Results 1 to 4 of 4
    Junior Member One Ring
    Sep 23 2019
    New Jersey
    Audi A4 B8 Misfire #3
    Have audi A4 2009 115k miles bone stock, which have a cylinder misfire #3. Replaced the spark plugs, and coils.still the same problem. Check for spark on all coils and they are getting spark. Did a carbon clean up, by taking the IAT sensor from the intake manifold ( using seafom) , seen to run better while i was doing it, alot of smoke, thought it will be better. No, still have the same misfire lol.
    At this point i been checking forums and no luck, any help!! Thankss👍🏽🤟🏽
    Might be injector 3? But i heard these injector barely goes bad, so im confused..
    Thanks in advance
    Veteran Member Four Rings LionKing's Avatar
    Mar 09 2017
    2009 A6 Avant - 5.2L V10 Swapped, 2013 S4 Backroads Warrior
    MD
    Injectors are actually a SUPER common problem. Sticking open or sticking closed. That would be my bet. Granted we have piston ring issues but that itself usually doent cause issues. Have you had chain and tensioner replaced yet?
    Sent from my LM-V450 using Tapatalk
    "Exhaust Gases go in the turbocharger and spin it, witchcraft happens, and you go faster"
    Sep 23 2019
    New Jersey
    i bought the car from a non name dealer a couple months ago, dont know the history. I was going to do it just to make sure, but with this problem dont know if it worth it.
    Thanks, im going to give a shot on the injectors since theyre 200$.
    Thanks i keep you guys posted!
    Thanks again!!
    Senior Member Two Rings Vinhouw's Avatar
    Jan 14 2014
    my two feet
    Tampa, FL
    Most likely the injectors. I had issue like you...i was on the freeway, accelerated and misfired. Change coils and sparks, and did carbon cleaning. My high pressure fuel pump was toasted too which overworked my injectors. They are toasted. With injectors replacement, might do a manual scrubbing to remove all carbon. I just hit 158k. 2011 A4 bone stock. Now i need to change my suspension set up..my rear shocks are bad apparently according to Audi. I’m running solowerks.
    Hope it helps!
