Hello guys, I'm new here and need a little help for a diagnosis.
Lately I was planning to do a timing belt job on my recently acquired a4 b7 2.0 tfsi only to find out after a quick check that the cam follower was completely destroyed. So an intake cam - follower - hpfp replacement was needed too. So I did all of these and while I was at it, I put a new chain and tensioner. I have to mention that the car was running well, no misfire and had no codes before.
For the job itself, I used the alignment tool and counted the links (followed the 18-19 links rule) for the chain job, because I know it's the best way to be accurate. For the timing belt, the timing marks all lined up after a couple of manual rotations of the engine. I even counted teeth on the belt between marks I had made just to be sure to transpose the new belt at the same place as the old one. Everything else I did according to Bentley, Elsawin and some other online resources like DIY's here and youtube like Astral Auto repairs channel (thanks everyone).
When I first started the car after (cold start), it ran fine for about 30 seconds to 1 minutes at approx 1100 rpm, then the rpms dropped to 800-900 and the car started misfiring. So I thought this is weird. I revved it to 1100 again, then 1500, then 2000 and engine feels smooth, no misfires. I went back to check, timing is according to specs : timing belt, all marks still lined up, tensioner is set the right way; timing chain, the right number of links is spot on, tensioner does his job and the 3 o-rings for the adjuster are in good condition (I had replaced these). When the engine is warmer, misfire starts right as the engine starts because the engine doesn't have the small period where it sits at 1100-1200 rpm on a cold start, but it rather instantly picks its idle at 800-900 rpm.
I have a basic scan tool, but no VCDS, and codes are :
P0016 : Crank/Cam Position Correlation
P0300, P0301, P0302, P0304 : misfire, random and cylinders
P0171, P0174 : System too lean
P0000 : ?
So I switched spark plugs, and it changed nothing (not surprising), same for coils. I changed camshaft position sensor and nothing too. I visually checked for vacuum leaks, doesn't seem to be the cause. All PCV lines are well connected.
Anyone have any ideas why it is misfiring at idle, but not with increasing rpm ? I don't understand what could cause this besides the timing if the timing is visually to spec...
Also, any input would be appreciated
Thanks
Thompson
