige, 6MT, boring white
    --'15 Audi A4 S-Line, 6MT, volcano red - wife's daily
    --'03 Mustang Cobra vert, '02 Porsche 911 Cabrio, '94 Caprice wagon, '23 Cadillac CT5-V Blackwing, '17 Corvette Z06
    --'08 Buell 1125R, '05 Speed Triple, '99 VFR800, '15 Vmax, '02 DRZ-400E
  38. #118
    Nov 28 2017
    Carbondale, IL
    I'm in the process of putting everything together. I shopped for 2015 Porsche Macan brake pads and they are definitely not correct. Rockauto.com just lists the 3.0L V6 and 3.6L V6 options, and the brake pads look like this:
    https://www.rockauto.com/en/moreinfo...=1684&jsn=1321
    The pads that are compatible with driver side Macan part number 95B-615-123-F and passenger side Macan caliper 95B-615-124-F actually look like this (I am just about positive):
    https://www.rockauto.com/en/moreinfo...=1684&jsn=1070
    The short version is that the 2015-2016 Porsche Macan front calipers are NOT the same as the 2015-2017 Audi Q5; apparently the only the sportier Macan was available for those years and they had the bigger 6-pot calipers. The 2017 Porsche Macan with the 2L I4 apparently does have the same calipers as the 2015-2017 Q5 according to my research on rockauto.com.
    To confound things even further, I tried looking up the Hawk HPS 5.0 part number at hawkperformance.com. The parts lookup there is completely unreliable--it returns results that I can't duplicate anywhere else. For example, it indicates that all four versions of the 2017 Macan (base, S, GTS, and turbo) all take the same pads, which are the same as the 2015-2016 6-pot brake pads. But browsing rockauto.com, there are clearly different pads for the 2017 2L Macan as opposed to the 3.0L and 3.6L.
    So I looked up the 2015 Audi Q5 at hawkperformance.com and it returns nothing.
    So then I looked up 2015 Audi Q5 at hawkpadsdirect.com and came up with this, which looks accurate. https://www.hawkpadsdirect.com/produ...40862568448192 That's part number HWKHB806B.624. Amazon has them for $107.99. https://www.amazon.com/Hawk-Performa.../dp/B074MYD4JV So that's what I'm going to order, and hope that it's the right pad.
    The good news is that all of the part numbers from the OP's post are the correct parts--they all bolt up as-expected. It's just finding the right Hawk Performance 5.0 brake pads that's been somewhat problematic. I plan to light-duty track my S4, and from what I've read, the 5.0 pads should do street and track duty reasonably well.
  39. #119
    Established Member Two Rings iCrap's Avatar
    Nov 29 2017
    2016 S5, 2023 Q5E, 2001 Honda S2000
    MD
    Has anyone found a better price than $567.28 for the two fronts? Currently in my cart at Delaware Porsche. I have an S5 so it seems I can reuse everything else. Just need calipers and pads.
    2016 S5 Daytona Grey - RS Grille | RSNAV | H&R | CTS Turbo Intake | 034 Stage 2 | Deval
    2023 Q5E - District Green
  40. #120
    Nov 28 2017
    Carbondale, IL
    Quote Originally Posted by thefleshrocket View Post
    FYI those were the correct pads--the fit properly and seem fine so far. Stopping power is decent when cold but ramps up once the pads have a little heat into them (like several mild / moderate stops from 60ish mph). I haven't taken them to the track yet.
