Results 1 to 8 of 8
    Junior Member One Ring
    Jul 03 2018
    toronto
    S3 Exhaust installed on an A3. How to open the valves?
    Hi all,
    I just installed an OEM S3 exhaust onto my A3 and the valve flaps are closed right now. Does anyone know how to open up the valves? Is there a way to manually have the flaps open at all times?
    Active Member Three Rings
    Feb 11 2015
    New Jersey
    Pull the motors off, tack weld the flaps to open position
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Just remove them? on the S3, you start it up, then immediately unplug them and they stay open. Its obnoxious open all the time though. I put mine back to stock operation
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Sep 14 2017
    Watertown
    He wont have the wiring to do that trick. Unless I am mistaken? Are they wired up like factory?
    Jul 03 2018
    toronto
    Nope, you're right. The A3 does not have wiring that connects to the valve, like the S3. Any way to do this with a minimal amount of effort? (i.e., no welding and maybe just applying some kind of signal to actuate the flaps?)
    Dec 10 2004
    R8_LS400
    Dallas, TX
    can't you just push them open? the motors should stay put yah?
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Is there a definitive answer on what conditions the valves open on the S3?
    2019 SQ5 Prestige
    Sep 14 2017
    Watertown
    Honestly I think cold Start they are open. And then they open and close while you drive around. They open at 3,000 rpms. I think.... I was monitoring them with vagcom when I did the conversion. And that seemed like that was the case. Anyone else have any more technical information?
