Results 1 to 37 of 37
    Senior Member Two Rings Fixeroh's Avatar
    Aug 13 2014
    Central Ohio
    Something to consider for new RS3 owners considering an ECU tune
    Took my 2018 RS3 in for it's 2 year maintenance today. Barely have 10K miles on the odometer however. About a year ago, went to APR Stage 1 93 octane tune. Extremely happy. 6 months later, got the TCU tune as well. I've always had a good communication with my Audi service guys. Like my previous S3 (tuned to Stage 2+) as well as this car, I remind them that the car has an ECU tune. They requested I tell them so they don't connect to the system and I don't get flagged. There is an air bag seat sensor wire recall out on the RS3. They could not do that during maintenance today because they would have to connect to the system and I would get flagged. So I declined the recall work. Seems the fix is to lengthen the sensor wire so when the passenger seat is jacked up to the highest setting, it won't disconnect itself. Not a worry for me. Point is to be aware that if you have any aftermarket ECU or TCU tunes done to your car during the normal warranty period, it may affect your ability to have recalls repaired. My PSA for the day.
    Feb 09 2016
    co
    Whats the point? Even if they don't TD1 it now.. next time you go in for actual warranty work and they have to plug it in it'll be TD1'd.
    Unless your hoping to sell it/trade it without a TD1
    Apr 20 2018
    Chicago
    Quote Originally Posted by LJS5 View Post
    Exactly. Assume once you flash your car you will get no meaningful warranty work done without you paying out of pocket. I'd love to go stage 2, but hate the sounds of those cars and the Apr stage 2 is pointless as it's barely better on e85, so I'd need to spend $ on another tune. Waiting on ludicrous mode Tesla Model 3 and I'll probably ditch the Rs3 as tired of dealing with swapping parts and dealing with dealers charging way over normal for small issues
    Jun 07 2019
    2017 S6
    NC
    Every time I take my RS3 in to the dealer for anything I flash it back to stock. I know it's not a guarantee against getting flagged but being able to flash it back to stock in a matter of 20 minutes is so easy to do myself it doesn't make sense not to. As far as that particular recall I've declined it every time. I'm not going to have them remove the seats and risk the car squeaking over such a trivial thing.
    Nov 06 2017
    Vancouver
    At least they didn't swap out your washer nozzles
    May 22 2020
    2002 Supercharged Civic Si ep3.
    Texas
    I got a random scare on my car today. Was stuck in traffic, and then shortly after I got playful with the car, was going above 100mph, then suddenly it quit accelerating and limited my rpm power to 4k. The car sounded ok and no odd noises. No cel on, only said, drive train malfunction, and maximum engine speed 4000 rpm. So I drove another 2 miles. Parked the car, turned it off, and turned it back on and no warnings of any kind. I got back on the highway to go to work, punched it and everything was back to normal. Something similar like this happened to me on my 16 s3 I had, except that one had some random misfire fault. Only happen once on the s3. I currently have 2500 miles on the 2020 Rs3 with apr stg 1 tune and forge turbo inlet pipe and hard pipe. I think it's some kind of weird glitch that happened with it. Not to overly worried. I haven't scanned the car yet to see if it has any stored codes.
    Senior Member Three Rings mezgermischief's Avatar
    Jul 13 2015
    997.2 GT3RS
    Quote Originally Posted by Leonitus86 View Post
    This use to happen to me all the time with my car and it is stock. Highway aggressive driving and I would get that message.
    May 22 2020
    Texas
    Quote Originally Posted by iStig View Post
    Really, ok so I'm not the only one. Did you just live with it? Or take it to get diagnosed?
    Veteran Member Three Rings 0000 RS5's Avatar
    Jul 13 2015
    Who’s tune? And what version?
    May 22 2020
    Texas
    Quote Originally Posted by 0000 RS5 View Post
    I have Apr stg 1 93 file. I did post that in my statement btw.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Good post. I have done exactly what the OP has said in the past, we even had the same cars too. I told my service advisors, mechanics, salesman and sales managers all I do to my cars from day one, they know me for years from buying cars from them all the time from the same car chain of dealers that sells other brands. We do exactly what the OP is saying, do as much as they can as far is warranty or recalls without having to connect the OBD 2. I traded them 3 tuned cars (A3 with APR, S3 with APR and A6 with APR), the only "negative thing" is that they keep telling me that they couldn't certify my cars when they had to sell them due to the tunes. I even met people that purchased my cars, the sales people sometimes tells them who owned the car(me). My last S3 is now owned by an owner that loves the tune.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Jul 13 2015
    My bad, you did. What version of the tune. This was fixed for me going from 1.3 to 1.6.
