Hi all,
I am new to this forum, so forgive me if I am posting in the wrong sub.
The car in question is an A4 Allroad 2010 2.0 TFSI. (200k km)
Revo Stage 2 (Running stage 1 setting for the time being)
Test Pipe
R8 Coilpacks (Added after problem started)
Pipercross intake filter
Car has been running fine for 6 months with the current setup.
The problem that I am experiencing is during hard acceleration from about 2k-3K RPM the motor stutter and hesitates hard. After 3K its mostly smooth.
Issue is worse when running up an hill. I would identify the issue as a misfire based on how it feels, but seemingly it is not based on my logs.
Ive had some coils going bad, so first thing I did was switching all the coils to the R8-packs, since I had 4 fresh ones lying around.
That did not do anything to the problem.
Suspected fuel related problem, did a log of Fuel pressure together with misfires. Fuel pressure is stable and no misfires registered.
Have ordered 4 new spark plugs, even though the ones I am currently running are only 10k Km old.
Boost pressure actual vs requested has a diff about 200 hpa = 3 Psi when the stuttering is happening
-Can this be spark plug related even if I get no misfire readings on my logs?
-Suspecting Carbon buildup at the valves?
-Diverter valve issue based on the requested vs actual?
Thanks in advance for any input, or suggestions for log setups.
