And the new Scan after EPB module replacement
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 15 16 17 19 42 46 52 53 56 62 72
VIN: WAUZZZ8K88A..... Mileage: 184840km-114854miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (------CABB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K1 907 115 A HW: 8K1 907 115
Component: 1.8l R4/4V TF H07 0004
Revision: A5H07---
Coding: 0104000318070018
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM18TFS8K1907115A A01005
ROD: EV_ECM18TFS8K1907115A.rod
VCID: 2C5D5972470B3F2F1D-8078
1 Fault Found:
7962 - Implausible Data Received from ABS Control Module
U0415 00 [032] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 184835 km
Date: 2019.04.29
Time: 11:10:42
Engine speed: 697.50 /min
Normed load value: 20.8 %
Vehicle speed: 255 km/h
Coolant temperature: 90 °C
Intake air temperature: 26 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 14.449 V
Readiness: 0010 0000
Address 03: ABS Brakes (J104) Labels:. 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 P HW: 8K0 907 379 P
Component: ESP8 front H04 0180
Revision: -------- Serial number: --------------
Coding: 030500
VCID: 46890BDAF1A7E57FEB-8012
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
012 - Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:10:43
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4722
Hex Value: 0x0035
Hex Value: 0xB1B5
Hex Value: 0x00FF
00473 - Control Module for Elect. Park/Hand Brake (J540)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:10:43
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4722
Hex Value: 0x0013
Hex Value: 0x02B5
Hex Value: 0x00FF
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 8K0 907 064 A HW: 8K0 907 064 A
Component: BCM2 1.1 H70 0132
Revision: 00002001
Coding: 031100
VCID: 2E59537A79174D3F33-807A
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H35 0052
Serial number: 0508000004796004
Subsystem 2 - Part No SW: 8K0 905 852 C HW: 8K0 905 852 C
Component: ELVAUDIB8 H35 0039
Serial number: 0208000006826001
2 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 132
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:12:57
02823 - Requirements for Locking the Steering Column Lock not met
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 92
Mileage: 184839 km
Time Indication: 0
Date: 2019.04.29
Time: 12:45:49
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 8T2 820 043 K HW: 8T2 820 043 K
Component: KLIMA 1 ZONE H05 0120
Revision: B0000000 Serial number: 0107.02.080548
Coding: 64040000
VCID: 3A716F2AB55F919F9F-806E
No fault code found.
Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
Part No SW: 8K0 907 063 HW: 8K0 907 063
Component: BCM1 1.0 H21 0253
Revision: 01021001 Serial number: 00000000002878
Coding: 690040B1001400000001000000005F5F001D02080000000100 0000
VCID: 6CDD99728F8BFF2F5D-8038
Subsystem 1 - Part No SW: 8K2 955 119 HW: 8T2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 080208 H05 0060
Serial number: SWFBIE 0000045
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 941 531 B HW: 8K0 941 531 B
Component: E1 - LDS H07 0070
Serial number: 00000000001102080143
1 Fault Found:
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 92
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:02:00
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD136U63
Coding: 30363434363030303030554A3052384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_A02.rod
VCID: 3C7D6932B76BAFAF8D-8068
Crash sensor for side airbag: driver side:
Serial number: 6334MSME34240612
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME337309357
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME56442F6BU
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME56462C0BO
Crash sensor for front airbag: driver side:
Serial number: 63732SME52760C5B4
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME50591F6FD
Address 16: Steering wheel (J527) Labels:. 8K0-953-568.clb
Part No SW: 8K0 953 568 D HW: 8K0 953 568 D
Component: Lenks.Modul H10 0012
Revision: -------- Serial number: 90304HBC0004G
Coding: 000002
VCID: 3B7F6A2EBA65A89784-806E
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 13
Reset counter: 92
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:02:48
Address 17: Instruments (J285) Labels:. 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 HW: 8K0 920 900
Component: KOMBIINSTR. H14 0216
