Results 1 to 27 of 27
    Jun 15 2019
    Earth
    Timing chain stretch on 3.0T
    Hi all,
    I did a lot of research, so far I can see that timing chain stretch is more of an issue on previous models than the B8 S4, but I did see some people on here getting the P0016 and P0018 which indicates either a timing chain stretch, a sensor issue, or the tensionners being bad enough to cause even further chain stretch.
    Currently, when my car is warm, I get 2.6xx on Bank 2 and 1.1xx on Bank 1.
    I will try to change oil as frequently as possible to slow down the chain stretch, but I would like some feedback at which point should I look into changing all the chains / tensionners?
    Jun 15 2019
    Earth
    Am bumping by asking a couple of questions:
    1. Anyone knows how to measure chain stretch physically on the 3.0T engine, assuming that the valve covers and timing covers are off?
    On the 2.0T engine, there are two notches that are used to measure the chain, one on the intake camshaft, the other on the exhaust cam, and the distance is 12.X cm to be within specs.
    2. Anyone knows which chains stretch exactly? Upper, middle, or center?
    Mar 05 2016
    My car B8.5 warmed up, camshaft adjustment inlet phase 1 & 2: 0.375 degree. I have 115k km and changing oil every 7500km interval.
    However, two friends that have B8, their camshaft adjustment inlet phase 1 & 2 are -47 degree and -48 degree. Does B8 have different interpretations than B8.5? cuz -47 seems very off the specs.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Apr 16 2017
    Illinois
    Quote Originally Posted by Waffles_s4 View Post
    Hi all,
    Try logging these measuring values and sharing it in datazap like I did.
    Quote Originally Posted by TC_S4 View Post
    Could you and your friends log these measuring values?
    2012 S4 | DSG | Prestige | Stage 2 | 187mm Fluidampr | AWE Touring | Eurocode Sways | 034 Insert | CR-15 | Forge Charge Cooler | ECS Carbon Intake
    Jun 15 2019
    Earth
    Bartlett:
    You have a B8, and the values reported by the ECU are not exactly the same than the B8,5.
    For example, on my B8.5 I get the following:
    camshaft adjustment inlet phase: 2.6 on bank 2 (yours is in the -47 to -48 range)
    camshaft adjustment inlet phase: 1.1 on bank 1 (yours is in the -47 to -48 range)
    camshaft adjustment inlet bank 1/2 specified: 127.8 degrees (same as yours)
    Am not sure what do the cam_ofs values are for. Any idea
    Jan 04 2017
    El Monte/CA/United States
    Would a bad sensor give an incorrect reading?
    My values when the car is warm are
    B1 2.6
    B2 6.8
    I recently changed the upper guide and tensioner on driver side so maybe it’s a bad tensioner? Stretched chain? Or installed incorrectly?
    It’s been 4 months since I replaced it the reason I’m looking into this is because I’m getting an irregular idle and vibrations. no misfires in advance measuring block, coils and plugs have been changed last year.
    Mar 05 2016
    Quote Originally Posted by sivletho View Post
    B1 2.6
    B2 6.8
    Look like a bad tensioner, 6.8 degrees basically is over 12 teeth on your actual tensioner, I will go back to the shop who replaced it and have it fix again.
    Veteran Member Four Rings Morritse's Avatar
    May 08 2018
    Stage 2 b8 a5 (sold)
    Berkeley, CA
    Just logged my b8 with a b8.5 motor out of curiosity.
    Everything was 0 across the board and bank1/2 inlet phase adjustment were both around -47-48°
    FBO B8. ~ 10.95@126 ~ 2.96s 0-60 ~ full weight street tires.
    Mar 05 2016
    Quote Originally Posted by Morritse View Post
    Yeah, B8 have these kind of reading -47,-48° ish range. Never figure out why, I believe there are some kind of conversion.
    Mar 31 2008
    eS-4
    CAL*SO
    what values are you guys checking on vcds?
    Mar 05 2016
    Quote Originally Posted by Fresh.S4 View Post
    Camshaft adjustment: inlet phase: bank 1
    Camshaft adjustment: inlet phase: bank 2
    Jan 04 2017
    Would the engine be running like crap at this state? It’s only on idle where it’s irregular but if I gun it it feels normal.
    I actually did the replacement myself lol
    Mar 05 2016
    [QUOTE=sivletho;14434968]Would the engine be running like crap at this state? It’s only on idle where it’s irregular but if I gun it it feels normal.
    Sent from my iPhone using Tapatalk[/QUOT
    Initially, why did you replaced the tensioner? How many teeth were out on the old tensioner and what was the reading?
    Jan 04 2017
    [QUOTE=TC_S4;14435186]
    I was getting a long rattle on cold start so I thought it was the tensioner but it might of been the broken upper guide since I had already bought the tensioner I decided to replace it.
    Unfortunately I didn’t check the values before I changed the tensioner.
    What do you mean by teeth?
