Results 1 to 10 of 10
    Junior Member Two Rings Rickdiculous's Avatar
    Aug 19 2019
    Royal Oak, Michigan
    Allroad 4.2 - Help finding Part No. for Y-Connector to Upper Radiator Coolant Hose
    Been scratching my head with this one for a bit now.
    2005 4.2 Allroad. Have a coolant leak coming from the Y-connector that connects from the bottom of the Upper Radiator Hose. Think that's the name for it, anyway. Part # 4Z7121103 *This is the hose referenced, not the Y-connector as I can't find it. I suspect ECS has the hose mislabeled, calling it "lower" when it should be Upper.
    It's a trickle leak. Have to top off coolant with every tank of gas. Appears to only leak once system is warm/pressurized.
    It appears the previous owner tried to seal the leak with JB weld, but it was ineffective. On inspection the hoses seem fine, clamp is on there tight. Material is pliable, not brittle or cracked.
    Interestingly enough, I tried filing off the JB weld and resealing it myself. When filed off, there was no obvious crack in the plastic, and after resealing the leak is still there
    Hose (with offending Y-connector) removed from car:
    Greater Pic for Context (passenger side, behind headlight, below removable air intake piping) with Y connector circled:
    In case the photos are prohibitively large, album located at: https://imgur.com/F4svHq2
    Does anyone have any clue where I can find this plastic connector? Local Audi wasn't much help. I've bought 4 different ones from amazon, ECS, etc and none of them fit quite right. One was close, but the skinny arm of the Y was slightly too small. Forcing me to attempt to repair my current part.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Quote Originally Posted by Rickdiculous View Post
    Have a coolant leak coming from the Y-connector that connects from the bottom of the Upper Radiator Hose. Think that's the name for it, anyway. Part # 4Z7121103 I suspect ECS has it mislabeled.
    The part number is for the longer rubber hose and smaller Y piece, I don't think it is mislabeled, you can see the part number right on the part in the picture on ECS. The plastic piece you have outlined in your picture (the larger Y) is not shown in the picture you link to at ECS.
    Try looking for the piece here.
    Aug 19 2019
    Royal Oak, Michigan
    Quote Originally Posted by MacFady View Post
    Correct on all counts. Sorry for the confusion. Edited OP for clarity.
    That ECS link is just for reference for that rad hose (even though it confusingly has its own Y at the other non-offending end of it). The alleged leaky Y-connector doesn't appear to be associated with that particular PN.
    That link is blocked at my work, will have to check back at home.
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    According to partslink24 it should be a T-piece there with part# 4Z7 121 087. Hmmm
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Aug 19 2019
    Royal Oak, Michigan
    Quote Originally Posted by AudiNike12 View Post
    I think partslink24 is wrong. I can't see a way that T-piece would fit in the current location without modification
    Anyway, went to a different Audi Service Dept that ended up being of help. They pulled a specific cooling diagram for my VIN, and ID'd the exact part. And were able to share the trivia that my Allroad was born 11/11/'04
    They refused to share the part# with me, naturally. But were able to order it from some obscure warehouse down south for $36+tax. Supposed to be in by middle of next week.
    I'm going to see if I can't get an official Part# for it after the fact and come back here to share it
    Aug 10 2011
    330i ZHP
    It will be on the bag. I don't know why they wouldn't just tell you.
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    Couldn't you just get the hole hose?
    Sent from my SM-J737T1 using Tapatalk
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Aug 10 2011
    330i ZHP
    Quote Originally Posted by m_haiser View Post
    He could, but the part he wants isn't part of that.
    Aug 19 2019
    Royal Oak, Michigan
    Official part number from the bag is 4Z7 121 087
    Can't seem to find the part online anywhere. Only get results for 087A, which is that T-piece.
    Mar 08 2020
    OR
    Thanks for that Rickdiculous! i think my inbox was still locked(new member) when your tried to reply. Appreciate it.
