Page 5 of 116 FirstFirst ... 345671555105 ... LastLast
Results 161 to 200 of 4603
  1. #161
    Established Member Two Rings Makes Centz's Avatar
    Nov 08 2018
    Goodyear Arizona
    Quote Originally Posted by 1S32K16 View Post
    Anyone running a DP with the stock cat back? I am trying to gauge how my wife will react. I had a catted DP and res delete with stock cat back on my S3 and she wasn’t pleased on longer road trips with the noise.
    Catless downpipe with all resonators intact.....love it. Cold starts are still pretty loud but after its initial 20 seconds or so it calms down pretty nice. I had no resonators and it was loud as shit, turbo sounded nice on spool but all in all i felt like i was driving a shit can civic with a 3 inch straight pipe 1.6 vtak y0!
    When im in comfort mode at cruise control 75mph the car still sounds stock, just to give you an idea.
    IG: @MAKES_CENTZ
  2. #162
    Established Member Two Rings FFM's Avatar
    Aug 29 2019
    Bellingham, WA
    If you guys are going catless then I would just have the cold start removed via a tune if possible. That high initial rpm is for warming the cat that no longer exists so is pointless.
    Current: R8 V8 6MT | B9 SQ5
  3. #163
    Veteran Member Three Rings dirtysoil's Avatar
    May 23 2009
    23 Tiguan; 22 RS5; 18 SQ5
    Indpls, IN
    I've been running the RedStar 300 CEL DP, with the stock catback for about two months now.
    Cold start is loud enough to hear with the windows closed, but not obnoxious. Just really defined burbles, as expected on a cold start.
    Sport and manual modes you can also tell you've done some work to the exhaust, but it is not obnoxious either. Honestly, I think it is the perfect mix of subtle and sporty. Quick shifts under full load sound really well, lots of raspy burbles! I have not driven in the other modes though (I can't even remeber what they are called😆).
    I also have not taken it on extended trips yet. I can't imagine there is any drone, as I havent experienced any at cruising speeds for short distances.
  4. #164
    Veteran Member Three Rings 1S32K16's Avatar
    Jul 07 2016
    Quote Originally Posted by dirtysoil View Post
    Perfect info just what I needed to know. I figured it would be subtle while keeping everything else stock. Appreciate the feedback.
    One thing I noticed is 034 provides replacement gaskets with their DP for the B9 S4/S5. Do you think it’s necessary to use new gaskets as Redstar doesn’t seem to include them.
    2019 Quantum Gray SQ5 with black optic package, 20% Rayno Ceramic tint, TAG Motorsports Painted Front Reflectors, BMC Air Filter, JB4, 034 Trans Mount, OEM Black Badges, 21’ BC Forged RZ39, Redstar 200cel DP, ODIS factory lowering
    2016 Monsoon Gray S3 with black optic package, Emmanuele design springs, rear sway bar and endlinks, 19' Forgestar CF5's
  5. #165
    Mar 01 2016
    Atlanta
    Installed reverse LED bulbs, nice to see Audi is still shipping cars with incandescent lights where they can get away with it.
    Did a quick writeup too since all I could find were Q7 ones (process was pretty much the same though...)
  6. #166
    Veteran Member Four Rings DiscoDan's Avatar
    Sep 07 2018
    Colorado
    Quote Originally Posted by pabs View Post
    Nice. Where did you get the bulbs?
    2020 SQ5 - Prestige | Quantum Gray | 034 Stage 1
  7. #167
    Mar 01 2016
    Atlanta
    Quote Originally Posted by DiscoDan View Post
    deAutokey, ran a bunch of their stuff in my S3 with no issues in the 4 years I had them. Way brigher than the Ziza ones I had tried from ECS.
  8. #168
    Veteran Member Four Rings Chris.green's Avatar
    Aug 09 2017
    Atlantic Canada
    Are the other bulbs in that housing led? If I’m going to go tot he trouble of changing the reverse lights I may as well do them all while the housing is out. Do you know what other bulbs are in there?
    2020 SQ5 | Glacier White Metallic
    BC Forged TD03 | CETE Lowering Module | Forge DV
    034 Transmission Insert | CTS Turbo Inlet
    AWE Coldfront | RocEuro Intake | 034 Strut brace
    IG: chrisssgreenwood
  9. #169
    Mar 01 2016
    Atlanta
    The other 2 bulbs in the housing to the left and right of the reverse light behind the red lenses don't look like they are LED (I didn't pull them out to confirm though). Didn't replace them on mine as it didn't really bother me as opposed to the really yellow reverse light. I honestly didn't really play too much with the light switch so I don't know when the other two bulbs light up. I'd guess rear fogs and perhaps parking light?
