Originally Posted by
Dondbg
Going deeper .... all started with tip conversion :)
Well what is stopping me is the $ and hands on experience - got you guys and google should tick / cover the experience bit, now for what you suggested the $ is not much, Q’s:
Part 021105701B is not listed as compatible with B6/7 S4’s
Why you didn’t suggest to replace the rings ?
The oil you are suggesting will it not cause some other damaged if I ran it for 10k since it is missing all the additives ..... that the synthetic got ?
Here is the thread for information on the bearings. They work just fine, I have spent a bit of time trying to find affordable solutions for people. I have mine and many other engines running bearings with this specification.
B6 & B7 S4 4.2 BHF / BBK Alternate Rod Bearing Option
https://www.audizine.com/forum/showthread.php?t=905286
I did not suggest to replace the rings as it is most likely not needed. If you asked me this a few months ago, I would have told you to buy my piston rings and throw them in. After a lengthy chat with a engineer who has far more experience than myself and most others I know with Alusil engine’s, you can say I have been enlightened. Here is the breakdown of what I have learned:
Our bores have been prepared from the factory with the appropriate machines and processes to microscopically wear down the aluminum and expose the silicone within the bores. The cast nitride coated rings that are supplied by the factory are not hard enough to wear down the silicone and will not touch the aluminum as it is microscopically beneath the exposed silicon which allows oil to stick to the pores for lubrication. The only thing that is really worn down is the rings and piston skirt coating. Once you clean the ring lands in your pistons, you can then measure clearances to check if they are within spec. They will most likely be within spec.
I say that it is not necessary to change the rings, because they have probably never been properly broken in to begin with. The reason being is that synthetic oil comes factory on these engines and all subsequent oil changes with owners have most likely been synthetic as well. There is nothing wrong with synthetic, in fact it is amazing for reducing wear. The problem is that it is too perfect and will not allow the rings to properly seat and if you measure the rings, they will most likely be very close to factory spec.
The problem with not seating rings is that it allows blow by in both directions. Oil is being blown up into the combustion chamber under vacuum, and gas is being blown down into the oil under compression. When oil gets blown in the combustion chamber, it creates massive carbon build up. The tops of your pistons will most likely be caked in carbon, as well as your ringlangs from all the blow-by getting burned. The problem lies in carbon building up in the ringlands primarily. The more carbon that is built up, equals to less open space that is between the rings and the piston. When you no longer have open space between the rings and the piston, pressure cannot form behind the rings and push the rings against the bores to create a seal between the chamber and crankcase. This will lead to your oil getting diluted by gas and your combustion chambers burning loads of oil and smoking it out the tailpipe.
A easy fix, is to remove the carbon buildup on the ringlands (which is excessive on these engines), reassemble, and continue the break in process. Use conventional oil that is not loaded with additives to continue the process which should have been done in the first place in seating your rings. I recommend Castrol GTX. It will not harm your engine. Change the oil every 3-4k miles while using conventional as it breaks down faster. After you feel that the break in process is complete (I suggest 10k miles on a used engine with un prepped bores) switch back over to synthetic to take advantage of its wear protection.
I totally understand that many may disagree with this and that I may have even not explained it as well as it was to myself. And that is fine. If you really want to re-prep your bores and re-ring your stock engine. Let me know, I sell everything you need. Even the factory rings with a spring loaded oil ring that Audi buys from Mahle that no one can get. I do not mind selling stuff.
Exceptions are if your bores have excessive scoring/wear or if your rings are out of spec.
Here is my thread on prepping bores when I went to forged internals if you want to do if:
https://www.audizine.com/forum/showt...-Engine-Part-2
If preparing the bores and re-ringing, I have been told to do a 15k-20k mile break in on conventional oil. This information only applies to Alusil engine’s/bores as iron bores are rather easy to seat rings.
Sent from my iPhone using
Audizine
