Hey everyone, I don't think I've posted anything on here before and it sucks that the first post would have to be about the infamous "Gearbox Malfunction".
So to give some context, I bought my 2012 Audi S4 Prestige at 63k miles from someone who really took care of the car. He had a very big folder of the maintenance done and the car was still under warranty when he sold it to me. (But was going to expire within the next following months). The car is now at 69.9k miles and the Gearbox Malfunction (you can keep driving) pops up...but then goes (Gearbox malfunction ... limited driving) on top of that the TPMS thing pops up+Yellow check engine lights. My car eventually starts jerking/shifting gears as I struggle to drive the car back home (2mile distance). As for the drive experience, towards the past couple of months driving I noticed that the car would sometimes take a odd amount of time to shift to the next gear (revs really high) and sometimes have small jerks and what-not. I've read through many older posts regarding this topic and was wondering what's the closest "symptoms" I can find with someone else and see how they were able to solve this issue. I usually go to a local indie shop that specializes in Audi's but it's been nearly 2 weeks and their shop is still on holiday close. I read that people either used the mech repair kit, circuit board, or worse...replacing the whole transmission...
TL:DR
The "Gearbox Malfunction" lights came on and my friend helped get the fault codes by scanning my car with VCDS, and is wondering if anyone can give me more insight on this issue. Much appreciated !
The codes that came up:
9708 - Sensor for Gear actuator 2
P171E1 00 [104] - Mechanical Malfunction
Intermittent - Confirmed - Tested since memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frenquency: 2
Reset Counter: 40
Mileage: 111813 km
Date: 2019.12.26
Time: 19:55:16
9712 - Sensor for Gear actuator 2
P171E1 00 [096] - Mechanical Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 111813 km
Date: 2019.12.26
Time: 18:44:20
8030 - Cooling Oil Valve
P179D 00 [232] - Electrical Malfunction
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frenquency: 11
Reset Counter: 40
Mileage: 111813 km
Date: 2019.12.26
Time: 14:58:38
