So I picked up a 2008 2.0t fsi engine with 78k miles on it to replace the bad one in my B7. Both engines are BWT. While I have it in my garage I've been fixing it up so I have less chance of problems down the road. I'm almost done and will be ready to get it in the car soon. Here's a list of everything I've done to the replacement engine so far thanks to all the wonderful people on this forum helping me out during this adventure.
New thermostat, new oil cooler, new rear main seal, dropped oil pan and cleaned out screen, installed new drain plug with magnet and new oil pan gasket, new oil filter housing, new Lp fuel line, new coolant hoses as needed, new timing chain tensioner and chain, 3 new rings inside timing cover and new gasket, new camshaft seal, new timing belt complete kit with water pump and tensioner pulley, new belts, removed cam tray and resealed it with anaerobic gasket maker and ARP bolts , new valve cover and gasket, new coils and plugs, rebuilt vacuum pump, new cam follower, new cam shaft end cap, new oil, fuel and air filter, new pressure control gasket and a new breather hose.
How'd I do?
Also I haven't touched the turbo yet. The one on the bad engine has 116k miles on it but worked fine, the one that came on the replacement engine should only have 78k miles on it but I don't know if it worked right or not. What one should I use and should I somehow clean the one I'll be using also? I see videos on how to clean a turbo when its on the running engine in the car but not when it's out of the car.
Thanks again for the help and here's some pics of the engine now.
