Results 1 to 29 of 29
    Veteran Member Three Rings BuickTypeR's Avatar
    Feb 18 2020
    wheeling illinois
    C7 A6 3.0T how do i get windows and roof to go down and up using my remote.
    C7 A6 3.0T how do i get windows and roof to go down and up using my remote.?
    Senior Member Three Rings Nick_elgy's Avatar
    Jan 01 2020
    A freezer
    Baltimore
    Quote Originally Posted by BuickTypeR View Post
    I’m wondering also. On my lexus and many other cars all you do is press and hold unlock button
    2016 Audi A6 prestige black optic. No mods yet
    Jan 01 2020
    A freezer
    Baltimore
    On YouTube it says you have to do it using vids
    Jan 01 2020
    A freezer
    Baltimore
    Quote Originally Posted by Nick_elgy View Post
    VCDS*
    Veteran Member Three Rings Vinng86's Avatar
    Jul 20 2018
    Toronto, ON
    There is a VAGCOM mod you can do that enables this feature. It wasn't enabled by default for me, but I used Carista to enable it.
    https://www.audizine.com/forum/showt...-list-and-help
    2014 Audi A6 3.0T Technik(Prestige) S-line w/ Black Optics
    Established Member Two Rings dbsterben's Avatar
    May 22 2020
    1982 BMW 325is // 2013 Ford Focus ST3
    Jacksonville, FL
    Press and hold the unlock button. If it doesn't work it might have been disabled, obdeleven is a quick way to change software relatively quickly, go with vcds if you plan on doing a lot of long coding though.
    2016 3.0T C7.5 S-Line Prestige Ibis White APR Stage 1 tune
    APR Stage 1 tune
    Established Member Two Rings indigofilipino's Avatar
    Mar 06 2019
    2018 Audi S5 B9 Premium Plus Coupe
    MiAMi
    You can use OBDEleven to enable it. Here's a screenshot of the app.
    2018 AUDi S5 Premium Plus Coupe
    Feb 18 2020
    wheeling illinois
    I’m so surprised this is not enable as factory my infiniti g37 had option to go down with remote not up. Okay OBD ELEVEN OR VDCS got it thanks guys. Anybody do cool features besides windows with ODBELEVEN?
    Jul 20 2018
    Toronto, ON
    Needle sweep mod! Your tachometer and speedometer needles do a full sweep on startup, and if you have ACC it lights up your dials to follow the needle. It's super cool.
    Feb 18 2020
    wheeling illinois
    i took care of needle full sweet and disabled noise for seatbelt too. Car scanner free to download. Easy app to use.
    Jan 01 2020
    A freezer
    Baltimore
    But need to buy the piece for like $150 right?
    Feb 18 2020
    wheeling illinois
    no just buy any obd2 plug in which cost me 20 bucks and i was able to connect using the app thru my bit apple.
    Oct 18 2017
    NW Philly
    I have tried myself via the app on obd11 and my windows do not go back up with remote. They open but that was a stock feature of the car. I just want them to close again.
    App did not work
    Veteran Member Three Rings paul-g's Avatar
    Dec 02 2011
    2013 Ford F150 3.5 EcoBoost 4x4, 2018 Volkswagen Tiguan
    did mine last night super easy. there are to threads on how to do things but you need to buy something to play around just need to buy one of the programmers. I use Ross tech
    2016 Audi A6 3.0 S line, APR Stage 1, Melen TCU Tune
    Veteran Member Three Rings silver3.8's Avatar
    Nov 13 2019
    DMV
    I can get windows to go down, but long press of the lock doesn't roll them up.
    C7.5 A6 2.0T P+ S - Line:
    Performance :RRR Stg 3 (93 & E30), Mamba GTX 3071R, APR Intercooler, 034 HPFP, APR Coils, HVF TCU, GFB VTA, BMS Pedal Tuner, Injen CAI, Visican gauge, JHM HFC & DP and Cende's Valvetronic Exhaust, Improved Racing's Catch can and 034 dog bone insert.
