Page 1 of 3 123 LastLast
Results 1 to 40 of 120
Hybrid View
    Established Member Two Rings V6Quatt's Avatar
    Dec 16 2011
    England
    Lowered Spring recommendations
    Recently I have been considering to lower my S5 B9 on springs not coilovers
    What would be the best cost effective lowering springs for the S5 B9 mine is a coupe
    A few questions:
    What brand springs work well with the stock S5 shock absorbers
    What is the ride like
    Has anybody installed other type springs for example adjustable height spring on their S5
    What would you recommend
    Established Member Two Rings SonnyS4's Avatar
    Jan 28 2020
    2018 Audi S4 (Gone) 2011 BMW 335i xDrive (Gone), 1997 BMW 328i (Gone)
    San Francisco
    I just ordered 034 springs for my S4. These and EMD springs seem to very popular on here for the b9 platform. They’re both a modest drop and don’t compromise ride quality too much. ABT & KW height adjustable springs are a solid option if you want more adjustability and don’t mind spending a little more
    '18 Audi B9 SQ5 Prestige - Azores Green / Black Napa / S Sport / Dynamic Steering / DAP / Cold Weather / Carbon Atlas / Trailer hitch
    Gone But Not Forgotten:
    '18 Audi B9 S4 - Prestige / Daytona Grey Pearl / Magma Red Napa
    '11 BMW E90 335i xDrive - Space Grey / Black / M Sport
    '97 BMW E36 328i - Titanium Silver / Dove Grey
    Dec 16 2011
    England
    Quote Originally Posted by SonnyS4 View Post
    Thanks SonnyS4
    Do you have a link to the 034 springs I'm from the UK How low do they lower the S5? modest drop is preferred .
    How do they compare to H&R or Eibach springs
    Jan 28 2020
    San Francisco
    Quote Originally Posted by V6Quatt View Post
    Thanks SonnyS4
    I want to say H&R and Eibach will have stiffer spring rates than the 034 and maybe a little more of a drop but I’m not 100% sure about that.
    Front strut and rear sway bar from 034 make a big difference as well if you want even more handling performance.
    https://store.034motorsport.com/dyna...9-audi-s4.html
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    Heard good things about HR Sport springs also. Found this coupe on HR and 20s.
    I’m probably going to go for the same.
    -cW
    2023 X3 M40i Alpine White
    Dec 16 2011
    England
    -cW
    The ride height seems sensible on this S5
    Dec 16 2011
    England
    -cW
    Do you know the part number for the H&R springs for the coupe as i believe there are 3 types 25mm 30mm or 35mm?
    Nov 06 2009
    2023 X3 M40
    NYC / DC/MD/VA
    https://www.ecstuning.com/b-h-and-r-...-set/50385~hr/
    -cW
    Veteran Member Three Rings Gryphon001's Avatar
    Apr 14 2009
    2018 S5 Sportback, Daytona Gray - 2008 Audi A3, S-Line, Ti, 6MT
    Mississauga, Ontario, Canada
    Look into the height adjustable springs... the regular drop springs are not always an even drop. I used to have H&R springs on my 2008 A3 and the ride quality was quite good... so now I got the H&R adjustable springs. But I haven’t installed them yet.
    Bearing in mind that the adjustable ones might be almost double the price is the standard ones.
    Those seem to be the most common/popular brands that get good reviews from people, H&R and 034 Motorsports.
    Dec 16 2011
    England
    Quote Originally Posted by Gryphon001 View Post
    Thanks ...I will look into the height adjustable to before making a decision. I just don't want the car becoming too bouncy
    Apr 14 2009
    Lowered Spring recomendations
    The springs themselves look pretty similar to the regular H&R springs.
    You just get these mounts to adjust the height they sit at relative to the mounting points.
    I don’t think the ride quality is likely to be any different from the standard H&R springs. The ride quality in my A3 certainly didn’t suffer any and it was definitely not bouncy. Only slightly firmer than stock. As for this application, I won’t know for sure until I actually install them. First I have to sort out some warranty issues with Audi before I will start messing around with installing aftermarket components.
