Results 1 to 8 of 8
Thread: Swapping in B&O
    Senior Member Three Rings Trevor08's Avatar
    Dec 19 2012
    Scottsdale
    Swapping in B&O
    Hey guys, I’m looking to buy an A4 that has literally every option (Competition, Manual, Tech, black Optics, mmi, premium plus) But doesn’t have B&O. This is a deal killer for me...unless it’s reasonable to add the B&O after the fact.
    The car is a good price and fits everything I want, except the B&O. I’ve had cars with the B&O in the past and it’s really important to me, but it’s hard to not pull the trigger on this one since it checks literally every other box I need checked!
    How hard or dumb is it to get a Used B&O system and install it?
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Really dumb. lol
    Veteran Member Four Rings mtroxel's Avatar
    Feb 24 2004
    Minneapolis
    I was really, REALLY disappointed with the B&O in my B8. I came from a B7 that had Bose, and I think that name is highly over rated, but it was quite a bit better than the B&O. I could name 2 or 3 songs that I knew well, and in my B&O there were instruments I couldn't even hear. I solved it for me, but suffice to say, I don't think B&O is a "must have" by any means.
    These companies sell their logo to car-makers, put together something that meets marketing's budget, and they both make money on the "upgrade". You are the only loser in that arrangement.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Three Rings weagle1856's Avatar
    Dec 15 2015
    Audi TT 225, Audi A4 Avant, VW CC, BMW X5
    Denver
    I actually love my b&o and would say it's worth it.
    Most people that disagree say that there's not enough bass. I think it's adequate and balanced. If you want the correct answer though, you should go drive one with B&O and see for yourself. Test the different audio sources too
    Sent from my Nokia 9 using Audizine mobile app
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    The retrofit is a good bit of work because the wiring harnesses are different. The added speakers do sound nice though. If you are up for it, I have an entire kit for sale right now in the classifieds section. You would need a harness but I believe that can be found here: https://www.aliexpress.com/item/32869909856.html
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Jul 16 2018
    Atlanta
    It wouldn't be hard to swap in the B&O amp and speakers at all, if you're familiar with car audio work at all. You'll need new sail cards with the holes for the 1" tweeters, but I'd expect the rest to be the same. Checking, the rear deck cover is the same for 9VD or 9VK (though only 9VK has mids mounted in the rear deck).
    If you're looking for an already developed system to just drop in, B&O is an upgrade over the non-B&O. But if I was going to dig into the car and change stuff out, I'd be more apt to swap in some good aftermarket equipment. Since you have MMI, you'd need a MOST bridge to get outputs to send to normal aftermarket amps, but these do exist.
    Dec 19 2012
    Scottsdale
    Hey man! Where are you located?
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by Trevor08 View Post
    Maine but willing to ship all the parts. Shoot me a PM if you are interested.
