Now based on this chart, for most people, we should be running 39/35 regardless of whether we have the staggered setup or the square setup.
However the tire pressure sticker on the side of my car only shows the pressures for up to 174mph. So it shows 44/39.
Also if the stock tires are rated at 91Y and my new tires I got mounted at 93Y. Based on the load index I should be filling them to 2 psi less correct? So I should be at 37/33?
https://static1.1.sqspcdn.com/static...+inflation.pdf