Revision: 00100000 Serial number: 7VH15V328
Coding: 2F04080002000008010000
VCID: 67D7E65E966DDC7730-8032
Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
Part No SW: 8T0 907 468 D HW: 8T0 907 468 D
Component: GW-BEM 5CAN H04 0084
Revision: GA801030 Serial number: 3000G08128803B
Coding: 000003
Shop #: WSC 00499 209 57114
VCID: 428117CADD8FD95FC7-8016
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H03 0135
Serial number: 18006880010208
Address 42: Door Elect, Driver (J386) Labels:. 8K0-959-793.clb
Part No SW: 8K0 959 793 C HW: 8K0 959 793 A
Component: TSG FA H10 0170
Revision: Serial number: 0000006879502
Coding: 011002204001410001
VCID: 40851DC2D383CB4FD1-8014
Address 46: Central Conv. (J393) Labels:. 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0109511909
Coding: 0100062000390040013001
5 Faults Found:
01518 - Bulb for Back-Up Lights; Left (M16)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 132
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 12:37:53
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 184839 km
Time Indication: 0
Date: 2019.04.29
Time: 12:45:30
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 184839 km
Time Indication: 0
Date: 2019.04.29
Time: 12:46:09
02737 - Bulb for Tail/Fog Light; Right
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 132
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 14:35:54
00985 - Right Tail Light (M2)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 132
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:18:21
Address 52: Door Elect, Pass. (J387) Labels:. 8K0-959-792.clb
Part No SW: 8K0 959 792 C HW: 8K0 959 792 A
Component: TSG BF H10 0170
Revision: Serial number: 0000006837158
VCID: 3F871E3EAE7DB4B7A8-806A
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 D HW: 8K0 907 801 D
Component: EPB Audi B8 H04 0050
Revision: 00000003 Serial number: 10000000010115
Shop #: WSC 00000 000 00000
VCID: 30654D0263235BCF21-8064
1 Fault Found:
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11101101
Fault Priority: 4
Fault Frequency: 2
Reset counter: 91
Mileage: 184835 km
Time Indication: 0
Date: 2019.04.29
Time: 11:07:13
Freeze Frame:
Voltage: 14.70 V
Count: 62
Speed: 0.0 km/h
Hex Value: 0x02F3
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio (J503) Labels:. 8Tx-035-152-56.clb
Part No SW: 8T2 035 152 HW: 8T2 035 152
Component: Chorus3 H19 0020
Revision: 00000001 Serial number: AUZ1Z2H6187808
Coding: 00000480040108000159070000
VCID: 6ED9937AB9970D3F73-803A
Subsystem 1 - Part No SW: 8T0 919 603 HW: 8T0 919 603
Component: Display H09 X017
Serial number: AUZ1Z2H5084523
Address 62: Door, Rear Left (J388) Labels:. 8K0-959-795.clb
Part No SW: 8K0 959 795 A HW: 8K0 959 795 A
Component: TSG HL H06 0170
Revision: Serial number: 0000006849225
Coding: 010002204001210001
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000006850910
End-------------------------(Elapsed Time: 02:42)--------------------------
Tuesday,28,April,2020,16:39:56:00008
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 19.6.0.2
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WAUZZZ8K88A025402 License Plate:
Mileage: 184840km-114854mi Repair Order:
VIN: WAUZZZ8K88A025402 Mileage: 184840km-114854miles
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
Revision: A5H07---
Readiness: 0110 0001
Coding: 030500
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 92
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:36:00
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0035
Hex Value: 0xB193
Hex Value: 0x00FF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:36:00
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0013
Hex Value: 0x0293
Hex Value: 0x00FF
Revision: 00002001
Coding: 031100
Coding: 64040000
Coding: 00FD11
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 92
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:31:00
Coding: 000002
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 92
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:31:48
Coding: 000003
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 92
Mileage: 184846 km
Time Indication: 0
Date: 2019.04.29
Time: 15:31:48
Freeze Frame:
Voltage: 14.60 V
Count: 62
Speed: 0.0 km/h
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
End-------------------------(Elapsed Time: 02:27)--------------------------
