Originally Posted by
eruben123
The engines will make the same power with the same tune. The 3.0 Q5 factory trans tune is VERY much neutered compared to the SQ5 factory trans tune, which would definitely have an impact if you were to race them next to each other. Once the TCU is tuned as well as the ECU, they are one and the same.
*All AMAX mapping is the same on the stock tunes. So, if you lined them up for a drag race, the trans tuning would have no impact.
friedliver
Just for completeness there is an additional cooler behind the driver-side fog light in the SQ5 that the Q5 does not have.
SnowmanMafia
Right but it really doesn't matter until someone goes dual pulley.
It's more like the opposite. The additional cooler helps at stock (literally engineered specifically for the extra boost of the SQ vs Q5 3.0T) and stage 1 levels for sure. It's once you get to stage 2 and definitely dual pulley that there's so much extra heat that the little extra cooler more or less becomes negligible.
scottst
IIRC on the last thread I saw on this the IE guys confirmed that the TCU (along with tune) was different in the SQ than the Q.
The trans tune in the SQ, stock, is one of the more aggressive automatic transmission OEM tunes I've experienced. Not bad for a dad mobile.
Correct- just about everything expect for the AMAX maps are different. I typically change 5x as much stuff on Q5 trans tunes compared to the SQ5 tunes.
flyfishing
If I got epl tune, I would assume it is more aggressive than oem sq5 tcu tune?
Not in the sense you're thinking. The WOT shift points (and some part throttle) are higher than a stock SQ5, but virtually everything else remains stock based on what I've seen. Therefore, a stock SQ5 will shift firmer and quicker than a EPL tuned Q5 3.0T. You have to go with a HP Tuners solution to get into that level of trans tune, especially if you want your downshifts and part throttle maps all addressed for both schedules and shift timing and pressures.
MSq5
EPL is mum about what they changed. It does have higher full throttle shift point set at 7,000 rpm compared to stock 6,300. That, alone, is a big improvement. I don’t know if they changed torque converter stall speed in AMAX mode. A good TCU tune will raise that to somewhere between 2,600 and 2,800 rpm. There may be other enhancements. You’ll have to ask those who use that tune and pay attention to details.
It appears that EPL applies a global multiplier of about 1.11 (11% increase) to all the upshift tables...regardless of mode, throttle position, etc... I think it's telling that it's 1.5 yrs later, and they still have never come out and said exactly what modes, particular behaviors, or shift situations they do or do not change. It may be because they know others can see the changes with the proper hardware and software, so it's better just to keep quite and collect people's money.