    Senior Member Three Rings Valentino S5's Avatar
    May 26 2019
    Mexico City
    I have 034 Motorsport springs. Very happy with results. Drop about 0.9” F/R. Ride quality is just a bit stiffer than stock (as expected) but gained a lot in dynamics. For me, lowering springs and front strut brace are 2 of the best mods for your suspension. A must have. Here’s a picture after lowering springs installed
    2019 S5 Coupe Mythos Black. EPL Stage 2 ECU+TCU. APR Intercooler. APR Ignition Coils. AWE AirGate Carbon Intake. Red Star Downpipe HJS 200cpsi. VPS Pre Muffler/Front Resonator Delete. ECS Big Bore Cast Aluminum Turbo Inlet Pipe and Silicon Turbo Inlet Hose. Pedal Commander Throttle Control System. 034 Motorsport Lowering Springs, Front Strut Brace & Transmission Mount.
    Dec 16 2011
    England
    Quote Originally Posted by Valentino S5 View Post
    Thanks the 034 seems popular and looks like a nice drop the motor looks sweet. Anymore angles?
    Oct 23 2019
    New York
    H&R springs
    Apr 14 2009
    Quote Originally Posted by delfred91 View Post
    H&R springs
    Nice stance
    ... and very nice ride.
    Aug 23 2017
    Bay Area
    H&R springs
    So cleannnn
    Oct 27 2019
    Tampa, Florida
    Are you using spacers?
    Oct 23 2019
    New York
    Quote Originally Posted by wiltedjoint View Post
    15mm in the front and 18mm in the back..no rubbing and maybe even space for 2mm more for both front and back.
    Veteran Member Three Rings TeflonS4's Avatar
    Toronto, Canada
    Do you know the offset of your wheels?
    B9.5 S5 SB Mythos Black
    Previous: B5 A4 | B6 A4 | B7 S4 | B8 S5 | Type 42 R8
    Others: E60 M5 | E71 X6 | W221 S550 | N400 V8 Vantage | GR Supra
    Oct 23 2019
    New York
    Quote Originally Posted by TeflonS4 View Post
    20x9 +34. These are the stock S5 black optics wheels
    Veteran Member Four Rings SHCKR's Avatar
    Jan 03 2019
    '19 Subaru Ascent
    NC
    Reach out to @Mops@Nemesis , he gave me a good description of different options available, and how they ride comparing to stock.
    '18 S4 Prestige; all packages
    Dec 01 2019
    Kirkland, WA
    Just got my 034 springs installed yesterday. I also have the H&R sway bars, front and rear. The car handles awesomely! Springs added a slight increase in ride stiffness but still very comfortable. Corners so flat. Here before and after pics. IMG_1688.JPGIMG_2258.JPG once I have a little more drive time, I’ll post a review.
    Dec 16 2011
    England
    Awesome much improved look.
    You happy with the stance...
    Quote Originally Posted by Fallstar View Post
    Senior Member Two Rings BrandonS's Avatar
    Mar 26 2012
    Do you have any more side shots now that everything has settled? I have the exact wheel setup and am considering switching from my H&Rs because I find it sits a bit low for my liking
    Apr 12 2018
    ga
    I installed my 034 springs on Saturday and initial impressions are positive. As others have stated, modest drop, slightly stiffer than stock in a good way (still retains audi comfort) and improved handling dynamics. Added a front strut brace yesterday and plan on installing my rear sway bar today to complete the handling upgrades.
    Toronto, Canada
    Everyone looks like their drops result in pretty even front/rear gaps. I have HR springs and I'm not sure why but the car is dumped on the front versus the rear.
    Veteran Member Three Rings idrinkv8's Avatar
    Nov 01 2008
    Whats the part number for the springs you got?
    Toronto, Canada
    Quote Originally Posted by idrinkv8 View Post
    H&R Springs - 50385
    Nov 01 2008
    H&R Springs - 50385
    I would get in contact with H&R and send them the pictures… That is most certainly not installed correctly as you’re about a half an inch too low. Are you able to reach in and take a picture of the spring and the seat where it sits
    Active Member One Ring DanielWayneJR's Avatar
    Jun 04 2013
    2015 Denali HD, 2015 Porsche Panamera
    MO
    My S5 Sportback sits about the same way. I called H&R and sent them a few pics thinking the car was sitting too high in the rear. Here is part of their response.
    I’ve reviewed the photo with several of my colleagues, and it does appear to lower appropriately.
    I do see the gap at the rear of the car, but on stock S5’s the rear end appears to sit a touch bit higher from the factory, our kit was designed to mimic that result only lower.
