Update - I cleared all the codes and tried another start here is that scan. ECU still does not respond to VCDS on address 01.
I pulled out the ECU from it's plenum and checked all the fuses in that box they were not blown. There were 3 relays in there a (1-395 and 2-614) I pulled them out and did resistance/continuity tests and they passed. I still need to try and put 12v on and make sure they close properly but everything in there looked clean an no corrosion.
I don't have a wiring diagram does anyone know where to go and get one to see if I'm getting power to the ECU? ECU model is 8E0 910 115 B. If I have to buy a new ECU any tips on that? Can I send this ECU to somewhere to get tested or is that a waste? How to get the security pin from the immobilizer? Thanks in advance.
Code:
Thursday,26,March,2020,13:14:47:33376
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64(Parallels)
VCDS Version 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
Data version: 20200210 DS308.0
www.Ross-Tech.com
VIN: WAUDF68E95A478984 License Plate:
Mileage: 205930km-127958mi Repair Order: post-start1
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUDF68E95A478984 Mileage: 205930km-127958miles
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 A HW: 09L 927 156
Component: AG6 09L 2,0TFSI USA 0030
Revision: --H01--- Serial number: 0089293
Coding: 0000002
Shop #: WSC 06335 000 00000
VCID: 2517F75B79E9202F9A3-8071
2 Faults Found:
18289 - Powertrain Data Bus: Missing Message
P1881 - 001 - Acceleration Request
Freeze Frame:
Fault Status: 01110001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 12.0∞C
T.B. Angle: 60.0∞
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU
Freeze Frame:
Fault Status: 01110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 205934 km
Time Indication: 0
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 C HW: 8E0 614 517 BB
Component: ESP8 quattro H04 0180
Revision: 00000000 Serial number: 00000000000000
Coding: 0004528
VCID: 270BFD5303E5323FA8F-8073
2 Faults Found:
01314 - Engine Control Module
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 1
Fault Frequency: 4
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFF93
Hex Value: 0x00FF
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Freeze Frame:
Hex Value: 0x0080
Hex Value: 0x0702
Hex Value: 0x00FF
Hex Value: 0xFF92
Hex Value: 0x00FF
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AM
Component: A4 Klimaautomat 2731
Coding: 00000
Shop #: WSC 00000
VCID: 6C81C27FDF93D16705D-513D
1 Fault Found:
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 J
Component: int. Lastmodul USA 0303
Coding: 01023
Shop #: WSC 65536
VCID: 392F2B2BE041B4CFCEB-4B01
1 Fault Found:
01494 - Bulb for Parking Lamps; Left (M1)
30-00 - Open or Short to Plus
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 E
Component: SDAR XM 0080
VCID: 2B0301631A2D165F4C7-5067
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-00 - -
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 0036N000869C
Coding: 0032607
VCID: 3C21323FEA6381E7D5D-8069
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 02 0070
Serial number: 6332DRB400B3511BF
Coding: 00032607
Subsystem 2 - Serial number: 6342DRB400B28928O
Subsystem 3 - Serial number: 6352ARB400459A40E
Subsystem 4 - Serial number: 6362ARB400458EC8Y
Subsystem 5 - Serial number: 63729RB400468353C
Subsystem 6 - Serial number: 63829RB400468646I
No fault code found.
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenks·ulenmodul 0601
Coding: 02041
Shop #: WSC 06335
VCID: 41DF43CB8891EC0F86B-4B01
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 981 N HW: 8E0 920 981 N
Component: KOMBI+WFS 4 H12 0040
Revision: 0040 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 02345 444 54467
VCID: 38292E2FDE4BADC7315-5185
1 Fault Found:
004 - No Signal/Communication
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: 71BFD30BF8813C8F36B-4B3D
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortger·t T7B 3132
Coding: 11836
Shop #: WSC 06335
VCID: 04518ADFD7033927EDD-4B01
Subsystem 1 - Part No: 8E1959801F
Component: Tırsteuer.FS BRM 0305
Subsystem 2 - Part No: 8E1959802E
Component: Tırsteuer.BF BRM 0205
Subsystem 3 - Part No: 8E0959801A
Component: Tırsteuer.HL BRM 0205
Subsystem 4 - Part No: 8E0959802A
Component: Tırsteuer.HR BRM 0205
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
Shop #: WSC 20209 444 58908
VCID: 2615F05704EF2B37939-8073
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH02 0020
1 Fault Found:
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 40
Time Indication: 0
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0470
Coding: 01205
Shop #: WSC 20209
VCID: 2C01027F1F23116745D-5067
End----(Elapsed Time: 04:53, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
