Results 1 to 2 of 2
    Jan 26 2006
    Denton, TX
    Need some quick TB advice....
    I am doing the water pump install and I noticed that the original gasket is metal. The one that came with the hepu wp is rubber(?). Do I need to use some blue stuff (gasket sealer?)? Or will it be fine just torqued down?
    07 Ibis White A4 2.0T 6MT
    04 Silver S4 - Stock .... for now
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i was told never to use the shitty ruber gasket that came with the kit. So i went and bought my own from the dealer, it was under 5 bucks i belive. But i think it should be fine if you torque it to factory spec. I didnt trust it tho.