    The entire design was a bit odd to me as the bulbs are attached to a grey plastic assembly that has the contacts inside it that in turn makes contact with the housing to supply the bulbs with power. How much do you want to bet Audi doesn't sell those plastic socket/bulb holders separately and it comes as an entire unit only.
  10. #170
    Nov 08 2018
    Goodyear Arizona
    Quote Originally Posted by FFM View Post
    Find me someone that can do that for me. :)
    IG: @MAKES_CENTZ
  11. #171
    Sep 07 2018
    Colorado
    Thanks. What exact lights from deAutoKey? They have a few options for the SQ5 on their site and it's not clear what is exactly the correct replacement part.
  12. #172
    Aug 09 2017
    Atlantic Canada
    https://deautokey.com/product/choose...r-bumper-tails
    I’m tempted to buy the whole set but I think being in Canada will yet again kill me on exchange and shipping. Maybe I should just take a chance on cheap ones on amazon
  13. #173
    Apr 23 2020
    Atlanta, GA
    Quote Originally Posted by Andor View Post
    That’s exactly where I ordered from. Took a bit to arrive but perfect fit.
    I got my paddles today and they fit the factory set fine but the tip of the new ones is hitting the wiper arm. I move the speed switch to the left and it helped. Did you have the same issue?
  14. #174
    May 23 2009
    Indpls, IN
    Getting those screws back in was a pain in the dick!😆
  15. #175
    Aug 29 2019
    Bellingham, WA
    Quote Originally Posted by Makes Centz View Post
    It should be an option from any of the available tuners. Surprised it’s not even mentioned.
  16. #176
    Aug 09 2017
    Atlantic Canada
    Just finished changing out the reverse bulbs. 5min job thanks to your write up. Ended up just getting bulbs off amazon to test. If I don’t get a light out error i’ll end up swapping out all the bulbs
  17. #177
    Aug 29 2019
    Bellingham, WA
    Feynlabs ceramic coat applied on Friday and all cured up today
  18. #178
    Jun 28 2015
    San Francisco
    What did you do to your B9 Q/SQ5 today?
    Finally put on spacers. 10mm front and 15mm rear.
  19. #179
    Veteran Member Four Rings phillyquattro's Avatar
    San Francisco, CA
    More like what I wish I didn't do to my SQ5 today. I tried to murder the Michelin man. First time in 6+ years that I've curbed a wheel and boy was it a doozy. Ugh. Guess I'll be looking to refinish these now.
    2019 GT3 Touring
    2019 SQ5 Premium+ (Build Thread)
    2016 S3 Premium+ (Build Thread)
    IG: brandongray
  20. #180
    Aug 09 2017
    Atlantic Canada
    Quote Originally Posted by phillyquattro View Post
    This is heart breaking and a horrible fear of mine with expensive wheels like that. What happened??
  21. #181
    San Francisco, CA
    Quote Originally Posted by Chris.green View Post
    I was heart broken yesterday but I've moved on a bit today. Shit happens. I already have a few chips from rocks, stains from liquids, etc. Just is what it is. I was making a turn at an intersection and was talking to and looking at my dog in the trunk in the rear view mirror. Just took the turn a little tight apparently and that particular curb was apparently quite sharp and had it out for ole rubber man. I was already debating getting new wheels or maybe painting these ones. So at a minimum I'll get these refinished and either keep them or flip'em and switch it up.
    2019 GT3 Touring
    IG: brandongray
  22. #182
    Jul 07 2016
    Ooh I would sell my RZ39’s to any takers and try to grab them from you lol.
  23. #183
    May 10 2020
    B8 A4
    Nashville area, Tennessee
    buy it...
  24. #184
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
  25. #185
    San Francisco, CA
    Make me an offer and spare me the trouble of trying to figure out what color to refinish them. LOL.
    Quote Originally Posted by designermonkey View Post
    buy it...
    Welcome to the club!
