Results 1 to 15 of 15
    Veteran Member Three Rings n8vs3's Avatar
    Jul 10 2016
    AGM battery coding on OBDeleven. "Fleece" or "Binary-AGM"?
    I recently installed an Autozone DuraLast platinum AGM battery on S3. When I was doing the battery coding, I didn't see "AGM" so I picked "Binary-AGM.". Then I read that fleece may possibly be common european name for AGM battery?
    So which option are people using when coding their AGM battery?
    Nov 17 2014
    San Francisco, CA
    I used binary agm as it's the only option.
    Sent from my Pixel 3 XL using Tapatalk
    Jul 10 2016
    Ok, thanks. Read somewhere that fleece can also mean AGM. Hopefully more people will chime in.
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by n8vs3 View Post
    AutoZone batteries are agm, not fleece. They are interchangeable in wording but fleece is how battery is built. Fleece equivalent are yellow top .
    Junior Member One Ring HmanS3's Avatar
    Sep 29 2018
    '16 S3
    Chicago, IL
    FWIW, I installed the same battery in my '16 S3 last fall and chose Binary-AGM. No issues thus far.
    Jul 10 2016
    Quote Originally Posted by HmanS3 View Post
    Cool..thanks for sharing..
    I emailed tech support at OBDeleven and asked if they can provide clarification. Still waiting for their answer.
    Jul 02 2017
    Irvine, CA
    The correct setting for AGM batteries is fleece. European cars with AGM batteries from the factory are set to fleece. I think it’s a weird translation from German.
    Nov 17 2014
    San Francisco, CA
    Quote Originally Posted by rawrmcrawrrawr View Post
    Here in there states it's set to AGM, not fleece from factory, because as stated before it's how the battery is built ("fabric" in the battery) that determines which setting.
    Jul 02 2017
    Irvine, CA
    Quote Originally Posted by mroberte View Post
    I’ve yet to see an admap with Binary-AGM set from the factory. Everyone who says to use binary-AGM, installed an AGM battery and changed the adaptation themselves.
    Can you please provide where you got the information that Binary-AGM is correct?
    http://www.vwwatercooled.com.au/foru...ml#post1198248
    Nov 17 2014
    San Francisco, CA
    Directly from the car, from factory. Then again when replacing the battery from the dealership.
    The procedure is also laid out in the Odis instructions when replacing.
    Jul 02 2017
    Irvine, CA
    Here are 4 reference admaps of different cars set to fleece from factory. There are many more on the Ross-tech forums. I doubt all these cars were coded incorrectly from the factory. Can you provide an Admap that shows Binary-AGM? What car came from the factory as Binary-AGM? Your own car?
    2017 Tiguan
    https://forums.ross-tech.com/showthr...-4Motion/page2
    2018 Audi A4
    https://forums.ross-tech.com/showthr...Scans-and-maps
    2019 Audi Q8
    https://forums.ross-tech.com/showthr...Scans-and-Maps
    2019 Audi RS3
    https://forums.ross-tech.com/showthr...O-(DAZA)/page2
    Jul 10 2016
    Well, got email reply from OBDeleven tech support and the answer was basically they are not sure which is option is correct for AGM battery sold in the US.
    I will contact Deutsch Autoparts to see if Paul had an answer
    Jul 02 2017
    Irvine, CA
    Another interesting thing is that in Vag Can Pro, Binary AGM is listed as “Bipolar AGM”, which is definitely the incorrect type of battery. The car in the video is set to “Vlies” which is the German translation of fleece. Given all this info, I would set your battery to fleece. I’ve been running my AGM battery for 2 years set to fleece without any issues.
    https://youtu.be/QdGgfvZ7yk0
    Jul 10 2016
    Thanks for sharing your knowledge.. I will search Ross-Tech forum...
    BTW, I just called Deutsch Autoparts and spoke with someone (not paul), but my question was deferred to manufacturer..so that wasn't helpful since the company behind OBDeleven didn't have an answer.
    Jul 10 2016
    2017 Tiguan
    2018 Audi A4
    2019 Audi Q8
    2019 Audi RS3
    Ok..I am convinced after reviewing these factory gateway 19 settings. Will switch to "fleece" on my battery technology setting