    May 22 2020
    Texas
    Honestly I don't know. I got tuned about 2 months ago. How can I check?
    Jul 13 2015
    If you have the mobile app (and Bluetooth module) then you can check it there. Otherwise you’d have to ask the shop you had it installed at. APR should be able to tell you as well.
    Established Member Two Rings legacypgmr's Avatar
    Feb 12 2012
    3rd rock from the Sun
    Quote Originally Posted by S3DUDE View Post
    So long as the salesmen tell the prospective new owner that the car has been tuned and would most likely NOT be covered under warranty of any kind I guess I'd have no problem.
    Better still it should also be included on the sales agreement - for the dealer's protection. If not, that dealer would probably lose the ensuing lawsuit.
    Feb 12 2012
    By-the-by, I don't know how, or even if, Audi does it, but even without hooking up to their computer with the flash still there, whether you flash the tune back or not, it is incredibly easy for the car's computer system to "know" the tune HAD BEEN applied.
    May 02 2019
    Quote Originally Posted by legacypgmr View Post
    It's a read/ write counter and ask they have to do is annotate the number of times in their system. If they have 002 and you have 003. You're TD1.
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '19 Volvo XC60, '05 Honda S2000 ITBs
    Schonaich, Germany
    Dealerships can only deny warrantied repairs if it is a direct result of the modification. Having a modified car does not void the warranty. Magnuson Moss Warranty Act.
    18 Catalunya RS3 Unitronic Stg 2/TCU Stg 2, APR DP & Intake, CTS Intercooler, 034 MPs, ECE Dogbone (0-60-3.18 : 1/4-11.16 on 98 RON) & 05 S2000 w/ ITB setup
    Gone, but not forgotten- 19 C43 AMG / 12 Abarth (full bolt on) / 07 JHM SC'ed / 08 Evolution X (full bolt on) / 05 M3 Dinan SC'ed / 05 LGT w/ Hybrid Turbo ......and many others!
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
    Apr 04 2012
    2019 RS3 Ara Blu
    Quote Originally Posted by MarcusDubya77 View Post
    That doesn't really work when you take it to court unless you have a couple million to spend on lawyer fees and years in court. So Yes that exists but your unlikely to get ahead in costs.
    Unitronic 1+ ECU/TCU: Tyrolsport Deadset Subframe locking kit: ECE Rear Motor Mount : Unitronic 4 inch turbo Inlet : APR Ignition Coils : VTT Silicone Charge Pipes : NGK Race Plugs : Whiteline Rear Sway Bar : 034 Motorsports mid-pipes : 034 Open Carbon Intake System : CTS Intercooler : 20% Suntek Ceramic Tint
    Feb 08 2013
    Schonaich, Germany
    Quote Originally Posted by allerum View Post
    Okay, believe what you want.
    Apr 04 2012
    2019 RS3 Ara Blu
    I don't see how it goes any other way. If you complain that the tune didn't break it and they do. You take them to court and they are going to have corporate lawyers and they are going to state because of the tune such and such parts were over taxed. You will then have to prove that these parts are not overtaxed and it was a manufacturing defect. I would like to know how else that would go? If you prove the mechanical parts were defective then yes you would win in court and your warranty would be honored for that repair.
    Apr 20 2018
    Chicago
    Good luck with that. Meanwhile your car is sitting there unable to drive until the dispute is litigated and eventually you lose in court. Dealer will work on basic stuff under warranty so it's not that nothing is covered, but anything remotely related or even a small chance related to tune or parts will get denied. That should be the baseline assumption vs some Act someone thinks will scare Audi into covering your fix.
    Feb 06 2018
    Tail of the Dragon
    I'm tuned, had airbag recall done (twice) and didn't get flagged afaik.
    Mexico Blau RS3.
    Mar 11 2020
    Under Blue Skies
    Quote Originally Posted by MXblau View Post
    Did you check your service paperwork for TD1?
