Results 1 to 2 of 2
    Nov 04 2018
    North Port, Florida
    2006 a4 2.0t random/multiple misfire
    I’ve done some carbon cleaning a while ago, I also replaced several parts as a preventative measure. After trying out the RS4 injectors I switched back to OEM injectors. The car never ran ok after all the work, and I didn’t have time to work on it for a good while. I just fired it up again and it idles pretty good, but once I get to ~2800 rpm the engine misfires heavily at #2 but also randomly across all cylinder. I went for a little test drive and I experienced near total loss of power and heavy misfire. Fuel pressure looks good. No fuel pressure leaks after turning off the engine.
    Senior Member Two Rings Epic-A3's Avatar
    May 05 2019
    Pennsylvania
    Are you getting any other codes?
    Did you put a tune on the car?
    Wild stab in the dark here, but are you 100% the timing is good still?
    If you have spark, and it's on all cylinders... sounds like timing, or maybe a bad seal around intake manifold.
    Check plugs as well, those Rs4 injectors would have had you burning super rich and may have fouled all of your plugs. Normally a different injector needs a tune to burn efficiently.