    Quote Originally Posted by Bezlar View Post
    No idea what the emojis were you used. Do they show as broken images for others here? :-(
    2019 GT3 Touring
    IG: brandongray
  26. #186
    Aug 09 2017
    Atlantic Canada
    I can’t see them either
  27. #187
    Jul 07 2016
    Looking for any intercooler feedback, I know there is the one from Forge or AWE. Both seem to be plug and play with no modification needed. Anyone running or know of any other options. AWE is a few hundred less than the forge
  28. #188
    San Francisco, CA
    I have the AWE one and have been happy with it. Install was plug and play, no modifications of any sorts. There is also one by a company called Rev9 that can be had for $500 or less depending on if you can catch it on sale. I think Makes Centz is running that and a fair amount of B9 S4/S5 guys are as well. I believe the SQ5 has slightly different mounting than the S4/S5 so not sure if it's a perfect fit out the box or not.
    2019 GT3 Touring
    IG: brandongray
  29. #189
    Aug 09 2017
    Atlantic Canada
    I made a thread not long ago about the Rev9 intercooler and Make Centz said he installed with the provided brackets
    https://www.audizine.com/forum/showt...8880-Rev9-FMIC
  30. #190
    Jul 07 2016
    Awesome thanks, I read through a lot of the S4 threads also. Glad to hear it is a direct fit with the included hardware. Now to figure out when it will be back in stock. That is a tough price to beat.
  31. #191
    Aug 09 2017
    Atlantic Canada
    Unitronic and CTS turbo also have intercooler options as well
  32. #192
    Apr 05 2006
    992 c4s
    Blue Springs
    Just sad face. Sucks about such nice wheels.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
  33. #193
    Jul 14 2009
    Pasadena
    I am also running a set from ijdm toy on my q3 and sq5 without issue. about half the cost of deauto
    IG: @matthewee
  34. #194
    Jun 14 2020
    Vancouver BC
    Installed a Roc Euro intake!
    I also drilled the butterfly nuts and attached parachute cord so it’s not impossible to get them back out of the frame rail.
    Sounds great! Unfortunately only sat in traffic with small gaps to accelerate, looking forward to getting it on an open road!
  35. #195
    Mar 01 2016
    Atlanta
    Quote Originally Posted by Vancity-MK II View Post
    I had to look up an install video to see what the butterfly nuts were for, pretty clever solution you came up with! At least you don't have to modify any chassis bolts or cut a hole in your intake like ones that cost 3x the price of that Roc Euro.
    Last night I got around to coding a few things like disabling the amber side markers, showing current gear at all times, and messing with the turn signal "nudge" flashes. Going to try and figure out how to disable the turn signal winking stuff tonight maybe as I haven't found much info about it online outside a few posts talking about enabling Scandinavian DRL, which I don't want.
  36. #196
    Dec 16 2019
    1986 944 turbo
    Oak Hills, CA
    Disable Winking DRL
    09 Cent Elect --> Long Coding --> Byte 2 : Bit 3 (sl_at_drl,active = ON)
    Note: DRL is still slightly dimmed, but does not completely turn off
    2020 SQ5 Prestige, Matador Red.
  37. #197
    Jul 07 2016
    Quote Originally Posted by BarneyM View Post
    Disable Winking DRL
    Let me know if you get this working. I tried coding the wink off when I first got the car but had no luck. Don't remember the coding I tried. But will try this.
  38. #198
    Dec 16 2019
    1986 944 turbo
    Oak Hills, CA
    This worked on my 2020 SQ5. I found others that did not work.
  39. #199
    Sep 15 2016
    2020 SQ5 & 2007 STI
    Miami, FL
    Quote Originally Posted by Cherk947 View Post
    I read reviews on some forums that this was an issue on some paddles so I ended up ordering ones that were not so long to avoid this.
    Mine do not really any contact. Sometimes it'll just rub very slightly on the wiper speed nob but like you said, if you move it to the left, there is no contact.
    I wished they placed the actual pad on the front of the mounting bracket instead of it in the back as it'll look much more flush and also avoid any future rubbing issues.
    2020 Audi SQ5 (Wifey) - Quantum Gray, SPULEN Wheel Spacer, Pending: H&R Super Sport Springs, Black OEM Emblems, RSQ5 Grill
    2012 McLaren MP4-12C (Daily) - Larini Catless DP, 1K Motorsports Stg 2
    2007 Subaru STI (Weekend) - GT3076R (FP-Red), Built Motor.......
    SOLD: 2008 Audi R8, Gated 6-Speed Manual
  40. #200
    Sep 07 2018
    Colorado
    2020 here and I did this same VagCom coding months ago with success.