    Appearance: RS6 front bumper, RS6 Honeycomb grille, Maxton design trunk lip, 19" Niche Rainer
    Dec 02 2011
    Quote Originally Posted by silver3.8 View Post
    did you follow this>
    Enable Remote Operation Windows and Sunroof
    [46 - Cent. Conv.] [Coding - 07] -> [Long Coding Helper] Byte 2
    Bit 2 - Set to 1
    then this
    On C7.5 for comfort window/roof operation you also have to do this as well:
    Enable window closing with remote (opening is already an option in MMI)
    46 - Cent. Conv.
    Adaptation - 10
    Channel 62
    Change value from 8738 to 48059
    Test
    Nov 13 2019
    DMV
    I have an obd11 and used the app. I will see if I can long code it.
    Quote Originally Posted by paul-g View Post
    Bit 2 - Set to 1
    then this
    46 - Cent. Conv.
    Adaptation - 10
    Channel 62
    Test
    Sent from my SM-N976U using Audizine mobile app
    Junior Member Two Rings H4mm3R2's Avatar
    Sep 10 2018
    Poland
    Bit 2 - Set to 1
    then this
    46 - Cent. Conv.
    Adaptation - 10
    Channel 62
    Test
    U are awesome
    Aug 24 2014
    Newport Beach, CA
    Another car with the windows and sunroof opening with a long press of the unlock, which I rarely use. Even my B5 S4 has that capability so surprising some don't have it enabled from the factory.
    Imola 2001 Stage 3 S4: 324K - 157mph 1/2 mile - 543whp/530ftlbs Mustang Dyno - Built BEL Block - RS4 cams/intake - TTE600s - Ringer Racing Stage 5 - Etspec - SRM V3 Intercoolers - AA built trans - 4:1 Diff - Vast cooler - JHM Trio - 034 - H&R Coilovers - OZ Racing - SRM/SSAC exhaust
    2024 M3 Comp xDrive
    2016 A6 prestige w/ s-line, APR Stg 1, Melen TCU, PS4S, valcona S6 interior parts
    Senior Member Two Rings 16s3pang's Avatar
    May 07 2016
    07 Mazda MX-5 PRHT
    Goffstown, NH
    I have a 16 RS7 and looking to enable the double lock and windows up feature in ODBEleven. I have this app enabled in the MMI but when double click and holding lock does not put the windows up.
    Does anyone have any idea's?
    TIA!
    |2016 RS7|
    |Sepang|Dynamic Pkg|B&O|Comfort Seats|Aluminum Atlas Inlays|Cold Weather Pkg|Milltek non-res exhaust|Roc-Euro intake|034 Motorsport Drivetrain Inserts|
    Feb 18 2020
    wheeling illinois
    bump
    Oct 18 2017
    NW Philly
    It does not work via the obd11 app.
    I've tried on my c7.5
    Nov 25 2014
    2002 Audi A4 3.0
    Columbus, IN
    Quote Originally Posted by Spitfire007 View Post
    I did it on my 2018 with a VCDS and it worked. Check out this post, https://www.audizine.com/forum/showt...ghlight=Vagcom it has a bunch of VCDS mods that people were able to do on the C7.5
    2018 Audi A6 3.0T Prestige - Stock for now (Still under warranty)
    Oct 18 2017
    NW Philly
    Correction.
    I can, through the stock car settings, get the windows to come down and the roof to open.
    However, I CANNOT, via Obd11's apps, get them to come back up and close.
    Veteran Member Three Rings A665's Avatar
    Oct 26 2019
    Mid-Atlantic
    I don't know about C7.5, but windows down & up / sunroof open & close via key fob is possible with OBD-II on C7 and prior.
    Here's a YouTube that may be helpful: https://www.youtube.com/watch?v=zy9NFw5Wo3I
    NOTE: I have noticed that the key fob range is very limited for this function, meaning that I have to be standing no more than, say, 12-15 ft away from vehicle for it to work. Thus, I really don't use it very much at all.
    2013 Audi A6 3.0T Prestige | S-Line / Sport | Full LED | 034 Stage 1 ECU+TCU | ECS Trans Mount Insert | JHM Driveshaft Carrier Bushing | FormulaOne Pinnacle Tint
    Dec 08 2020
    Portland, OR
    I wish there was a way to have them roll up with a single press of door lock button or key fob.
