Page 32 of 32 FirstFirst ... 22303132
Results 1,241 to 1,272 of 1272
  1. #1241
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    Swapped my OEM flat bottom steering wheel for a full Alcantara flat bottom. I am in heaven
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
  2. #1242
    Veteran Member Three Rings AlaskanAudi's Avatar
    Jul 28 2012
    2018 Tiguan
    Houston, TX
    Quote Originally Posted by MNAudi101 View Post
    Show us a before vs after!
  3. #1243
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Well, going to need new tires as mine are looking severely cracked.
    Running OEM staggered wheels with 255/30/19 tires right now. They came on it when I bought it last month.
    I like the wide tire look. Any reason to not stick with this size? I know many go 245/35/19, but rather keep the wider tires if no reason not to.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
  4. #1244
    Aug 18 2011
    Stuff
    Minnesota
    Quote Originally Posted by AlaskanAudi View Post
    Sorry just saw this post, ill get some before and after and post today
    200k daily tank
    My Build Thread
  5. #1245
    Dec 06 2018
    Pacific North West
    Took advantage of the nice weather and renewed my summer wheels for the upcoming season!
    o washed with Dawn power wash
    o sprayed with Simoniz iron remover
    o Mothers clay bar treatment
    o washed with Adams strip wash
    o spot polish on the flat surfaces with my micro polisher
    o final clean with homemade IPA panel wipe
    o Adams ceramic coating
    I had so much ceramic coating left over that I decided to treat my newly acquired struts and springs ... should keep them looking nice with a simple pressure wash. When I switch them over ... I'll give my winter wheels the same treatment before storing.
  6. #1246
    Jul 28 2012
    2018 Tiguan
    Houston, TX
    Quote Originally Posted by Bobbybrown View Post
    Daaang I want one of the wheel roller things, nice work! Nothing like fresh and clean under-body parts
  7. #1247
    Dec 06 2018
    Pacific North West
    ... one of my favorite tools when it comes to detailing made by Maxshine
  8. #1248
    Jun 02 2014
    09 A3 Quattro, 15 A3 Quattro, 14 A4 Quattro, 22 VW Taos, 19 TT 20th Anniversary Edition
    Lynnfield MA
    Replaced the timing chains on my A3 with a kit from ECS Tunning. To my surprise the chain was not stretched at all at 162k miles. The guides were worn a little.
    Sent from my XQ-BC62 using Tapatalk
  9. #1249
    Junior Member Two Rings
    Jun 19 2022
    Southern VA
    Freshly tinted and washed. I also recently did the 034 engine and trans mounts, upper timing cover gaskets/seals - all 5 of them. I also did an oil change and PCV with fresh oil cap at 95k miles. Should be good for a long while.
    My goal is to keep the car and see how many miles I can get it to. I am planning on replacing the turbo at some point, the fins are a little chewed up on the cold side for who knows what reason.
    I gotta say, for a 8 year old car she looks real good all shined up.
    2018 A4 Allroad - Manhattan Grey
  10. #1250
    Jul 28 2012
    2018 Tiguan
    Houston, TX
    Quote Originally Posted by trebec View Post
    Looks stunning!
    By upper timing gaskets and seals, do you mean: the upper timing cover (side), associated cam seals (2 of them), top timing cover? I’m not sure what the 5th seal is that you replaced
  11. #1251
    Jun 02 2014
    Lynnfield MA
    Looks stunning!
    You have cover gasket, 2 cam solenoids seals and 2 o-ring seals on the cam bridge. I just replaced all 5 when installing new timing kit on my A3.
  12. #1252
    Veteran Member Four Rings MikTip's Avatar
    Dec 25 2004
    Earth
    Turbo fins chewed up...it from dirt and debris hitting them...did the car have a cone filter setup? Or an issue with the OE airbox and filter allowing dirt to bypass the filter?
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
  13. #1253
    Jun 19 2022
    Southern VA
    Quote Originally Posted by evo v View Post
    This.
    Quote Originally Posted by MikTip View Post
    Yup. The dealership did a full "service" and replaced the air filter according to carfax. When I pulled the APR intake the filter was literally disintegrating. Put a new filter and noticed the fins. Disappointing but I've heard of the IS38 OEM turbo's having some issues with wastegate stuff I think. The HPA OEM+ is supposed to be a real stout upgrade that will last probably as long as the car.
  14. #1254
    Dec 25 2004
    Earth
    This.
    So the APR setup allowed in dirt...which explains the turbo fins.
    Hpa's turbo has.a 2mm larger diameter turbine shaft. This is in an effort to help if and when the is38 is maxed out while boosting. The is38 cannot withstand high boost for extended periods of time. The hot side turbine bearing siezes...the shaft breaks and the hot side impellar jumps into the converter along with allot of oil. My first OE is38 lasted 183,000 miles with a stage 1 tune. 24psi. Allot of tunes turn up the boost higher. If your not going abive stage 1...the oe is38 will survive as long as you dont run it at full boost for extended periods.
