Results 1 to 18 of 18
    May 01 2018
    Virginia
    Getting weight down in RS3, items to remove/change!
    So I am curious what are the best weight savings for an RS3? Is there a topic already posted for this entirely?
    So far I have done:
    Front Pass. Seat removal
    All trunk items
    All rear seat items
    AWE Track exhaust
    So what are the next best things for a car that can be driven on street without affecting performance? How can we get to TT-RS weight? Possible?
    Battery kit- does this require reprogramming? STM plug and play? Best kit?
    Brake Rotors- (not getting rid of stock calipers) Rotors - Best kit savings? 2 piece floating?
    Sorry if this is beaten post. Really would like fun suggestions to lose some more weight!
    2014 SQ5 DP/104 Octane 11.001 @124.55
    2019 TTE RS3 FBO
    2021 GLC63 S AMG
    Apr 25 2017
    MKV R32, 17 GTI, 12 Turbo Beetle
    Marietta GA
    I can’t imagine taking the seats out of the car unless it was just track day. I would start with dropping 7-10 lbs a wheel for some rims. Fuel is 6lbs a gallon. :)
    Veteran Member Three Rings Flom Motorsports's Avatar
    Sep 18 2019
    Northern VA, USA
    swapping out factory body panels for carbon fiber ones. I know there are hood and front fender options out there, but they're not cheap by any means. yes going with the STM battery kit would shave a few pounds. not really sure how far you're willing to go, there's always the option to fully strip the interior, lexan windows etc. anytime you can swap factory parts for lighter ones made out of carbon fiber or titanium/aluminum, you should save weight. theres a company in poland that makes a full front tubular subframe, i believe their weight saving claim is 9kg, about 20lbs
    2018 RS3 - Too many mods to list them all
    2015 Q7 TDI - Daily and tow rig
    www.flommotorsports.com
    Veteran Member Four Rings brad65ford's Avatar
    May 30 2005
    fl
    Would like a sunroof black plexi option or something like that. Surely would remove some nice weight off the top of the car
    Dec 10 2008
    Built MKII Audi TTS, FBO BMW 535XI
    Moose Jaw, SK
    OP, it's probably best to state the purpose of the weight reduction. If it's for road racing, things like the sunroof, and a tubular subframe and control arms (because you're also getting adjustable camber and caster, which is essential for road racing), will take priority. If it's for simple drag racing, the brakes and wheels will take priority over non-rotating mass.
    Check out my site!:
    Regina Wedding Photography
    '19 Audi RS3 - Unitronic Stage 2
    '10 FBO BMW 535XI
    '09 Built Audi TTS
    '02 Audi TT 225 - HTA6262 @35psi - 605wHP
    May 01 2018
    Virginia
    Quote Originally Posted by cheeba View Post
    Drag racing. Want to get it as light as possible..
    2019 TTE RS3 FBO
    2021 GLC63 S AMG
    Dec 10 2008
    Moose Jaw, SK
    Yeah, definitely start with the rotating mass. It's also unsprung mass, so as a benefit, handling improves - to me, considerably - when shaving a lot of weight from the brakes and wheels. Below is some info I had saved from when I originally looked into this. Some 18" wheels will clear our front brakes, so I'd look for some of those - in the 18lb range is about as light as you can get without spending something like $4k+CAD on a top-notch set.
    AP Racing/Essex (TT RS, owner verified) - 21.6 lb/ea
    Girodisc (RS3, per manufacturer) - 24.0 lb/ea
    Neuspeed (RS3, per manufacturer) - 22.4 lb/ea
    OEM (TTRS, per Jeff) - 27 lb/ea
    OEM (RS3, per Girodisc) - 27.4 lb/ea
    OEM (RS3, per Neuspeed) - 26.9 lb/ea
    I'd look to the battery next since you can save about 40lbs there. If you're just swapping it for racing, you can also get a lithium unit at about 4lb, and half the cost of the STM kit, that will still crank our engine.
