Originally Posted by
Smac770
The adaptation value gives you a feel for the extent of the chain stretch. It's not authoritative like visually checking the tensioner extension, but it's a hell of a lot more convenient for just wanting a "should I care to check yet".
But it says nothing about whether you have the defective tensioner or the corrected tensioner.
Yes to all your points. But I am trying a different tack as an early warning of chain/tensioner problems on a car that is definitely
not broken (2.0 TFSI MQB). VCDS provides camshaft adaptation values for both cams and in my case it is 0 Deg for intake and 3.7 deg exhaust. But there is also an adaptation value to use after cam chain replacement which I take as the same as the original factory value. If I adjust the adaptation for the chain replacement number I get is 0.5 deg.
I notice that this effect seems to be common on the not broken VAG cars posted in the Ross-Tech site. One suggestion is is that this phase shift is emission related. My measurement is at idle so may change under load. So far for 2000 mi there has been no change.
I see you often post on Ross-Tech. Opinion? I have asked about this on different forums with 0 responses, Obviously of questionable use on high mileage engines.