  15. #1255
    Jun 19 2022
    Southern VA
    Well I peak at 22 psi on my OBD gauge reader, I eventually plan to go "stage 2" with a downpipe. I don't run it at high boost for extended periods either way, this is my daily and it does not get autox or tracked, I don't have the insurance for that nor do I want to. I'm looking for super high mileage and ultimate reliability, some occasional street abuse, a launch from time to time that kinda stuff. I prefer partial boost sounds and performance anyways.
  16. #1256
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Replaced the primary O2 sensor after catching 3x P0131 codes (no CEL). The stock sensor looks pretty rough at 79k miles. Also knocked out an oil change while I was at it.
    2019 SQ5 Prestige
  17. #1257
    Jun 02 2014
    Lynnfield MA
    Sold mine. Now I'm left with 2 TT 8S- roadster and a coupe and A3 8P.
  18. #1258
    Veteran Member Three Rings Eli0073's Avatar
    Jul 17 2020
    USA And Finland
    Install a dash cam
    Sent from my IN2017 using Audizine Forum mobile app
  19. #1259
    Jun 13 2021
    World
    Quote Originally Posted by Eli0073 View Post
    Install a dash cam
    Can you please share more photos and info like what brand dash cam you got and how you did the install?
    I am looking to do the same to my car and would like to see how you did it!
  20. #1260
    Jul 17 2020
    USA And Finland
    Quote Originally Posted by n0ferz View Post
    It's a FitCamX. If you have an Audi S3 8V is Camera Model: HD2-7708 (Model-A). It comes with everything you need. Do the install with the car off, Used the provided pry tool and remove the bowl trim and the other part. The camera piggy back from the rain sensor. You unplugged the rain sensor and plugged into the camera harness and from the camera harness there's a plug that goes back to the rain sensor. That's it. Then you put the camera bowl in place that is the tricky part. It took me several tries until it slot in perfectly, then put the last part to hide the cables and done. You download the app, turn the car on search in your phone for the camera wifi the instructions tells you the WiFi name and password and that's it the app has settings for image and sound and other stuff I'm not familiar. I bought a lens that is an extra accessory is a anti-glare. The app is very easy to use. There's plenty of install tutorials if you search in YouTube.
  21. #1261
    Apr 01 2007
    houston texas
    Raced it!
    2019 SQ5 Prestige
  22. #1262
    Jun 13 2021
    World
    Thanks a lot, that was very helpful!
  23. #1263
    Nov 23 2024
    St. Luis, MO, USA
    Did an oil change and painted the rear diffuser matte black
  24. #1264
    Jul 17 2020
    USA And Finland
    Install a Rear Trunk Brace.
  25. #1265
    Jul 17 2020
    USA And Finland
    Replace the undertay with this new one that covers all the way down to the dog bone. Install new front lip that was the victim of snow . Install front strut brace, and the prop shaft alignment kit.
  26. #1266
    Jul 17 2020
    USA And Finland
    Install front subframe brace and rear lower control arms aero covers retrofit.
  27. #1267
    Apr 01 2007
    houston texas
    I sm super interested in reading more about the larger belly and and rear control arm aero covers!
    2019 SQ5 Prestige
  28. #1268
    Jul 17 2020
    USA And Finland
    The aero covers are easy to install, you have to remove the two 8mm spreader rivets to remove a small plastic cover in order to install the new ones and reused those rivets again. They're held in place by 4 rivets. Two on the bottom and two on top.
    For the undertay you will need to buy 3 Combination Torx M8 Head Bolts Part #WHT000729A the others torx screws you can use the ones you already have.
  29. #1269
    Junior Member One Ring
    Dec 14 2024
    Dubai
    Put together a baffled and wire meshed DQ500 breather can for $35. Need to get M4 bolts for the mounting bracket, maybe paint the SS bracket black if I feel like it.
    Instead of using the generic catch can's inlet/outlet, I'm using the bottom drain port as the inlet and the filtered top as a breather. (Which connects to the part with the brass mesh filter)
    Then I need confirm correct hose sizing, paint my bracket black, and I'm good to go for the install.
  30. #1270
    Dec 14 2024
    Dubai
    Installed APR ignition coils and I've successfully installed my DIY $35 DSG catch can. Used an 8mm ID nitrile rubber hose.
    I gotta say, the can looks pretty good.
  31. #1271
    Dec 14 2024
    Dubai
    Got a TVS Engineering Stage 2+ transmission tune installed, it's amazing. It made the DQ500 so smooth and refined, no rough shifts even when gunning it in Dynamic, just lightning fast and smooth shifts.
    Received my DS1 today too, will install the stage 1 93 AKI tune tomorrow.
  32. #1272
    Senior Member Two Rings ashed's Avatar
    Jul 09 2013
    01 Santorin S4 project,'14 Rubicon, '12 Silverado
    Lakewood, Co
    What did you do to your RS3 today?
    I bought it :) 2018 nardo grey 57k miles