    Feb 08 2013
    Schonaich, Germany
    Like I said, you all can believe what you want based off of your experience. I am not here to argue, just to tell the truth from my perspective. I have yet to be turned down warrantied work based on modifications. However, any work that had to be done was not tied to a modification. Also, I didn't try to fool the dealers by getting work done that could have been caused by modifications. I am more than willing to provide you examples if you can't figure that out. So, yeah, Magnuson Miss Warranty Act..
    Nov 06 2017
    Vancouver
    Depends on what you're dealing with. If you're tuned and say, break an axle, it's not going to be covered. If the wiper motor fails, it should be, this is mostly common sense.
    However there are grey areas and/or people that just don't want to believe it is possible their modification caused a problem. This is where Audi will say 'sorry about that' and now the onus is on you, which is where lawyers come into play. So what those other guys are saying is absolutely right.
    Feb 08 2013
    Schonaich, Germany
    Wait.... I am pretty sure I explained that in my first post. I pretty much simplified something you all seem to be complicating. I thought this was a forum to help fellow owners, not scare them into unwillingness to take their cars in for warrantied work...
    Nov 06 2017
    Vancouver
    The thing most people are worried about is TD1 status, which can be triggered any time the vehicle is connected to the Audi system, whether warranty work is being performed or not.
    Feb 08 2013
    Schonaich, Germany
    Then don't modify your car. You are not going to fool a dealership by trying to hide the fact that your car is modified. They know what these engines have been engineered to handle. However, don't spread false information about work that could still be covered under warranty. There are people on the forums that a lot of this is still new to.
    Nov 06 2017
    Vancouver
    Are you talking specifically to me? Because my car is not modified, and I completely agree with you.
    Feb 08 2013
    Schonaich, Germany
    Not at all. I am just trying to clarify any misinformation being spread around.
    Junior Member Two Rings
    Jan 26 2015
    trinite
    Got my airbag recall done while I was APR
    No TD1, they have some way around it if they know what they are doing
    I was honest and told them I was tuned and not to hook it up, and the service tech wrote a note and walked over and told the shop manager
    Oct 18 2017
    Michigan
    Yeah i mean if you're in with the service guys they will not TD1 you for simple stuff like recalls or issues not related to the tune. If your engine has a major issue though you can bet they aren't just gonna look the other way and go "oh well he was never TD1 so we'll handle $20k worth of work free of charge under warranty".
    Insta: Mattyrs3
    Jan 26 2015
    trinite
    Oh for sure
    IIf something with the drivetrain goes it’s on me
    But when my window was singing going up and down, I took it in and had it fixed no problem
    Feb 08 2013
    Schonaich, Germany
    One other thing to keep in mind when you take your car in for service and aske them not to scan it. I am about 99% sure that it will be annotated by the technician into the maintenace record to cover his ass. They will, most likely, be able to deduce that the car was tuned based off of that info alone or.... they could easily still pass blame to owner for not allowing them to scan the engine during prior visits. Its just easier to be forthcoming, and understand the risk, or just stay stock.
    Mar 11 2020
    Under Blue Skies
    Small stuff like window regulators or items with lower cost I can see how it will be warrantied with tune. But if anyone expects their dealer or Audi to repair/replace high cost parts like an engine, transmission, Haldex. etc. with a tune, I think that's fantasy. That being said, I have heard of dealers even denying window regulator repair/replacement under warranty if you have tinted windows...
    Aug 13 2014
    Central Ohio
    S3DUDE; we've conversed before. And we seem to think the same in some regards. I did not have luck your luck in trading my tuned S3 in with my dealer however. They informed me it would be difficult to resell due to the tunes. Even though the car had already reached the 4 year point and original warranty was basically over. Found a few offers on the S3 but they didn't pan out. My daughter actually bought the car from me in the end. And is in love with it! Makes her commute much more enjoyable. I can also answer any questions she may have about the car. Which brings me to another question, after the warranty period has expired, does a TD1 mean anything at all? Unless I get some kind of extended warranty, I see no reason why the Audi service guys can't connect to the network post warranty expiration regardless of tunes on the car. It is what it is at that point. I'm currently not worried about any non major recalls but would think there may be some MMi or other system updates for the car I'm not receiving because the car isn't connected to the Audi network.