    To verify the proper springs are installed, the 50385 kit comes with the following springs:
    Front: 28757VA w/ a red paint mark
    Rear: 28757-5HA
    My car is not sitting on bump stops front or rear, it’s just not as low in the back as I expected. I did compare to a photo with stock springs (same wheels installed) and it did have the same rake, so I took H&Rs response as good enough. Wondering if there’s another option to get a little lower in the rear or if I should just order the adjustable springs.
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    With all these lowering springs the bumpstops must be trimmed or you can get odd looking heights and not the greatest ride quality. The H&R lower springs certainly ride on the bumpstops when they are not trimmed.
    Also cars that do not have certain options may sit differently, amount of gas in the car, items in the car, etc.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Apr 12 2018
    ga
    I stayed away from H&R because I had seen others with the same stance.
    Quote Originally Posted by [email protected] View Post
    Cheers,
    I disagree re cutting bumpstops. 034 is a mild drop a nowhere near sitting on the bumpstops when at rest. Vehicle options/ full tank/ items in the car is not going to explain differences like what we see between abiley84 H&R and TeflonS4 H&R drop.
    Aug 07 2008
    Dallas, TX
    Quote Originally Posted by dkmesa View Post
    I can guarantee that if the bumpstops are not trimmed on the H&R that it can yield an odd looking and driving A/S/RS5. I say this because when I first installed H&R springs on my S5 I did not trim and the car sat oddly, lower front, higher rear. I inspected and found the rear bumpstops were effecting the resting ride height. The front was almost touching as well and in time would have when the springs settled. I trimmed front and rear bumpstops, the rear came down visibly as the springs settled and the front now actually has proper suspension range of motion without contacting the bumpstops.
    With springs that lower less than the H&R springs it's still a requirement to trim the bumpstops if you want the car to ride without hitting them repeatedly. Bumpstops are not meant to be part of the suspension that holds weight or is repeatedly contacted/used. With stock suspension heights the bumpstops are used to avoid hard contact with the chassis and disallowing the shock internals to bottom out under very large suspension movement. This means that any larger movement of the suspension engages the bumpstops adding a massive change in spring rate during contact, bumpstops increase the spring rate massively when they are engaged which is not their intention.
    That is how little room there is with a half trimmed bumpstop with this car which has H&R springs:
    My S5 sat normally front/rear after the bumpstops were trimmed, the rear being the most effected. Every single lowering spring or adjustable spring kit for these models requires the bumpstops be trimmed for proper suspension travel and/or in some cases proper resting ride height.
    Cheers,
    www.europrice.us
    [email protected]
    Mar 26 2012
    Cheers,
    Hey Alex I'm dealing with the same issue on my b9.5 at the moment, with the front being super low and the rear being too high in comparison. So you noticed the front came up after trimming? did you have to pull all of the suspension to do the trimming?
    Dec 16 2011
    England
    yeah would like to know also as H & R say they don't need trimming
    Jun 14 2013
    Long Beach, CA
    I'm on the same H&R Sport Springs and mine is not dumped like that at all. I know mine is an A5, as compared to your S5 but the drop is advertised the same and I've seen many S5s with the same springs dropped like mine. Regarding the bump stops, I actually have no idea if the shop who installed it trimmed it.
    2019 Audi A5 Sportback Premium+ | Ascari Blue Metallic | Black Optics | S-Line Sports Package | Bang & Olufsen | Feynlab Self-Heal Lite | H&R Sport Springs | Variant Argon 20x10 | MagnaFlow Cat-Back Exhaust
    2012 Audi A3 Premium+ | Deep Sea Blue Pearl | Open Sky | ST Coilovers | Full LED Interior | RS3 Front Grill | VMR V710 18" Gunmetal | Milltek Non-Resonated Catback Exhaust
    (SOLD)
    Jul 02 2014
    NW indiana
    Quote Originally Posted by abiley84 View Post
    What wheels are those?
    Jun 14 2013
    Long Beach, CA
    Quote Originally Posted by Bsimms View Post
    Variant Argon 20x10
    (SOLD)
    Junior Member Two Rings subie77's Avatar
    Oct 17 2016
    Toronto, ON
    034 here as well. Super happy with the look and ride. Pics below as well as a before and after.
    Sent from my iPhone using Tapatalk Pro
    Sep 28 2010
    NW NC / DE
    Quote Originally Posted by subie77 View Post
    Looks great buddy!