    Thanks for the response by the way
    Mar 05 2016
    [QUOTE=sivletho;14435378]
    On the tensioner, marks(teeths) to see how far the tensioner apply tension to the chain. The OE tension should have 12 marks or around 6°. On the vcds ready each degree represent approximately 2 marks. So 6° you pretty much at the limit of your tensioner. It looks like the problem wasn’t your tensioner but the chain itself. Let put it that way, if at the beginning you’re hearing rattle on cold start due to a stretched chain, replacing another tension would change anything, the reading of the inlet should be the same, since the chain is still stretched. I think it’s the chain the culprit.
    Jan 04 2017
    [QUOTE=TC_S4;14435757]
    Damn I should of done more research I would of checked the marks on the tensioner,
    the only thing is there is no more rattling on start up so I think that’s good?
    but if the readings are accurate then for sure it has to be stretched chain.
    I’m Gona try and clean / swap sensors to confirm the readings are correct.
    Mar 05 2016
    [QUOTE=sivletho;14435830]
    Did you swapped an original Audi/VW tensioner or you got an aftermarket tensioner? The original tensioner have 12 marks, some aftermarket tension are longer, so will have few extra marks. If you swap an aftermarket tensioner that’s longer, it’s normal that you will heard no rattle, for now at least.
    Swap sensors to confirm the reading is a good idea.
    When you changed the upper guide and the tensioner, what parts did you have to removed to have access? Did you have to lift the engine, drop the subframe?
    Jan 04 2017
    [QUOTE=TC_S4;14435843]
    I swap to part number 06E109217AJ brand is from ina according to fcp there oem
    the piston did seem skinnier and longer. I used to hate the rattle on start up now I love the quite startup.
    Yes I will start with the sensor swap first and update the tread.
    I have a 2011 A6 3.0t
    I had to disconnect and untangle the o2 sensor and egr wires like 4 in total
    and remove the egr/secondary air injection valve/combi valve that blocks the bottom bolts for the timing cover it’s a tight space but definitely a doable diy project especially if you have the right tools I’m not sure if it’s the same for an s4
    Established Member Two Rings cuerna's Avatar
    Jun 23 2010
    Lubbock, Texas
    I have a 2012 A6 3.0T
    With VCDs I got these:
    Camshaft adjustment Bank 1 inlet phase: -46.5
    Camshaft adjustment Bank 2 inlet phase: -46.1
    Does it sound normal?
    About 1 seconds chain rattle in the morning then goes away. Miles: 120k
    Audi A6 2012 3.0T
    BMW 330i 2006
    VW GLI MKV 2.0T
    Audi A4 B6 1.8T
    VW Golf MK4 2.0
    VW beetle 1995
    Senior Member Two Rings raceshop147's Avatar
    Oct 18 2021
    2012 Toyota Tundra, 2004 Aprilia Tuono R, 2021 Beta 300RR Race
    Does anyone have the procedure to check this via the VCDS?
    I have the scan tool and haven’t figured out how to do this check yet
    Thanks in advance for the support!!
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Quote Originally Posted by RaceShop147 View Post
    If you have the VCDS tool (not a generic version) you can go to the Ross-Tech Forum for assistance (including product support, how-to's and tips, etc.). There are experts from both the US and EU, etc., who are responsive and can help you.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Jun 23 2010
    Lubbock, Texas
    Is under
    Engine>
    Channel 93
    Or (protocol: UDS)
    Engine >
    Advance measuring values>
    Camshaft adjustment inlet phase bank 1
    Camshaft adjustment inlet phase bank 2
    Audi A6 2012 3.0T
    BMW 330i 2006
    VW GLI MKV 2.0T
    Audi A4 B6 1.8T
    VW Golf MK4 2.0
    VW beetle 1995
    Oct 18 2021
    Quote Originally Posted by cuerna View Post
    Is under
    Engine>
    Channel 93
    Or (protocol: UDS)
    Engine >
    Hello
    My values at idle were
    ENG103031, Camshaft adjustment: inlet phase: bank 1, -750°
    ENG99898, Camshaft adjustment: inlet phase: bank 2, 0.750°
    When I rev’d it up they changed a bit…what is the tolerance supposed to be ?
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    What is the acceptable cam adjustment range for the B8 3.0T? (Great/OK/Service Soon/Change Now)?
    - - - Updated - - -
    And while at it: what is the reported service cost range for the timing chain service?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by vtraudt View Post
    - - - Updated - - -
    If you want to replace the chains, tensioners and guides, it can be spendy. The engine must be pulled since everything is on the back of the engine up against the firewall. If you are just wanting to do the guides or tensioners, might as well do the chains, too, as the added cost of the chains is modest compared to having to go back in again.
    Expect $5,000-$6000 USD if done by a reputable shop with proper tools and experience.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Feb 20 2010
    Brighton, MI
    Anyone have the 'tolerances' or limits for both values?
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    2013 A5 3.0T:
    Checked yesterday, warm engine:
    Camshaft adjustment: inlet phase: bank 1 = 1.5 degree
    Camshaft adjustment: inlet phase: bank 2 = 3.0 degree
    Now: what does that indicate?
    Still haven't found any 'good' input as to what the numbers should be, or if they indicate ANYTHING.
    05 Golf TDI
