Originally Posted by
adam044
So now are you suggesting to bleed the 2 supercharger bleeder screws, the HX AND now this hose?
I was merely suggesting where that bleeder is located and how to use it. There are two separate threads going on this subject, so I'm not quite sure where we are.
I hold the view that if you are doing a full system drain/flush and refill, this heater hose bleed should be included. If you can't get hot air from the heater do it first. Usually, if you properly burp the reservoir, though, you'll get hot air.
If merely bleeding after installing an aftermarket HX, and preserving as much coolant in place as possible, its optional if you have good hot heat. Its also optional when doing repeat bleeding when you've already bled and think you still have air (high IATs).
However, since its easy to pull that hose back and bleed there as a final step, I have done it, anyway. When you think about it, Audi put that bleeder there for a reason. Whether air in the heater core has any effect on the supercharger loop, even indirectly, is debatable. I understand that point. But, why not do it? It is the highest bleed point in the system.
As to the supercharger screws, mine have been easy to turn, but I've turned them out a half turn first with the engine cold, "cracking" them, then back until almost tight but still turning easily, before starting the hot engine bleed. Its been easy that way and they don't leak until you turn them out more.
It really helps to find a big driver bit that fits them well. I'm OCD enough to have done this quite a few times, now, messing with different percentages of water to coolant - now 80/20 in favor of water, but going back to 70/30 or 50/50 when traveling north. Every time, I'm rebleeding. Those little plastic screws are doing fine. Maybe I'm just lucky. But, I think gently "cracking" them a bit cold is helping.
I'm by no means an expert on this. I'm merely reporting what I've been doing.