    After that, I think you have to look to seats and interior stripping, or carbon panels if you want to keep it in daily form. Do you need your AC and stereo?
    Honestly though, slicks on lightweight 18" wheels are going to pick you up a ton of time, provided the surface is prepped well.
    Check out my site!:
    '10 FBO BMW 535XI
    '09 Built Audi TTS
    Jul 13 2018
    Winnipeg, MB, Canada
    Never forget about the second spare tire attached to the driver. A serious racer is lean and mean.
    Dec 03 2017
    Quote Originally Posted by TheContrarian View Post
    Funny thing about that, I knew a guy I used to work with that really got into drag racing and lost over 100lbs specifically to be lighter at the track. Guess this hobby can have health benefits too.
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    Here is my contribution as per yesterday 9 October 2020.
    OEM rotors 29.2lbs
    Neuspeed 2 piece rotors 22.2 lbs
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Senior Member Two Rings RSKYBET's Avatar
    Jan 16 2018
    Midwest
    Quote Originally Posted by S3DUDE View Post
    OEM rotors 29.2lbs
    Which OEM rotor variant did you have? Your factory rotor weight seems a bit higher than other samples.
    2017 Audi RS3 1 of 244 (250) and 1 of 33 in Mythos Black
    @surprs3
    May 01 2016
    Central Florida
    Quote Originally Posted by RSKYBET View Post
    The stock rotors on my 2019 TTRS were just over 29 pounds each The Essex rotors were 21 per
    2023 Kyalami Green RS3
    2022 Dodge Durango SRT (Daily/Hauler)
    2015 Harley Road Glide
    2024 Aprilia Tuareg 660
    Junior Member Two Rings
    Feb 27 2019
    2019 Audi RS3, 2013 500 ABARTH
    Princeton, Texas
    Don't forget the man/ woman behind the steering wheel. There's some weight that can be shed there also.
    I don't know how the cross balancing is on the RS3. You want to remove weights from both sides of the car.
    For the extreme... remove all the HVAC/ Heating systems from the car.
    2019 Audi RS3.
    2020 DODGE Challenger R/T Scat Pack Widebody.
    2013 FIAT 500 ABARTH.
    Aug 29 2017
    Tucson, AZ
    Go to this link and look at my last post. I added new pictures, I weighted the rotors with two scales now and I noticed that my rotors have a completely different shape of rotor hats as the ones advertised by ECS/Neuspeed on their website which makes a lot of sense. Most likely they posted the V2 rotors on that pictures. Again, please go to the link below and look at my last post I posted pictures and I also added the ECStuning link so that you can compare the two rotors design.
    It appears that the V1 OEM rotors are roughly 2 lbs heavier compared to the V2s OEM rotors. Link below:
    https://www.audizine.com/forum/showt...-laying-around
    at 3100ft elevation
    May 22 2020
    2002 Supercharged Civic Si ep3.
    Texas
    OEM rotors 29.2lbs
    That's pretty significant on a rotor. Can you reuse the stock pads? Also is this for the ccbb or the standard rs3 brakes?
    Aug 29 2017
    Tucson, AZ
    ^^ Yes, I was surprised too. I seen pictures on google and others reported 27 lbs and change. My car was built in the beginning of 2018. the difference between the stock rotor and the neuspeed is 24% lighter.
    at 3100ft elevation
    Jun 04 2019
    jb/malaysia
    pretty easy just change the rotor to carbon ceramic , using tillet carbon, battery , full titanium system
    Aug 29 2017
    Tucson, AZ
    ^^^ Yes, I can reuse my stock pads but they had small cracks but on its defense I would say that despite having 17000 miles the pads had another 10000 miles of life on them. As per the rotors, I had the early version and yes they are crazy heavy. The carbon ceramics weight 12.6 or 12.9 lbs.
    at 3100ft elevation
