im 100% sure its some electrical problem but where that is a big question mark.
My scanner is able to scan the ECU for the codes prior of starting it(while battery disconnected and swapping ECU) but as soon as i start it and then she stalls the scanner will say failed to communicate,witch happens right away after the 1st start up.
I have another ECU of a 1999 A4 Quattro AEB M/T and it does the same thing.
I checked all my fuses and all of them are good exept found the rear whipper fuse blown but that dosent matther at all.
Connected my 2.8 ECU just for fun and was able to read aswell.
Also Cant access ABS/Air Bag Modules after the swap witch i absolutly need because they are popping out and i need to pass inspection aswell(didnt have them before swapping the engine too)
The car itself its an 1998 A4 M/T Avant that had a 2.8 30V,witch i really didnt like so swapped for the 1.8T witchmore realialbe,easy to work and has way much potential when they properly work.
The 1.8t is bone stock with no upgrades,few sensors are new,some are reused,yes i did a TB adaptation and even tried a 2nd TB,tried 1 brand new temp sensor and one original from the passat, new BKR6EIX as plugs,tried with and without MAF sensor connected,im out of ideas at that point do i need to do some wiring( did check the end of the harness and there is 1 pins in the yellow connector and one in the brown that dosent link up with any pins from the car connectors all the rest seems to be connecting to some pins)
Has any of you went thrue this kind of situation?
Tought this is pretty straightforward swap till this happens
Any help with be gladdy appreciated,wiling to ship you out some food via ubereats to the one that can seriously help me out here(no jokes
Thanks in advance
Info pulled out of Maestro Scanner on the Passat ECU
Controller part number :8D0907557P
Ecu software number is :1037352103
Ecu hardware number is :0261204258
Vin number is :unknown
Ecu type :256K M3.8/5.9
Engine type :5V 1.8Turbo
Was able to pull few check engine codes : 16946 ,System Voltage too low / 16806 Bank 1 Catalyst Below threshold ( New O2 sensors so maybe from previous car ) / 16500 G62 implausible signal / 18010 Power supply terminal 30 , Voltage Low( im boosting the car everytime to get it started ) & last code is 18021 MIL Control circuit open.
