If pinch bolt for upper control arms is frozen don’t mess with it, can become a nightmare quickly.
Does drive shaft bolt onto transmission output shafts or is it a male spline that goes into transmission?
Usually I disconnect lower ball joint and tie rod end so you can swing hub away to get driveshaft out of wheel bearing
