Yes there are 2 different oils (what they are called on sites are very similar) If the part number was , then its the correct fluid. I believe the sensor is actually in the area of the gear sensor and the clutches are in the atf fluid.
Fluids are very important, hence the reason for changing them so frequently in these transmissions to keep them from having so much issues. If the wrong fluid is used it wont do the same job that it's supposed to do. Also if it's low/dirty, it could also not being doing the job its supposed to causing increased friction, wear and HEAT. From what I read, dirty fluid and heat is what causes this issue in the first place.
Fluid found here, and quite expensive. Part number G052513A2
https://www.fcpeuro.com/products/vw-...YaAqWFEALw_wcB
I'm not sure if they used the right fluid as its just the type there and not part number. I found some other fluid that has a different part number but same oil type as you specified but not for our transmission. Everything I see is that's used for 6mt and front diff.
When I got all my stuff done, I researched and sourced all parts myself with the updated stuff. I all off the part numbers from the tsbs.
