Results 1 to 2 of 2
    Mar 13 2020
    Stamford, CT
    Help with fault code P0236
    Check engine light came on today in my Q5
    Fault code read P02360 Turbocharger boost pressure sensor A Circuit range
    I read around and some said that I should replace Map sensor and others said it could be diverter valve
    Any thoughts or experiences?
    Established Member Two Rings Zoltar's Avatar
    Nov 03 2015
    If you can tap in a boost gauge then you can monitor on your dash if you have a vaccum leak. Or if you can check around your diverter valve for signs. My FSI has the upgraded one as they are know to fail
    Sent from my SM-A505W using Tapatalk
